RTEMS 6.1-rc2
#include <thread.h>
Data Fields | |
Objects_Control | Object |
Thread_queue_Control | Join_queue |
Thread queue for thread join operations and multi-purpose lock. | |
States_Control | current_state |
Priority_Node | Real_priority |
The base priority of this thread in its home scheduler instance. | |
Thread_Scheduler_control | Scheduler |
Scheduler related control. | |
Thread_Wait_information | Wait |
Thread_Timer_information | Timer |
Context_Control | Registers |
This member contains the context of this thread. | |
bool | is_idle |
bool | is_preemptible |
bool | is_fp |
bool | was_created_with_inherited_scheduler |
True, if the thread was created with an inherited scheduler (PTHREAD_INHERIT_SCHED), and false otherwise. | |
Thread_CPU_budget_control | CPU_budget |
This member contains the CPU budget control used to manage the CPU budget of the thread. | |
Timestamp_Control | cpu_time_used |
This member contains the amount of CPU time consumed by this thread since it was created. | |
Timestamp_Control | cpu_time_used_at_last_reset |
This member contains the amount of CPU time consumed by this thread at the time of the last reset of the CPU usage by rtems_cpu_usage_reset(). | |
Thread_Start_information | Start |
Thread_Action_control | Post_switch_actions |
Context_Control_fp * | fp_context |
struct _reent * | libc_reent |
void * | API_Extensions [THREAD_API_LAST+1] |
Thread_Keys_information | Keys |
The POSIX Keys information. | |
Thread_Life_control | Life |
Thread life-cycle control. | |
Thread_Capture_control | Capture |
struct rtems_user_env_t * | user_environment |
Pointer to an optional thread-specific POSIX user environment. | |
struct _pthread_cleanup_context * | last_cleanup_context |
LIFO list of POSIX cleanup contexts. | |
struct User_extensions_Iterator * | last_user_extensions_iterator |
LIFO list of user extensions iterators. | |
void * | extensions [RTEMS_ZERO_LENGTH_ARRAY] |
Variable length array of user extension pointers. | |
This structure defines the Thread Control Block (TCB).
Uses a leading underscore in the structure name to allow forward declarations in standard header files provided by Newlib and GCC.
In case the second member changes (currently Join_queue), then the memset() in _Thread_Initialize() must be adjusted.
void* _Thread_Control::API_Extensions[THREAD_API_LAST+1] |
This array contains the API extension area pointers.
States_Control _Thread_Control::current_state |
This field is the current execution state of this thread.
void* _Thread_Control::extensions[RTEMS_ZERO_LENGTH_ARRAY] |
The length is defined by the application via <rtems/confdefs.h>.
Context_Control_fp* _Thread_Control::fp_context |
This field points to the floating point context for this thread. If NULL, the thread is integer only.
bool _Thread_Control::is_fp |
This field is true if the thread uses the floating point unit.
bool _Thread_Control::is_idle |
This field is true if the thread is an idle thread.
bool _Thread_Control::is_preemptible |
This field is true if the thread is preemptible.
Thread_queue_Control _Thread_Control::Join_queue |
The lock of this thread queue is used for various purposes. It protects the following fields
struct _reent* _Thread_Control::libc_reent |
This field points to the newlib reentrancy structure for this thread.
Thread_Life_control _Thread_Control::Life |
Control state changes triggered by thread restart and delete requests.
Objects_Control _Thread_Control::Object |
This field is the object management structure for each thread.
Context_Control _Thread_Control::Registers |
This member is placed directly after the end of the common block so that the structure offsets are as small as possible. This helps on instruction set architectures with a very limited range for intermediate values.
Thread_Start_information _Thread_Control::Start |
This field contains information about the starting state of this thread.
Thread_Timer_information _Thread_Control::Timer |
This field is the Watchdog used to manage thread delays and timeouts.
Thread_Wait_information _Thread_Control::Wait |
This field is the blocking information for this thread.
