RTEMS 6.1-rc4
This group contains the SuperCore implementation. More...
Modules | |
API Mutex Handler | |
This group contains the API Mutex Handler implementation. | |
Address Handler | |
This group contains the Address Handler implementation. | |
Assert Handler | |
This group contains the Assert Handler implementation. | |
Atomic Operations | |
This group contains the atomic operations implementation. | |
Barrier Handler | |
This group contains the Barrier Handler implementation. | |
CPU Architecture Support | |
This group contains the implementation to support a processor architecture. | |
Chain Handler | |
This group contains the Chain Handler implementation. | |
Context Handler | |
This group contains the Context Handler implementation. | |
Copyright Notice | |
This group contains the implementation to provide a copyright notice and the RTEMS version. | |
Exception Mapping Interfaces | |
This group contains the interfaces for mapping machine exceptions to signals using the fatal error handler. | |
Execute Once Support | |
This group contains the implementation to execute a routine only once. | |
Freechain Handler | |
This group contains the Freechain Handler implementation. | |
Futex Handler | |
This group contains the Futex Handler implementation. | |
Hash Handler | |
This group contains the Hash Handler implementation. | |
Heap Handler | |
This group contains the Heap Handler implementation. | |
ISR Handler | |
This group contains the ISR Handler implementation. | |
Internal Error Handler | |
This group contains the Internal Error Handler implementation. | |
MPCI Handler | |
This group contains the MPCI Handler implementation. | |
Memory Handler | |
This group contains the Memory Handler implementation. | |
Message Queue Handler | |
This group contains the Message Queue Handler implementation. | |
Multiprocessing (MP) Packet Handler | |
This group contains the Multiprocessing (MP) Packet Handler implementation. | |
Multiprocessor Resource Sharing Protocol (MrsP) | |
This group contains the implementation to support the Multiprocessor Resource Sharing Protocol (MrsP) . | |
Mutex Handler | |
This group contains the Mutex Handler implementation. | |
Object Handler | |
This group contains the Object Handler implementation. | |
Operation Status Support | |
This group contains the Operation Status Support implementation. | |
Per-CPU Information | |
This group contains the implementation of the per-CPU information. | |
Priority Bitmap | |
This group contains the implementation to support priority bitmaps. | |
Priority Handler | |
This group contains the Priority Handler implementation. | |
Processor Mask | |
This group contains the implementation to support processor masks. | |
Profiling Support | |
This group contains the implementation to support profiling. | |
Read-Write Lock | |
This group contains the Read-Write Lock implementation. | |
Red-Black Tree Handler | |
This group contains the Red-Black Tree Handler implementation. | |
SMP Barriers | |
This group contains the SMP barrier implementation. | |
SMP Locks | |
This group contains the SMP lock implementation. | |
SMP Support | |
This group contains the implementation to support SMP systems. | |
Scheduler Handler | |
This group contains the Scheduler Handler implementation. | |
Semaphore Handler | |
This group contains the Semaphore Handler implementation. | |
Stack Handler | |
This group contains the Stack Handler implementation. | |
System Lock Mutex Handler | |
This group contains the System Lock Mutex Handler implementation. | |
System Lock Mutex Support | |
The System Lock Mutex Support helps to implement directives which use data structures compatible with the data structures defined by the Newlib provided <sys/lock.h> header file. | |
System Lock Semaphore Support | |
The System Lock Semaphore Support helps to implement directives which use data structures compatible with the data structures defined by the Newlib provided <sys/lock.h> header file. | |
System State Handler | |
This group contains the System State Handler implementation. | |
Thread Handler | |
This group contains the Thread Handler implementation. | |
Thread Queue Handler | |
This group contains the Thread Queue Handler implementation. | |
Thread States | |
This group contains the implementation to support thread states. | |
Thread-Local Storage (TLS) | |
This group contains the implementation to support thread-local storage (TLS). | |
Time of Day Handler | |
This group contains the Time of Day Handler implementation. | |
Timecounter Handler | |
This group contains the Timecounter Handler implementation. | |
Timespec Helpers | |
This group contains the implementation to support operations with variables of the POSIX defined struct timespec type. | |
Timestamp Handler | |
This group contains the Timestamp Handler implementation. | |
User Extensions Handler | |
This group contains the User Extensions Handler implementation. | |
Watchdog Handler | |
This group contains the Watchdog Handler implementation. | |
Workspace Handler | |
This group contains the Workspace Handler implementation. | |
Files | |
file | basedefs.h |
This header file provides basic definitions used by the API and the implementation. | |
file | condition.c |
This source file contains the implementation of _Condition_Wait(), _Condition_Wait_timed(), _Condition_Wait_recursive(), _Condition_Wait_recursive_timed(), _Condition_Wait_recursive_timed_ticks(), _Condition_Signal(), and _Condition_Broadcast(). | |
file | configstackspacesize.c |
This source file contains the implementation of rtems_configuration_get_stack_space_size(). | |
file | debugisthreaddispatchingallowed.c |
This source file contains the implementation of _Debug_Is_thread_dispatching_allowed(). | |
file | debugunreachable.c |
This source file contains the implementation of _Debug_Unreachable(). | |
file | semaphore.c |
This source file contains the implementation of _Semaphore_Wait(), _Semaphore_Wait_timed_ticks(), _Semaphore_Try_wait(), _Semaphore_Post(), and _Semaphore_Post_binary(). | |
void * | RTEMS_DEQUALIFY_types_not_compatible (void) |
A not implemented function to trigger compile time errors with an error message. | |
The SuperCore provides services for all APIs.
