RTEMS 6.1-rc5
This group contains the API Mutex Handler implementation. More...
Modules | |
RTEMS Allocator Mutex | |
Protection for all memory allocations and deallocations in RTEMS. | |
Files | |
file | apimutex.h |
This header file provides the interfaces of the API Mutex Handler. | |
file | allocatormutex.c |
This source file contains the implementation of _RTEMS_Lock_allocator(), _RTEMS_Unlock_allocator(), and _RTEMS_Allocator_is_owner(). | |
file | apimutexisowner.c |
This source file contains the implementation of _API_Mutex_Is_owner(). | |
file | apimutexlock.c |
This source file contains the implementation of _API_Mutex_Lock(). | |
file | apimutexunlock.c |
This source file contains the implementation of _API_Mutex_Unlock(). | |
struct | API_Mutex_Control |
Control block used to manage each API mutex. More... | |
#define | API_MUTEX_INITIALIZER(name) { _MUTEX_RECURSIVE_NAMED_INITIALIZER( name ), 0 } |
Statically initialize an API mutex. | |
void | _API_Mutex_Lock (API_Mutex_Control *mutex) |
Acquires the specified API mutex. | |
void | _API_Mutex_Unlock (API_Mutex_Control *mutex) |
Releases the specified API mutex. | |
bool | _API_Mutex_Is_owner (const API_Mutex_Control *mutex) |
Checks if the specified API mutex is owned by the executing thread. | |
This handler provides routines to ensure mutual exclusion in a thread context at the API level.
bool _API_Mutex_Is_owner | ( | const API_Mutex_Control * | mutex | ) |
[in] | mutex | The API mutex to check the owner from. |
void _API_Mutex_Lock | ( | API_Mutex_Control * | mutex | ) |
[in,out] | mutex | The API mutex to acquire. |
void _API_Mutex_Unlock | ( | API_Mutex_Control * | mutex | ) |
[in,out] | mutex | The API mutex to release. |
