file | address.h [code] |
| This header file provides the interfaces of the Address Handler.
file | apimutex.h [code] |
| This header file provides the interfaces of the API Mutex Handler.
file | assert.h [code] |
| This header file provides the interfaces of the Assert Handler.
file | atomic.h [code] |
| This header file provides the interfaces of the Atomic Operations.
file | basedefs.h [code] |
| This header file provides basic definitions used by the API and the implementation.
file | bsd-tree.h [code] |
| This header file provides a red-black tree implementation.
file | chain.h [code] |
| This header file provides interfaces of the Chain Handler which are used by the implementation and the API.
file | chainimpl.h [code] |
| This header file provides interfaces of the Chain Handler which are only used by the implementation.
file | context.h [code] |
| This header file provides the interfaces of the Context Handler.
file | copyrt.h [code] |
| This header file provides the interfaces of the Copyright Notice.
file | corebarrier.h [code] |
| This header file provides interfaces of the Barrier Handler which are used by the implementation and the Application Configuration.
file | corebarrierimpl.h [code] |
| This header file provides interfaces of the Barrier Handler which are only used by the implementation.
file | coremsg.h [code] |
| This header file provides interfaces of the Message Queue Handler which are only used by the implementation.
file | coremsgbuffer.h [code] |
| This header file provides interfaces of the Message Queue Handler which are used by the implementation, the Application Configuration, and the API.
file | coremsgimpl.h [code] |
| This header file provides interfaces of the Message Queue Handler which are used by the implementation and the Application Configuration.
file | coremutex.h [code] |
| This header file provides interfaces of the Mutex Handler which are used by the implementation and the Application Configuration.
file | coremuteximpl.h [code] |
| This header file provides interfaces of the Mutex Handler which are only used by the implementation.
file | corerwlockimpl.h [code] |
| This header file provides interfaces of the Read-Write Lock which are only used by the implementation.
file | coresem.h [code] |
| This header file provides interfaces of the Semaphore Handler which are used by the implementation and the Application Configuration.
file | coresemimpl.h [code] |
| This header file provides interfaces of the Semaphore Handler which are only used by the implementation.
file | exception.h [code] |
| This header file provides the interfaces for mapping exceptions to signsls.
file | freechain.h [code] |
| This header file provides interfaces of the Freechain Handler which are used by the implementation and the Application Configuration.
file | freechainimpl.h [code] |
file | hash.h [code] |
| This header file provides the interfaces of the Hash Handler.
file | heap.h [code] |
| This header file provides interfaces of the Heap Handler which are used by the implementation and the Application Configuration.
file | heapimpl.h [code] |
file | heapinfo.h [code] |
| This header file provides interfaces of the Barrier Handler which are used by the implementation and the API.
file | interr.h [code] |
| This header file provides the interfaces of the Internal Error Handler.
file | isr.h [code] |
| This header file provides the main interfaces of the ISR Handler.
file | isrlevel.h [code] |
| This header file provides the ISR_Level related interfaces of the ISR Handler.
file | isrlock.h [code] |
| This header file provides the interfaces of the ISR Locks.
file | memory.h [code] |
| This header file provides the interfaces of the Memory Handler.
file | mpci.h [code] |
| This header file provides interfaces of the MPCI Handler which are used by the implementation and the Application Configuration.
file | mpciimpl.h [code] |
| This header file provides interfaces of the MPCI Handler which are only used by the implementation.
file | mppkt.h [code] |
| This header file provides the interfaces of the Multiprocessing (MP) Packet Handler.
file | mrsp.h [code] |
| This header file provides interfaces of the Multiprocessor Resource Sharing Protocol (MrsP) which are used by the implementation and the Application Configuration.
file | mrspimpl.h [code] |
| This header file provides interfaces of the Multiprocessor Resource Sharing Protocol (MrsP) which are only used by the implementation.
file | muteximpl.h [code] |
| This header file provides the interfaces of the System Lock Mutex Support.
file | object.h [code] |
| This header file provides interfaces of the Object Handler which are used by the implementation and the Application Configuration.
file | objectdata.h [code] |
| This header file provides data structures used by the implementation and the Application Configuration to define instances of Objects_Information, _Objects_MP_Controls, and ultimately Thread_Configured_control.
file | objectimpl.h [code] |
| This header file provides interfaces of the Object Handler which are only used by the implementation.
file | objectmp.h [code] |
| This header file provides the interfaces of the Object Handler Multiprocessing (MP) Support.
