RTEMS 6.1-rc4
ARM Architecture Support. More...
Modules | |
AArch32 System Registers | |
This group provides functions to read and write the AArch32 system registers. | |
ARM Assembler Support | |
ARM Assembler Support. | |
ARM Co-Processor 15 Support | |
ARM co-processor 15 (CP15) support. | |
ARM Paravirtualization Support | |
PMSAv7 Support | |
This group provides support functions to manage an Arm PMSAv7 (Protected Memory System Architecture) based Memory Protection Unit (MPU). | |
PMSAv8-32 Support | |
This group provides support functions to manage an Arm PMSAv8-32 (Protected Memory System Architecture) based Memory Protection Unit (MPU). | |
Files | |
file | __aeabi_read_tp.c |
This source file contains the implementation of __aeabi_read_tp(). | |
file | __tls_get_addr.c |
This source file contains the implementation of __tls_get_addr(). | |
file | arm-exception-default.c |
This source file contains the implementation of _ARM_Exception_default(). | |
file | arm-exception-frame-print.c |
This source file contains the implementation of _CPU_Exception_frame_print(). | |
file | armv4-isr-install-vector.c |
This source file contains the ARM-specific _CPU_ISR_install_vector(). | |
file | armv4-sync-synchronize.c |
This source file contains the implementation of __sync_synchronize(). | |
file | armv7-thread-idle.c |
This source file contains the implementation of _CPU_Thread_Idle_body(). | |
file | armv7m-context-initialize.c |
This source file contains the implementation of _CPU_Context_Initialize(). | |
file | armv7m-context-restore.c |
This source file contains the implementation of _CPU_Context_restore(). | |
file | armv7m-context-switch.c |
This source file contains the implementation of _CPU_Context_switch(). | |
file | armv7m-exception-default.c |
This source file contains the implementation of _ARMV7M_Exception_default(). | |
file | armv7m-exception-handler-get.c |
This source file contains the implementation of _ARMV7M_Get_exception_handler(). | |
file | armv7m-exception-handler-set.c |
This source file contains the implementation of _ARMV7M_Set_exception_handler(). | |
file | armv7m-exception-priority-get.c |
This source file contains the implementation of _ARMV7M_Get_exception_priority(). | |
file | armv7m-exception-priority-handler.c |
This source file contains the implementation of _ARMV7M_Set_exception_priority_and_handler(). | |
file | armv7m-exception-priority-set.c |
This source file contains the implementation of _ARMV7M_Set_exception_priority(). | |
file | armv7m-initialize.c |
This source file contains the implementation of _CPU_Initialize(). | |
file | armv7m-isr-dispatch.c |
This source file contains the implementation of _ARMV7M_Thread_dispatch(). | |
file | armv7m-isr-enter-leave.c |
This source file contains the implementation of _ARMV7M_Interrupt_service_enter() and _ARMV7M_Interrupt_service_leave(). | |
file | armv7m-isr-level-get.c |
This source file contains the implementation of _CPU_ISR_Get_level(). | |
file | armv7m-isr-level-set.c |
This source file contains the implementation of _CPU_ISR_Set_level(). | |
file | armv7m-isr-vector-install.c |
This source file contains the implementation of _CPU_ISR_install_vector(). | |
file | armv7m-multitasking-start-stop.c |
This source file contains the implementation of _ARMV7M_Start_multitasking(). | |
file | cpu.c |
This source file contains static assertions to ensure the consistency of interfaces used in C and assembler and it contains the ARM-specific implementation of _CPU_Initialize(), _CPU_ISR_Get_level(), _CPU_ISR_Set_level(), and _CPU_Context_Initialize(). | |
file | arm.h |
This header file provides defines derived from ARM multilib defines. | |
file | armv4.h |
This header file provides interfaces of the ARMv4 architecture support. | |
file | armv7m.h |
This header file provides interfaces of the ARMv7-M architecture support. | |
file | cpu.h |
This header file defines implementation interfaces pertaining to the port of the executive to the ARM architecture. | |
file | cpu_asm.h |
ARM Assembler Support API. | |
file | cpuimpl.h |
struct | Context_Control |
Thread register context. More... | |
struct | ARM_VFP_context |
struct | CPU_Exception_frame |
The set of registers that specifies the complete processor state. More... | |
#define | CPU_MODEL_NAME "ARMv4" |
#define | ARM_MULTILIB_ARCH_V4 |
#define | CPU_NAME "ARM" |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 32 |
#define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define | CPU_MODES_INTERRUPT_MASK 0x1 |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE (1024 * 4) |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT 8 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 8 |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_USE_LIBC_INIT_FINI_ARRAY TRUE |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44 |
#define | ARM_EXCEPTION_FRAME_SIZE 80 |
#define | ARM_EXCEPTION_FRAME_REGISTER_R8_OFFSET 32 |
#define | ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET 52 |
#define | ARM_EXCEPTION_FRAME_REGISTER_PC_OFFSET 60 |
#define | ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET 72 |
#define | ARM_VFP_CONTEXT_SIZE 264 |
#define | _CPU_ISR_Disable(_isr_cookie) |
#define | _CPU_ISR_Enable(_isr_cookie) arm_interrupt_enable( _isr_cookie ) |
#define | _CPU_ISR_Flash(_isr_cookie) arm_interrupt_flash( _isr_cookie ) |
#define | _CPU_Context_Get_SP(_context) (_context)->register_sp |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Initialize_fp(_destination) |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | CPU_THREAD_LOCAL_STORAGE_VARIANT 11 |
Typedefs | |
typedef void(* | CPU_ISR_handler) (void) |
typedef uint32_t | CPU_Counter_ticks |
typedef uintptr_t | CPU_Uint32ptr |
void | _CPU_ISR_Set_level (uint32_t level) |
Sets the hardware interrupt level by the level value. | |
uint32_t | _CPU_ISR_Get_level (void) |
void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
void | _CPU_Initialize (void) |
CPU initialization. | |
void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
CPU switch context. | |
RTEMS_NO_RETURN void | _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir) |
RTEMS_NO_RETURN void | _CPU_Context_restore (Context_Control *new_context) |
uint32_t | _CPU_Counter_frequency (void) |
CPU_Counter_ticks | _CPU_Counter_read (void) |
RTEMS_NO_RETURN void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
RTEMS_NO_RETURN void | _ARM_Exception_default (CPU_Exception_frame *frame) |
void | _CPU_Context_volatile_clobber (uintptr_t pattern) |
void | _CPU_Context_validate (uintptr_t pattern) |
RTEMS_NO_RETURN void | _CPU_Exception_resume (const CPU_Exception_frame *frame) |
#define _CPU_Context_Initialize_fp | ( | _destination | ) |
#define _CPU_ISR_Disable | ( | _isr_cookie | ) |
typedef uintptr_t CPU_Uint32ptr |
Type that can store a 32-bit integer or a pointer.
void _CPU_Initialize | ( | void | ) |
CPU initialization.
CPU initialization.
void _CPU_ISR_Set_level | ( | uint32_t | level | ) |
[in] | level | for or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15. |
