RTEMS 7.0-rc1
rtems_can_bittiming_const Struct Reference
This structure is used to represent CAN bit timing constants. More...
#include <can-bittiming.h>
const char * name
 This member holds the controller's name.
uint32_t tseg1_min
 This member holds mimimal possible TSEG1 value.
uint32_t tseg1_max
 This member holds maximal possible TSEG1 value.
uint32_t tseg2_min
 This member holds mimimal possible TSEG2 value.
uint32_t tseg2_max
 This member holds maximal possible TSEG2 value.
uint32_t sjw_max
 This member holds maximal possible Sync Jump Width value.
uint32_t brp_min
 This member holds mimimal possible Bit Rate Prescaler value.
uint32_t brp_max
 This member holds maximal possible Bit Rate Prescaler value.
uint32_t brp_inc
 This member holds Bit Rate Prescaler initial value.
Controller should define these constants based on its maximal and minimal values.
