RTEMS 7.0-rc1
rtems_can_get_bittiming Struct Reference
This structure is used to get CAN bit timing values via IOCTL call. More...
#include <can-bittiming.h>
uint16_t type
 This member specifies which bittiming is to be set (nominal, data) RTEMS_CAN_BITTIME_NOMINAL - nominal bit timing RTEMS_CAN_BITTIME_DATA - data bit timing (for CAN FD chips)
struct rtems_can_bittiming bittiming
 This member holds the rtems_can_bittiming structure. This represents currently set values.
struct rtems_can_bittiming_const bittiming_const
 This member holds the rtems_can_bittiming_const structure. This represents maximum and minimal possible bit timing values.
