RTEMS 6.1-rc4
Modules | Files | Data Structures | Macros | Typedefs | Enumerations | Functions
This group contains the AArch64 CPU port. More...
 AArch64 Assembler Support
 AArch64 Assembler Support.
 AArch64 Paravirtualization Support
 This handler encapsulates the functionality (primarily conditional feature defines) related to paravirtualization on the AArch64.
file  aarch64-exception-default.c
 This source file contains the implementation of _AArch64_Exception_default().
file  aarch64-exception-frame-print.c
 Implementation of _CPU_Exception_frame_print.
file  aarch64-exception-frame.c
 This source file contains the implementation of _CPU_Exception_disable_thread_dispatch(), _CPU_Exception_frame_get_signal(), _CPU_Exception_frame_set_resume(), and _CPU_Exception_frame_make_resume_next_instruction().
file  aarch64-thread-idle.c
 This source file contains the AArch64-specific _CPU_Thread_Idle_body() implementation.
file  cpu.c
 AArch64 architecture support implementation.
file  mmu-vmsav8-64.h
 Definitions used in MMU setup.
file  vectors.h
 ARM AArch64 Exception API.
file  aarch64-system-registers.h
 This header file provides the API to read and write the AArch64 system registers.
file  cpu.h
 This header file provides interfaces of the AArch64 CPU port.
struct  Context_Control
 Thread register context. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
#define AARCH64_MULTILIB_HAS_WFI
#define AARCH64_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
#define AARCH64_MULTILIB_HAS_BARRIER_INSTRUCTIONS
#define AARCH64_MULTILIB_HAS_CPACR
#define AARCH64_MULTILIB_CACHE_LINE_MAX_64
#define CPU_NAME   "AArch64"
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   TRUE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   32
#define CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
#define CPU_MODES_INTERRUPT_MASK   0x1
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1024 * 8)
#define CPU_SIZEOF_POINTER   __SIZEOF_POINTER__
#define CPU_ALIGNMENT   16
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   16
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_LIBC_INIT_FINI_ARRAY   TRUE
#define CPU_MAXIMUM_PROCESSORS   32
#define AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET   0x70
#define AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE   0x68
#define AARCH64_EXCEPTION_FRAME_SIZE   0x350
#define AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET   0xF8
#define AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET   0xF0
#define AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET   0x108
#define AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET   0x118
#define AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET   0x128
#define AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET   0x138
#define AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET   0x150
#define _CPU_ISR_Disable(_isr_cookie)
#define _CPU_ISR_Enable(_isr_cookie)    AArch64_interrupt_enable( _isr_cookie )
#define _CPU_ISR_Flash(_isr_cookie)    AArch64_interrupt_flash( _isr_cookie )
#define _CPU_Context_Get_SP(_context)    (_context)->register_sp
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Initialize_fp(_destination)
#define VECTOR_POINTER_OFFSET   0x78
#define VECTOR_ENTRY_SIZE   0x80
#define CPU_PER_CPU_CONTROL_SIZE   0
#define CPU_INTERRUPT_FRAME_SIZE   0x2E0
#define CPU_THREAD_LOCAL_STORAGE_VARIANT   11
typedef unsigned __int128 uint128_t
typedef void(* CPU_ISR_handler) (void)
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
enum  AArch64_symbolic_exception_name {
  AARCH64_EXCEPTION_SP0_SYNCHRONOUS = 0 , AARCH64_EXCEPTION_SP0_IRQ = 1 , AARCH64_EXCEPTION_SP0_FIQ = 2 , AARCH64_EXCEPTION_SP0_SERROR = 3 ,
  AARCH64_EXCEPTION_SPx_SYNCHRONOUS = 4 , AARCH64_EXCEPTION_SPx_IRQ = 5 , AARCH64_EXCEPTION_SPx_FIQ = 6 , AARCH64_EXCEPTION_SPx_SERROR = 7 ,
  AARCH64_EXCEPTION_LEL64_SYNCHRONOUS = 8 , AARCH64_EXCEPTION_LEL64_IRQ = 9 , AARCH64_EXCEPTION_LEL64_FIQ = 10 , AARCH64_EXCEPTION_LEL64_SERROR = 11 ,
  AARCH64_EXCEPTION_LEL32_SYNCHRONOUS = 12 , AARCH64_EXCEPTION_LEL32_IRQ = 13 , AARCH64_EXCEPTION_LEL32_FIQ = 14 , AARCH64_EXCEPTION_LEL32_SERROR = 15 ,
  MAX_EXCEPTIONS = 16 , AARCH64_EXCEPTION_MAKE_ENUM_64_BIT = INT_MAX
void _CPU_ISR_Set_level (uint32_t level)
 Sets the hardware interrupt level by the level value.
uint32_t _CPU_ISR_Get_level (void)
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint64_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
void _CPU_Initialize (void)
 CPU initialization.
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context.
RTEMS_NO_RETURN void _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir)
RTEMS_NO_RETURN void _CPU_Context_restore (Context_Control *new_context)
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
RTEMS_NO_RETURN void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _AArch64_Exception_interrupt_no_nest (void)
void _AArch64_Exception_interrupt_nest (void)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
RTEMS_NO_RETURN void _CPU_Exception_resume (CPU_Exception_frame *frame)
RTEMS_NO_RETURN void _CPU_Exception_dispatch_and_resume (CPU_Exception_frame *frame)
void _CPU_Exception_disable_thread_dispatch (void)
int _CPU_Exception_frame_get_signal (CPU_Exception_frame *frame)
void _CPU_Exception_frame_set_resume (CPU_Exception_frame *frame, void *address)
void _CPU_Exception_frame_make_resume_next_instruction (CPU_Exception_frame *frame)
void _AArch64_Exception_frame_copy (CPU_Exception_frame *new_ef, CPU_Exception_frame *old_ef)
void _AArch64_Exception_default (CPU_Exception_frame *frame)
void _CPU_Context_volatile_clobber (uintptr_t pattern)
void _CPU_Context_validate (uintptr_t pattern)
Program State Registers
#define AARCH64_PSTATE_N   (1LL << 31)
#define AARCH64_PSTATE_Z   (1LL << 30)
#define AARCH64_PSTATE_C   (1LL << 29)
#define AARCH64_PSTATE_V   (1LL << 28)
#define AARCH64_PSTATE_D   (1LL << 9)
#define AARCH64_PSTATE_A   (1LL << 8)
#define AARCH64_PSTATE_I   (1LL << 7)
#define AARCH64_PSTATE_F   (1LL << 6)
ARM AArch64 Architecture Support.
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _destination)
Value:
do { \
*(*(_destination)) = _CPU_Null_fp_context; \
} while (0)
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _isr_cookie)
Value:
do { \
_isr_cookie = AArch64_interrupt_disable(); \
} while (0)
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
◆ _CPU_Initialize()
void _CPU_Initialize ( void  )
CPU initialization.
CPU initialization.
◆ _CPU_ISR_Set_level()
void _CPU_ISR_Set_level ( uint32_t  level)
Parameters
[in]levelfor or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15.
See also
OpenRISC architecture manual.
