RTEMS 7.0-rc1
This structure is used to set CAN bit timing values via IOCTL call. More...
#include <can-bittiming.h>
Data Fields | |
| uint16_t | type |
| This member specifies which bittiming is to be set (nominal, data) RTEMS_CAN_BITTIME_NOMINAL - nominal bit timing RTEMS_CAN_BITTIME_DATA - data bit timing (for CAN FD chips) | |
| uint16_t | from |
| This member specifies the source of bit timing constants RTEMS_CAN_BITTIME_FROM_BITRATE - calculate from bitrate RTEMS_CAN_BITTIME_FROM_PRECOMPUTED - used precomputed values. | |
| struct rtems_can_bittiming | bittiming |
| This member holds the rtems_can_bittiming structure. This is used to specify bitrate or precomputed values. | |
