RTEMS 7.0-rc1
rtems_can_bittiming Struct Reference
This structure is used to represent CAN bit timing. More...
#include <can-bittiming.h>
uint32_t bitrate
 This member holds CAN bitrate.
uint32_t sample_point
 This member holds CAN sample point.
uint32_t tq
 This member holds time quantum value.
uint32_t prop_seg
 This member holds propagation segment.
uint32_t phase_seg1
 This member holds phase segment 1.
uint32_t phase_seg2
 This member holds phase segment 2.
uint32_t sjw
 This member holds Sync Jump Width value.
uint32_t brp
 This member holds Bit Rate Prescaler value.
This structure is used to set new bit timing or obtain the current one.