file | onceimpl.h [code] |
| This header file provides the interfaces of the Execute Once Support.
file | percpu.h [code] |
| This header file provides the interfaces of the Per-CPU Information.
file | percpudata.h [code] |
| This header file provides the interfaces of the Flexible Per-CPU Data.
file | priority.h [code] |
| This header file provides interfaces of the Priority Handler which are used by the implementation and the Application Configuration.
file | prioritybitmap.h [code] |
| This header file provides interfaces of the Priority Bitmap which are used by the implementation and the Application Configuration.
file | prioritybitmapimpl.h [code] |
| This header file provides interfaces of the Priority Bitmap which are only used by the implementation.
file | priorityimpl.h [code] |
| This header file provides interfaces of the Priority Handler which are only used by the implementation.
file | processormask.h [code] |
| This header file provides the interfaces of the Processor Mask.
file | processormaskimpl.h [code] |
file | profiling.h [code] |
| This header file provides the interfaces of the Profiling Support.
file | protectedheap.h [code] |
| This header file provides the interfaces of the Protected Heap Handler.
file | rbtree.h [code] |
| This header file provides interfaces of the Red-Black Tree Handler which are used by the implementation, the Application Configuration, and the API.
file | rbtreeimpl.h [code] |
| This header file provides interfaces of the Red-Black Tree Handler which are only used by the implementation.
file | scheduler.h [code] |
| This header file provides interfaces of the Scheduler Handler which are used by the implementation and the Application Configuration.
file | schedulercbs.h [code] |
| This header file provides interfaces of the Constant Bandwidth Server (CBS) Scheduler which are used by the implementation and the Application Configuration.
file | schedulercbsimpl.h [code] |
| This header file provides interfaces of the Constant Bandwidth Server (CBS) Scheduler which are only used by the implementation.
file | scheduleredf.h [code] |
| This header file provides interfaces of the EDF Scheduler which are used by the implementation and the Application Configuration.
file | scheduleredfimpl.h [code] |
| This header file provides interfaces of the EDF Scheduler which are only used by the implementation.
file | scheduleredfsmp.h [code] |
| This header file provides the interfaces of the Earliest Deadline First (EDF) Priority SMP Scheduler.
file | schedulerimpl.h [code] |
| This header file provides interfaces of the Scheduler Handler which are only used by the implementation.
file | schedulernode.h [code] |
| This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are used by the implementation and the Application Configuration.
file | schedulernodeimpl.h [code] |
| This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are only used by the implementation.
file | schedulerpriority.h [code] |
| This header file provides interfaces of the Deterministic Priority Scheduler which are used by the implementation and the Application Configuration.
file | schedulerpriorityaffinitysmp.h [code] |
| This header file provides the interfaces of the Deterministic Priority Affinity SMP Scheduler.
file | schedulerpriorityimpl.h [code] |
| This header file provides interfaces of the Deterministic Priority Scheduler which are only used by the implementation.
file | schedulerprioritysmp.h [code] |
| This header file provides interfaces of the Deterministic Priority SMP Scheduler which are used by the implementation and the Application Configuration.
file | schedulerprioritysmpimpl.h [code] |
| This header file provides interfaces of the Deterministic Priority SMP Scheduler which are only used by the implementation.
file | schedulersimple.h [code] |
| This header file provides interfaces of the Simple Priority Scheduler which are used by the implementation and the Application Configuration.
file | schedulersimpleimpl.h [code] |
| This header file provides interfaces of the Simple Priority Scheduler which are only used by the implementation.
file | schedulersimplesmp.h [code] |
| This header file provides the interfaces of the Simple Priority SMP Scheduler.
file | schedulersmp.h [code] |
| This header file provides interfaces of the SMP Scheduler which are used by the implementation and the Application Configuration.
file | schedulersmpimpl.h [code] |
| This header file provides interfaces of the SMP Scheduler which are only used by the implementation.
file | schedulerstrongapa.h [code] |
| This header file provides the interfaces of the Strong APA Scheduler.
file | scheduleruniimpl.h [code] |
| This header file provides interfaces of the supporting the implementation of uniprocessor schedulers.
file | semaphoreimpl.h [code] |
| This header file provides the interfaces of the System Lock Semaphore Support.
file | smp.h [code] |
| This header file provides interfaces of the SMP Support which are used by the implementation and the Application Configuration.
file | smpbarrier.h [code] |
| This header file provides the interfaces of the SMP Barriers.
