RTEMS 6.1-rc4
Files | Data Structures | Macros | Typedefs
This group provides support functions to manage an Arm PMSAv7 (Protected Memory System Architecture) based Memory Protection Unit (MPU). More...
file  armv7-pmsa.h
 This header file provides the API to manage an Arm PMSAv7 based Memory Protection Unit (MPU).
struct  ARMV7_PMSA_Region
 The region definition is used to initialize the Memory Protection Unit (MPU). More...
#define ARMV7_RGNR_REGION_SHIFT   0
#define ARMV7_RGNR_REGION_MASK   0xffU
#define ARMV7_RGNR_REGION_GET(_reg)    (((_reg)&ARMV7_RGNR_REGION_MASK) >> ARMV7_RGNR_REGION_SHIFT)
#define ARMV7_RGNR_REGION_SET(_reg, _val)
#define ARMV7_RGNR_REGION(_val)    (((_val) << ARMV7_RGNR_REGION_SHIFT) & ARMV7_RGNR_REGION_MASK)
#define ARMV7_RSR_EN   0x1U
#define ARMV7_RSR_RSIZE_SHIFT   1
#define ARMV7_RSR_RSIZE_MASK   0x3eU
#define ARMV7_RSR_RSIZE_GET(_reg)    (((_reg)&ARMV7_RSR_RSIZE_MASK) >> ARMV7_RSR_RSIZE_SHIFT)
#define ARMV7_RSR_RSIZE_SET(_reg, _val)
#define ARMV7_RSR_RSIZE(_val)    (((_val) << ARMV7_RSR_RSIZE_SHIFT) & ARMV7_RSR_RSIZE_MASK)
#define ARMV7_RSR_SD_SHIFT   8
#define ARMV7_RSR_SD_MASK   0xff00U
#define ARMV7_RSR_SD_GET(_reg)    (((_reg)&ARMV7_RSR_SD_MASK) >> ARMV7_RSR_SD_SHIFT)
#define ARMV7_RSR_SD_SET(_reg, _val)
#define ARMV7_RSR_SD(_val)   (((_val) << ARMV7_RSR_SD_SHIFT) & ARMV7_RSR_SD_MASK)
#define ARMV7_RACR_B   0x1U
#define ARMV7_RACR_C   0x2U
#define ARMV7_RACR_S   0x4U
#define ARMV7_RACR_TEX_0   0x8U
#define ARMV7_RACR_TEX_1   0x10U
#define ARMV7_RACR_TEX_2   0x20U
#define ARMV7_RACR_AP_0   0x100U
#define ARMV7_RACR_AP_1   0x200U
#define ARMV7_RACR_AP_2   0x400U
#define ARMV7_RACR_XN   0x1000U
#define ARMV7_PMSA_READ_ONLY_CACHED
#define ARMV7_PMSA_READ_ONLY_UNCACHED    (ARMV7_RACR_TEX_0 | ARMV7_RACR_AP_0 | ARMV7_RACR_AP_2)
#define ARMV7_PMSA_READ_WRITE_CACHED    (ARMV7_RACR_TEX_0 | ARMV7_RACR_C | ARMV7_RACR_B | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_READ_WRITE_UNCACHED   (ARMV7_RACR_TEX_0 | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_READ_WRITE_SHARED    (ARMV7_RACR_TEX_0 | ARMV7_RACR_S | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_SHAREABLE_DEVICE   (ARMV7_RACR_B | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_NON_SHAREABLE_DEVICE   (ARMV7_RACR_TEX_1 | ARMV7_RACR_AP_0)
typedef struct ARMV7_PMSA_Region ARMV7_PMSA_Region
◆ ARMV7_PMSA_READ_ONLY_CACHED
Value:
(ARMV7_RACR_TEX_0 | ARMV7_RACR_C | ARMV7_RACR_B | ARMV7_RACR_AP_0 | \
ARMV7_RACR_AP_2)
◆ ARMV7_RGNR_REGION_SET
#define ARMV7_RGNR_REGION_SET (   _reg,
  _val
Value:
(((_reg) & ~ARMV7_RGNR_REGION_MASK) | \
(((_val) << ARMV7_RGNR_REGION_SHIFT) & ARMV7_RGNR_REGION_MASK))
◆ ARMV7_RSR_RSIZE_SET
#define ARMV7_RSR_RSIZE_SET (   _reg,
  _val
Value:
(((_reg) & ~ARMV7_RSR_RSIZE_MASK) | \
(((_val) << ARMV7_RSR_RSIZE_SHIFT) & ARMV7_RSR_RSIZE_MASK))
◆ ARMV7_RSR_SD_SET
#define ARMV7_RSR_SD_SET (   _reg,
  _val
Value:
(((_reg) & ~ARMV7_RSR_SD_MASK) | \
(((_val) << ARMV7_RSR_SD_SHIFT) & ARMV7_RSR_SD_MASK))
Typedef Documentation
◆ ARMV7_PMSA_Region
A region is empty if the size is zero.
