RTEMS 6.1-rc5
Data Structures | Macros
isrlock.h File Reference
This header file provides the interfaces of the ISR Locks. More...
#include <rtems/score/isrlevel.h>
#include <rtems/score/smplock.h>
struct  ISR_lock_Context
 Local ISR lock context for acquire and release pairs. More...
#define ISR_LOCK_NEEDS_OBJECT   0
 If this define has a non-zero value, then the interrupt lock operations require an object of type ::ISR_lock_Control, otherwise no lock object is required.
#define _ISR_lock_Initialize(_lock, _name)    do { (void) _name; } while (0)
 Initializes an ISR lock.
#define _ISR_lock_Destroy(_lock)
 Destroys an ISR lock.
#define _ISR_lock_Set_name(_lock, _name)
 Sets the name of an ISR lock.
#define _ISR_lock_ISR_disable_and_acquire(_lock, _context)    _ISR_Local_disable( ( _context )->isr_level )
 Acquires an ISR lock.
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)    _ISR_Local_enable( ( _context )->isr_level )
 Releases an ISR lock.
#define _ISR_lock_Acquire(_lock, _context)    do { (void) _context; } while ( 0 )
 Acquires an ISR lock inside an ISR disabled section.
#define _ISR_lock_Release(_lock, _context)    do { (void) _context; } while ( 0 )
 Releases an ISR lock inside an ISR disabled section.
#define _ISR_lock_Acquire_inline(_lock, _context)    do { (void) _context; } while ( 0 )
 Acquires an ISR lock inside an ISR disabled section (inline).
#define _ISR_lock_Release_inline(_lock, _context)    do { (void) _context; } while ( 0 )
 Releases an ISR lock inside an ISR disabled section (inline).
#define _ISR_lock_ISR_disable_profile(_context)
#define _ISR_lock_ISR_disable(_context)
 Disables interrupts and saves the previous interrupt state in the ISR lock context.
#define _ISR_lock_ISR_enable(_context)    _ISR_Local_enable( ( _context )->isr_level )
 Restores the saved interrupt state of the ISR lock context.