file | smpimpl.h [code] |
| This header file provides interfaces of the SMP Support which are only used by the implementation.
file | smplock.h [code] |
| This header file provides the main interfaces of the SMP Locks.
file | smplockmcs.h [code] |
| This header file provides the interfaces of the SMP Locks related to MCS locks.
file | smplockseq.h [code] |
| This header file provides the interfaces of the SMP Locks related to sequence locks.
file | smplockstats.h [code] |
| This header file provides the interfaces of the SMP Locks related to lock statistics.
file | smplockticket.h [code] |
| This header file provides the interfaces of the SMP Locks related to ticket locks.
file | stack.h [code] |
| This header file provides interfaces of the Stack Handler which are used by the implementation and the Application Configuration.
file | stackimpl.h [code] |
| This header file provides interfaces of the Stack Handler which are only used by the implementation.
file | states.h [code] |
| This header file provides interfaces of the Thread States which are used by the implementation and the Application Configuration.
file | statesimpl.h [code] |
| This header file provides interfaces of the Thread States which are only used by the implementation.
file | status.h [code] |
| This header file provides the interfaces of the Operation Status Support.
file | sysstate.h [code] |
| This header file provides the interfaces of the System State Handler.
file | thread.h [code] |
| This header file provides interfaces of the Thread Handler which are used by the implementation and the Application Configuration.
file | threadcpubudget.h [code] |
| This header file provides interfaces used to implement the CPU budget management of threads.
file | threaddispatch.h [code] |
| This header file provides the interfaces of the Thread Handler related to thread dispatching.
file | threadidledata.h [code] |
| This header file provides data structures used by the implementation and the Application Configuration to define _Thread_Idle_stack_size and _Thread_Idle_body.
file | threadimpl.h [code] |
| This header file provides interfaces of the Thread Handler which are only used by the implementation.
file | threadmp.h [code] |
| This header file provides the interfaces of the Thread Handler Multiprocessing (MP) Support.
file | threadq.h [code] |
| This header file provides interfaces of the Thread Queue Handler which are used by the implementation and the Application Configuration.
file | threadqimpl.h [code] |
| This header file provides interfaces of the Thread Queue Handler which are only used by the implementation.
file | threadqops.h [code] |
| This header file provides interfaces related to thread queue operations.
file | timecounter.h [code] |
| This header file provides interfaces of the Timecounter Handler which are used by the implementation and the API.
file | timecounterimpl.h [code] |
| This header file provides interfaces of the Timecounter Handler which are only used by the implementation.
file | timespec.h [code] |
| This header file provides the interfaces of the Timespec Helpers.
file | timestamp.h [code] |
| This header file provides interfaces of the Timestamp Handler which are used by the implementation and the Application Configuration.
file | timestampimpl.h [code] |
| This header file provides interfaces of the Timestamp Handler which are only used by the implementation.
file | tls.h [code] |
| This header file provides the interfaces of the Thread-Local Storage (TLS).
file | todimpl.h [code] |
| This header file provides the interfaces of the Time of Day Handler and the Time of Day Handler Action Hooks.
file | userext.h [code] |
| This header file provides interfaces of the User Extensions Handler which are used by the implementation and the Application Configuration.
file | userextdata.h [code] |
| This header file provides data structures used by the implementation and the Application Configuration to define _User_extensions_Initial_count, _User_extensions_Initial_extensions, and _User_extensions_Initial_switch_controls.
file | userextimpl.h [code] |
| This header file provides interfaces of the User Extensions Handler which are only used by the implementation.
file | watchdog.h [code] |
| This header file provides interfaces of the Watchdog Handler which are used by the implementation and the Application Configuration.
file | watchdogimpl.h [code] |
| This header file provides interfaces of the Watchdog Handler which are only used by the implementation.
file | watchdogticks.h [code] |
| This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are used by the implementation and the Application Configuration.
file | wkspace.h [code] |
| This header file provides interfaces of the Workspace Handler which are only used by the implementation.
file | wkspacedata.h [code] |
| This header file provides data structures used by the implementation and the Application Configuration to define _Workspace_Size, _Workspace_Is_unified, and _Workspace_Malloc_initializer.
file | wkspaceinitmulti.h [code] |
| This header file provides the implementation of _Workspace_Initialize_for_multiple_areas().
file | wkspaceinitone.h [code] |
| This header file provides the implementation of _Workspace_Initialize_for_one_area().
