#define | THREAD_WAIT_STATE_MASK 0xffU |
| Mask to get the thread wait state flags.
#define | THREAD_WAIT_STATE_READY 0x0U |
| Indicates that the thread does not wait on something.
#define | THREAD_WAIT_STATE_INTEND_TO_BLOCK 0x1U |
| Indicates that the thread begins with the blocking operation.
#define | THREAD_WAIT_STATE_BLOCKED 0x2U |
| Indicates that the thread completed the blocking operation.
#define | THREAD_WAIT_CLASS_MASK 0xff00U |
| Mask to get the thread wait class flags.
#define | THREAD_WAIT_CLASS_EVENT 0x100U |
| Indicates that the thread waits for an event.
#define | THREAD_WAIT_CLASS_SYSTEM_EVENT 0x200U |
| Indicates that the thread waits for a system event.
#define | THREAD_WAIT_CLASS_OBJECT 0x400U |
| Indicates that the thread waits for an object.
#define | THREAD_WAIT_CLASS_PERIOD 0x800U |
| Indicates that the thread waits for a period.
void | _Thread_Iterate (Thread_Visitor visitor, void *arg) |
| Calls the visitor with all threads and the given argument until it is done.
void | _Thread_Initialize_information (Thread_Information *information) |
| Initializes the thread information.
void | _Thread_Handler_initialization (void) |
| Initializes thread handler.
void | _Thread_Create_idle (void) |
| Creates idle thread.
RTEMS_NO_RETURN void | _Thread_Start_multitasking (void) |
| Starts thread multitasking.
Status_Control | _Thread_Initialize (Thread_Information *information, Thread_Control *the_thread, const Thread_Configuration *config) |
| Initializes thread.
void | _Thread_Free (Thread_Information *information, Thread_Control *the_thread) |
| Frees the thread.
Status_Control | _Thread_Start (Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context) |
| Starts the specified thread.
Status_Control | _Thread_Restart (Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context) |
| Restarts the thread.
void | _Thread_Yield (Thread_Control *executing) |
| Yields the currently executing thread.
Thread_Life_state | _Thread_Change_life (Thread_Life_state life_states_to_clear, Thread_Life_state life_states_to_set, Thread_Life_state ignored_life_states) |
| Changes the life of currently executing thread.
Thread_Life_state | _Thread_Set_life_protection (Thread_Life_state state) |
| Set the thread to life protected.
void | _Thread_Kill_zombies (void) |
| Kills all zombie threads in the system.
RTEMS_NO_RETURN void | _Thread_Exit (void *exit_value, Thread_Life_state life_states_to_set) |
| Exits the currently executing thread.
Status_Control | _Thread_Join (Thread_Control *the_thread, States_Control waiting_for_join, Thread_Control *executing, Thread_queue_Context *queue_context) |
| Joins the currently executing thread with the thread.
Thread_Cancel_state | _Thread_Cancel (Thread_Control *the_thread, Thread_Control *executing, Thread_Life_state life_states_to_clear) |
| Cancels the thread.
Status_Control | _Thread_Close (Thread_Control *the_thread, Thread_Control *executing, Thread_queue_Context *queue_context) |
| Closes the thread.
States_Control | _Thread_Clear_state_locked (Thread_Control *the_thread, States_Control state) |
| Clears the specified thread state without locking the lock context.
States_Control | _Thread_Clear_state (Thread_Control *the_thread, States_Control state) |
| Clears the specified thread state.
States_Control | _Thread_Set_state_locked (Thread_Control *the_thread, States_Control state) |
| Sets the specified thread state without locking the lock context.
States_Control | _Thread_Set_state (Thread_Control *the_thread, States_Control state) |
| Sets the specified thread state.
void | _Thread_Load_environment (Thread_Control *the_thread) |
| Initializes enviroment for a thread.
void | _Thread_Entry_adaptor_idle (Thread_Control *executing) |
| Calls the start kinds idle entry of the thread.
void | _Thread_Entry_adaptor_numeric (Thread_Control *executing) |
| Calls the start kinds numeric entry of the thread.
void | _Thread_Entry_adaptor_pointer (Thread_Control *executing) |
| Calls the start kinds pointer entry of the thread.
void | _Thread_Handler (void) |
| Wrapper function for all threads.
void | _Thread_Priority_perform_actions (Thread_Control *start_of_path, Thread_queue_Context *queue_context) |
| Checks if the thread is owner of the lock of the join queue.
void | _Thread_Priority_add (Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
| Adds the specified thread priority node to the corresponding thread priority aggregation.
void | _Thread_Priority_remove (Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
| Removes the specified thread priority node from the corresponding thread priority aggregation.
void | _Thread_Priority_changed (Thread_Control *the_thread, Priority_Node *priority_node, Priority_Group_order priority_group_order, Thread_queue_Context *queue_context) |
| Propagates a thread priority value change in the specified thread priority node to the corresponding thread priority aggregation.
void | _Thread_Priority_update (Thread_queue_Context *queue_context) |
| Updates the priority of all threads in the set.
Thread_Control * | _Thread_Get (Objects_Id id, ISR_lock_Context *lock_context) |
| Gets a thread by its identifier.
Objects_Id | _Thread_Self_id (void) |
| Gets the identifier of the calling thread.
Timestamp_Control | _Thread_Get_CPU_time_used (Thread_Control *the_thread) |
| Updates the used cpu time for the heir and dispatches a new heir.
Timestamp_Control | _Thread_Get_CPU_time_used_locked (Thread_Control *the_thread) |
| Gets the used processor time of the thread throughout its entire lifetime if the caller already acquired the thread state and home scheduler locks.
Timestamp_Control | _Thread_Get_CPU_time_used_after_last_reset (Thread_Control *the_thread) |
| Gets the used processor time of the thread after the last CPU usage reset.
Objects_Id | _Thread_Wait_get_id (const Thread_Control *the_thread) |
| Returns the object identifier of the object containing the current thread wait queue.
void | _Thread_Continue (Thread_Control *the_thread, Status_Control status) |
| Cancels a blocking operation so that the thread can continue its execution.
void | _Thread_Timeout (Watchdog_Control *the_watchdog) |
| General purpose thread wait timeout.
Status_Control | _Thread_Set_name (Thread_Control *the_thread, const char *name) |
| Sets the name of the thread.
size_t | _Thread_Get_name (const Thread_Control *the_thread, char *buffer, size_t buffer_size) |
| Gets the name of the thread.
This header file provides interfaces of the Thread Handler which are only used by the implementation.
