RTEMS 6.1-rc4
The set of registers that specifies the complete processor state. More...
#include <cpu.h>
uint64_t register_x0
uint64_t register_x1
uint64_t register_x2
uint64_t register_x3
uint64_t register_x4
uint64_t register_x5
uint64_t register_x6
uint64_t register_x7
uint64_t register_x8
uint64_t register_x9
uint64_t register_x10
uint64_t register_x11
uint64_t register_x12
uint64_t register_x13
uint64_t register_x14
uint64_t register_x15
uint64_t register_x16
uint64_t register_x17
uint64_t register_x18
uint64_t register_x19
uint64_t register_x20
uint64_t register_x21
uint64_t register_x22
uint64_t register_x23
uint64_t register_x24
uint64_t register_x25
uint64_t register_x26
uint64_t register_x27
uint64_t register_x28
uint64_t register_fp
void * register_lr
uintptr_t register_sp
void * register_pc
uint64_t register_daif
uint64_t register_cpsr
uint64_t register_syndrome
uint64_t register_fault_address
AArch64_symbolic_exception_name vector
uint64_t reserved_for_stack_alignment
uint64_t register_fpsr
uint64_t register_fpcr
uint128_t register_q0
uint128_t register_q1
uint128_t register_q2
uint128_t register_q3
uint128_t register_q4
uint128_t register_q5
uint128_t register_q6
uint128_t register_q7
uint128_t register_q8
uint128_t register_q9
uint128_t register_q10
uint128_t register_q11
uint128_t register_q12
uint128_t register_q13
uint128_t register_q14
uint128_t register_q15
uint128_t register_q16
uint128_t register_q17
uint128_t register_q18
uint128_t register_q19
uint128_t register_q20
uint128_t register_q21
uint128_t register_q22
uint128_t register_q23
uint128_t register_q24
uint128_t register_q25
uint128_t register_q26
uint128_t register_q27
uint128_t register_q28
uint128_t register_q29
uint128_t register_q30
uint128_t register_q31
union {
   struct {
      uint32_t   register_r0
      uint32_t   register_r1
      uint32_t   register_r2
      uint32_t   register_r3
      uint32_t   register_r4
      uint32_t   register_r5
      uint32_t   register_r6
      uint32_t   register_r7
      uint32_t   register_r8
      uint32_t   register_r9
      uint32_t   register_r10
      uint32_t   register_r11
      uint32_t   register_r12
      uint32_t   register_sp
      void *   register_lr
      void *   register_pc
   uint32_t   registers [16]
const ARM_VFP_contextvfp_context
uint32_t reserved_for_stack_alignment
struct Context_Control_ssefp_ctxt
uint32_t edi
uint32_t esi
uint32_t ebp
uint32_t esp0
uint32_t ebx
uint32_t edx
uint32_t ecx
uint32_t eax
uint32_t idtIndex
uint32_t faultCode
uint32_t eip
uint32_t cs
uint32_t eflags
uint32_t vecnum
uint32_t sr
uint32_t pc
 This member contains the PC value.
uint32_t d0
uint32_t d1
uint32_t d2
uint32_t d3
uint32_t d4
uint32_t d5
uint32_t d6
uint32_t d7
uint32_t a0
uint32_t a1
uint32_t a2
uint32_t a3
uint32_t a4
uint32_t a5
uint32_t a6
uint32_t a7
uint32_t r1
uint32_t r2
uint32_t r3
uint32_t r4
uint32_t r5
uint32_t r6
uint32_t r7
uint32_t r8
uint32_t r9
uint32_t r10
uint32_t r11
uint32_t r12
uint32_t r13
uint32_t * r14
uint32_t * r15
uint32_t * r16
uint32_t * r17
uint32_t r18
uint32_t r19
uint32_t r20
uint32_t r21
uint32_t r22
uint32_t r23
uint32_t r24
uint32_t r25
uint32_t r26
uint32_t r27
uint32_t r28
uint32_t r29
uint32_t r30
uint32_t r31
uint32_t msr
uint32_t * ear
uint32_t esr
uint32_t * btr
uint32_t integer_registers [16]
uint32_t r14
uint32_t r15
uint32_t r16
uint32_t r17
uint32_t gp
uint32_t fp
uint32_t sp
uint32_t ra
uint32_t et
uint32_t ea
uint32_t status
uint32_t ienable
uint32_t ipending
uint32_t processor_state_register
double float_registers [1]
uint32_t r [32]
uint32_t epcr
uint32_t eear
uintptr_t EXC_SRR0
uintptr_t EXC_SRR1
uint32_t _EXC_number
uint32_t RESERVED_FOR_ALIGNMENT_0
uint32_t EXC_CR
uint32_t EXC_XER
uintptr_t EXC_CTR
uintptr_t EXC_LR
uintptr_t RESERVED_FOR_ALIGNMENT_1
PPC_GPR_TYPE GPR0
PPC_GPR_TYPE GPR1
PPC_GPR_TYPE GPR2
PPC_GPR_TYPE GPR3
PPC_GPR_TYPE GPR4
PPC_GPR_TYPE GPR5
PPC_GPR_TYPE GPR6
PPC_GPR_TYPE GPR7
PPC_GPR_TYPE GPR8
PPC_GPR_TYPE GPR9
PPC_GPR_TYPE GPR10
PPC_GPR_TYPE GPR11
PPC_GPR_TYPE GPR12
PPC_GPR_TYPE GPR13
PPC_GPR_TYPE GPR14
PPC_GPR_TYPE GPR15
PPC_GPR_TYPE GPR16
PPC_GPR_TYPE GPR17
PPC_GPR_TYPE GPR18
PPC_GPR_TYPE GPR19
PPC_GPR_TYPE GPR20
PPC_GPR_TYPE GPR21
PPC_GPR_TYPE GPR22
PPC_GPR_TYPE GPR23
PPC_GPR_TYPE GPR24
PPC_GPR_TYPE GPR25
PPC_GPR_TYPE GPR26
PPC_GPR_TYPE GPR27
PPC_GPR_TYPE GPR28
PPC_GPR_TYPE GPR29
PPC_GPR_TYPE GPR30
PPC_GPR_TYPE GPR31
uintptr_t RESERVED_FOR_ALIGNMENT_2
CPU_Interrupt_frame Interrupt_frame
uintptr_t mcause
uintptr_t sp
uintptr_t gp
uintptr_t tp
uintptr_t s2
uintptr_t s3
uintptr_t s4
uintptr_t s5
uintptr_t s6
uintptr_t s7
uintptr_t s8
uintptr_t s9
uintptr_t s10
uintptr_t s11
uint32_t psr
 This member contains the PSR register value.
uint32_t npc
 This member contains the nPC value.
uint32_t trap
 This member contains the trap number.
uint32_t wim
 This member contains the WIM register value.
uint32_t y
 This member contains the Y register value.
uint32_t global [8]
 This member contains the global 0..7 register values.
uint32_t output [8]
 This member contains the output 0..7 register values.
SPARC_Register_window windows [SPARC_NUMBER_OF_REGISTER_WINDOWS - 1]
 This member contains the additional register windows according to the saved WIM.
This structure contains the register set of a context which caused an unexpected trap.
The CPU exception frame may be available in fatal error conditions like for example illegal opcodes, instruction fetch errors, or data access errors.
See also
rtems_fatal(), RTEMS_FATAL_SOURCE_EXCEPTION, and rtems_exception_frame_print().
See also
The documentation for this struct was generated from the following files:
