RTEMS 6.1-rc2
This group contains the Object Handler implementation. More...
Modules | |
Object Handler Multiprocessing (MP) Support | |
This group contains the implementation to support the Object Handler in multiprocessing (MP) configurations. | |
Files | |
file | object.h |
This header file provides interfaces of the Object Handler which are used by the implementation and the Application Configuration. | |
file | objectdata.h |
This header file provides data structures used by the implementation and the Application Configuration to define instances of Objects_Information, _Objects_MP_Controls, and ultimately Thread_Configured_control. | |
file | objectimpl.h |
This header file provides interfaces of the Object Handler which are only used by the implementation. | |
file | objectactivecount.c |
This source file contains the implementation of _Objects_Active_count(). | |
file | objectallocate.c |
This source file contains the implementation of _Objects_Allocate(). | |
file | objectallocatenone.c |
This source file contains the implementation of _Objects_Allocate_none(). | |
file | objectallocatestatic.c |
This source file contains the implementation of _Objects_Allocate_static(). | |
file | objectallocateunlimited.c |
This source file contains the implementation of _Objects_Allocate_unlimited(). | |
file | objectapimaximumclass.c |
This source file contains the implementation of _Objects_API_maximum_class(). | |
file | objectclose.c |
This source file contains the implementation of _Objects_Close(). | |
file | objectextendinformation.c |
This source file contains the implementation of _Objects_Extend_information(). | |
file | objectfree.c |
This source file contains the implementation of _Objects_Free_unlimited(). | |
file | objectfreenothing.c |
This source file contains the implementation of _Objects_Free_nothing(). | |
file | objectfreestatic.c |
This source file contains the implementation of _Objects_Free_static(). | |
file | objectgetinfo.c |
This source file contains the implementation of _Objects_Get_information(). | |
file | objectgetinfoid.c |
This source file contains the implementation of _Objects_Get_information_id(). | |
file | objectgetlocal.c |
This source file contains the implementation of _Objects_Get(). | |
file | objectgetnameasstring.c |
This source file contains the implementation of _Objects_Name_to_string() and _Objects_Get_name_as_string(). | |
file | objectgetnext.c |
This source file contains the implementation of _Objects_Get_next(). | |
file | objectgetnoprotection.c |
This source file contains the implementation of _Objects_Get_no_protection(). | |
file | objectidtoname.c |
This source file contains the implementation of _Objects_Id_to_name(). | |
file | objectinitializeinformation.c |
This source file contains the implementation of _Objects_Initialize_information(). | |
file | objectnamespaceremove.c |
This source file contains the implementation of _Objects_Namespace_remove_string(). | |
file | objectnametoid.c |
This source file contains the implementation of _Objects_Name_to_id_u32(). | |
file | objectnametoidstring.c |
This source file contains the implementation of _Objects_Get_by_name(). | |
file | objectsetname.c |
This source file contains the implementation of _Objects_Set_name(). | |
file | objectshrinkinformation.c |
This source file contains the implementation of _Objects_Free_objects_block() and _Objects_Shrink_information(). | |
union | Objects_Name |
struct | Objects_Control |
struct | Objects_Information |
The information structure used to manage each API class of objects. More... | |
#define | OBJECTS_INDEX_START_BIT 0U |
#define | OBJECTS_NODE_START_BIT 16U |
#define | OBJECTS_API_START_BIT 24U |
#define | OBJECTS_CLASS_START_BIT 27U |
#define | OBJECTS_INDEX_MASK (Objects_Id)0x0000ffffU |
#define | OBJECTS_NODE_MASK (Objects_Id)0x00ff0000U |
#define | OBJECTS_API_MASK (Objects_Id)0x07000000U |
#define | OBJECTS_CLASS_MASK (Objects_Id)0xf8000000U |
#define | OBJECTS_INDEX_VALID_BITS (Objects_Id)0x0000ffffU |
#define | OBJECTS_NODE_VALID_BITS (Objects_Id)0x000000ffU |
#define | OBJECTS_API_VALID_BITS (Objects_Id)0x00000007U |
#define | OBJECTS_CLASS_VALID_BITS (Objects_Id)0x0000001fU |
#define | OBJECTS_UNLIMITED_OBJECTS 0x80000000U |
#define | OBJECTS_ID_INITIAL_INDEX (0) |
#define | OBJECTS_ID_FINAL_INDEX (0xffffU) |
#define | OBJECTS_APIS_LAST OBJECTS_POSIX_API |
#define | OBJECTS_ID_NONE 0 |
#define | OBJECTS_ID_OF_SELF ((Objects_Id) 0) |
#define | OBJECTS_SEARCH_ALL_NODES 0 |
#define | OBJECTS_SEARCH_OTHER_NODES 0x7FFFFFFE |
#define | OBJECTS_SEARCH_LOCAL_NODE 0x7FFFFFFF |
#define | OBJECTS_WHO_AM_I 0 |
#define | OBJECTS_ID_INITIAL(_api, _class, _node) _Objects_Build_id( (_api), (_class), (_node), OBJECTS_ID_INITIAL_INDEX ) |
#define | OBJECTS_ID_FINAL ((Objects_Id)~0) |
#define | _Objects_Build_name(_C1, _C2, _C3, _C4) |
#define | _Objects_Build_id(the_api, the_class, node, index) |
Builds an object ID from its components. | |
#define | _Objects_Is_unlimited(maximum) ( ( ( maximum ) & OBJECTS_UNLIMITED_OBJECTS ) != 0 ) |
#define | _Objects_Maximum_per_allocation(maximum) ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS)) |
#define | _Objects_Local_node ((uint16_t) 1) |
The local MPCI node number. | |
#define | OBJECTS_NO_STRING_NAME 0 |
Constant for the object information string name length to indicate that this object class has no string names. | |
#define | OBJECTS_INFORMATION_MP(name, extract) |
#define | OBJECTS_INFORMATION_DEFINE_ZERO(name, api, cls, nl) |
Statically initializes an objects information. | |
#define | OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex) |
#define | OBJECTS_INTERNAL_CLASSES_LAST OBJECTS_INTERNAL_THREADS |
#define | OBJECTS_RTEMS_CLASSES_LAST OBJECTS_RTEMS_BARRIERS |
#define | OBJECTS_POSIX_CLASSES_LAST OBJECTS_POSIX_SHMS |
#define | _Objects_Maximum_nodes 1 |
#define | OBJECTS_INDEX_MINIMUM 1U |
Typedefs | |
typedef uint32_t | Objects_Id |
typedef uint16_t | Objects_Maximum |
typedef struct Objects_Information | Objects_Information |
typedef bool(* | Objects_Name_comparators) (void *, void *, uint16_t) |
Enumerations | |
enum | Objects_APIs { OBJECTS_NO_API = 0 , OBJECTS_INTERNAL_API = 1 , OBJECTS_CLASSIC_API = 2 , OBJECTS_POSIX_API = 3 , OBJECTS_FAKE_OBJECTS_API = 7 } |
enum | Objects_Internal_API { OBJECTS_INTERNAL_NO_CLASS = 0 , OBJECTS_INTERNAL_THREADS = 1 } |
enum | Objects_Classic_API { OBJECTS_CLASSIC_NO_CLASS = 0 , OBJECTS_RTEMS_TASKS = 1 , OBJECTS_RTEMS_TIMERS , OBJECTS_RTEMS_SEMAPHORES , OBJECTS_RTEMS_MESSAGE_QUEUES , OBJECTS_RTEMS_PARTITIONS , OBJECTS_RTEMS_REGIONS , OBJECTS_RTEMS_PORTS , OBJECTS_RTEMS_PERIODS , OBJECTS_RTEMS_EXTENSIONS , OBJECTS_RTEMS_BARRIERS } |
enum | Objects_POSIX_API { OBJECTS_POSIX_NO_CLASS = 0 , OBJECTS_POSIX_THREADS = 1 , OBJECTS_POSIX_KEYS , OBJECTS_POSIX_MESSAGE_QUEUES , OBJECTS_POSIX_SEMAPHORES , OBJECTS_POSIX_TIMERS , OBJECTS_POSIX_SHMS } |
enum | Objects_Fake_objects_API { OBJECTS_FAKE_OBJECTS_NO_CLASS = 0 , OBJECTS_FAKE_OBJECTS_SCHEDULERS = 1 } |
enum | Objects_Get_by_name_error { OBJECTS_GET_BY_NAME_INVALID_NAME , OBJECTS_GET_BY_NAME_NAME_TOO_LONG , OBJECTS_GET_BY_NAME_NO_OBJECT } |
Objects_Control * | _Objects_Allocate_none (Objects_Information *information) |
Always return NULL. | |
Objects_Control * | _Objects_Allocate_static (Objects_Information *information) |
Return an inactive object or NULL. | |
Objects_Control * | _Objects_Allocate_unlimited (Objects_Information *information) |
void | _Objects_Free_static (Objects_Information *information, Objects_Control *the_object) |
Free the object. | |
void | _Objects_Free_unlimited (Objects_Information *information, Objects_Control *the_object) |
Objects_Maximum | _Objects_Extend_information (Objects_Information *information) |
Extends an object class information record. | |
void | _Objects_Free_objects_block (Objects_Information *information, Objects_Maximum block) |
Free the objects block with the specified index. | |
void | _Objects_Shrink_information (Objects_Information *information) |
Shrinks an object class information record. | |
void | _Objects_Initialize_information (Objects_Information *information) |
Initializes the specified objects information. | |
unsigned int | _Objects_API_maximum_class (uint32_t api) |
Returns highest numeric value of a valid API for the specified API. | |
Objects_Control * | _Objects_Allocate (Objects_Information *information) |
Allocates an object. | |
Status_Control | _Objects_Name_to_id_u32 (uint32_t name, uint32_t node, Objects_Id *id, const Objects_Information *information) |
Searches an object of the specified class with the specified name on the specified set of nodes. | |
Objects_Control * | _Objects_Get_by_name (const Objects_Information *information, const char *name, size_t *name_length_p, Objects_Get_by_name_error *error) |
Gets an object control block identified by its name. | |
Status_Control | _Objects_Id_to_name (Objects_Id id, Objects_Name *name) |
Returns the name associated with object id. | |
Objects_Control * | _Objects_Get (Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information) |
Maps the specified object identifier to the associated local object control block. | |
Objects_Control * | _Objects_Get_no_protection (Objects_Id id, const Objects_Information *information) |
Maps object ids to object control blocks. | |
Objects_Control * | _Objects_Get_next (Objects_Id id, const Objects_Information *information, Objects_Id *next_id_p) |
Gets the next open object after the specified object identifier. | |
Objects_Information * | _Objects_Get_information (Objects_APIs the_api, uint16_t the_class) |
Gets object information. | |
Objects_Information * | _Objects_Get_information_id (Objects_Id id) |
Gets information of an object from an ID. | |
char * | _Objects_Get_name_as_string (Objects_Id id, size_t length, char *name) |
Gets object name in the form of a C string. | |
size_t | _Objects_Name_to_string (Objects_Name name, bool is_string, char *buffer, size_t buffer_size) |
Converts the specified object name to a text representation. | |
Status_Control | _Objects_Set_name (const Objects_Information *information, Objects_Control *the_object, const char *name) |
Sets objects name. | |
void | _Objects_Namespace_remove_string (const Objects_Information *information, Objects_Control *the_object) |
Removes object with a string name from its namespace. | |
void | _Objects_Close (const Objects_Information *information, Objects_Control *the_object) |
Closes object. | |
Objects_Maximum | _Objects_Active_count (const Objects_Information *information) |
Returns the count of active objects. | |
void | _Objects_Free_nothing (void *ptr) |
This function does nothing. | |
Objects_Information **const | _Objects_Information_table [OBJECTS_APIS_LAST+1] |
This handler provides mechanisms which can be used to initialize and manipulate all objects which have identifiers.
#define _Objects_Build_id | ( | the_api, | |
the_class, | |||
node, | |||
index | |||
the_api | The object API. |
the_class | The object API class. |
node | The object node. |
index | The object index. |
#define _Objects_Build_name | ( | _C1, | |
_C2, | |||
_C3, | |||
_C4 | |||
This macro is used to build a thirty-two bit style name from four characters. The most significant byte will be the character _C1.
[in] | _C1 | is the first character of the name |
[in] | _C2 | is the second character of the name |
[in] | _C3 | is the third character of the name |
[in] | _C4 | is the fourth character of the name |
#define _Objects_Is_unlimited | ( | maximum | ) | ( ( ( maximum ) & OBJECTS_UNLIMITED_OBJECTS ) != 0 ) |
Returns if the object maximum specifies unlimited objects.
[in] | maximum | The object maximum specification. |
true | Unlimited objects are available. |
false | The object count is fixed. |
#define _Objects_Maximum_nodes 1 |
The following is referenced to the number of nodes in the system.
#define OBJECTS_API_MASK (Objects_Id)0x07000000U |
This mask is used to extract the API portion of an object Id.
#define OBJECTS_API_START_BIT 24U |
This is the bit position of the starting bit of the API portion of the object Id.
#define OBJECTS_API_VALID_BITS (Objects_Id)0x00000007U |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the API portion of an object Id.
#define OBJECTS_APIS_LAST OBJECTS_POSIX_API |
This macro is used to generically specify the last API index.
#define OBJECTS_CLASS_MASK (Objects_Id)0xf8000000U |
This mask is used to extract the class portion of an object Id.
#define OBJECTS_CLASS_START_BIT 27U |
This is the bit position of the starting bit of the class portion of the object Id.
#define OBJECTS_CLASS_VALID_BITS (Objects_Id)0x0000001fU |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the class portion of an object Id.
#define OBJECTS_ID_FINAL ((Objects_Id)~0) |
This macro specifies the highest object ID value
#define OBJECTS_ID_FINAL_INDEX (0xffffU) |
This is the highest value for the index portion of an object Id.
#define OBJECTS_ID_INITIAL | ( | _api, | |
_class, | |||
_node | |||
) | _Objects_Build_id( (_api), (_class), (_node), OBJECTS_ID_INITIAL_INDEX ) |
This macros calculates the lowest ID for the specified api, class, and node.
#define OBJECTS_ID_INITIAL_INDEX (0) |
This is the lowest value for the index portion of an object Id.
#define OBJECTS_ID_NONE 0 |
No object can have this ID.
#define OBJECTS_ID_OF_SELF ((Objects_Id) 0) |
The following defines the constant which may be used to manipulate the calling task.
#define OBJECTS_INDEX_MASK (Objects_Id)0x0000ffffU |
This mask is used to extract the index portion of an object Id.
#define OBJECTS_INDEX_MINIMUM 1U |
This is the minimum object ID index associated with an object.
#define OBJECTS_INDEX_START_BIT 0U |
This is the bit position of the starting bit of the index portion of the object Id.
#define OBJECTS_INDEX_VALID_BITS (Objects_Id)0x0000ffffU |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the index portion of an object Id.
#define OBJECTS_INFORMATION_DEFINE | ( | name, | |
api, | |||
cls, | |||
type, | |||
max, | |||
nl, | |||
ex | |||
The initialized objects information references a table with statically allocated objects as specified by the object maximum parameter. These objects must be registered via a call to _Objects_Information().
name | The object class C designator namespace prefix, e.g. _Semaphore. |
api | The object API number, e.g. OBJECTS_CLASSIC_API. |
cls | The object class number, e.g. OBJECTS_RTEMS_SEMAPHORES. |
type | The object class type. |
max | The configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set). |
nl | The object name string length, use OBJECTS_NO_STRING_NAME for objects without a string name. |
ex | The optional object extraction method. Used only if multiprocessing (RTEMS_MULTIPROCESSING) is enabled. |
#define OBJECTS_INFORMATION_DEFINE_ZERO | ( | name, | |
api, | |||
cls, | |||
nl | |||
The initialized objects information contains no objects.
#define OBJECTS_INTERNAL_CLASSES_LAST OBJECTS_INTERNAL_THREADS |
#define OBJECTS_NODE_MASK (Objects_Id)0x00ff0000U |
This mask is used to extract the node portion of an object Id.
#define OBJECTS_NODE_START_BIT 16U |
This is the bit position of the starting bit of the node portion of the object Id.
#define OBJECTS_NODE_VALID_BITS (Objects_Id)0x000000ffU |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the node portion of an object Id.
#define OBJECTS_POSIX_CLASSES_LAST OBJECTS_POSIX_SHMS |
#define OBJECTS_RTEMS_CLASSES_LAST OBJECTS_RTEMS_BARRIERS |
#define OBJECTS_SEARCH_ALL_NODES 0 |
The following constant is used to specify that a name to ID search should search through all nodes.
#define OBJECTS_SEARCH_LOCAL_NODE 0x7FFFFFFF |
The following constant is used to specify that a name to ID search should search only on this node.
#define OBJECTS_SEARCH_OTHER_NODES 0x7FFFFFFE |
The following constant is used to specify that a name to ID search should search through all nodes except the current node.
#define OBJECTS_UNLIMITED_OBJECTS 0x80000000U |
Mask to enable unlimited objects. This is used in the configuration table when specifying the number of configured objects.
#define OBJECTS_WHO_AM_I 0 |
The following constant is used to specify that a name to ID search is being asked for the ID of the currently executing task.
typedef uint32_t Objects_Id |
The following type defines the control block used to manage object IDs. The format is as follows (0=LSB):
Bits 0 .. 15 = index (up to 65535 objects of a type) Bits 16 .. 23 = node (up to 255 nodes) Bits 24 .. 26 = API (up to 7 API classes) Bits 27 .. 31 = class (up to 31 object types per API)
typedef uint16_t Objects_Maximum |
This type is used to store the maximum number of allowed objects of each type.
typedef bool(* Objects_Name_comparators) (void *, void *, uint16_t) |
Functions which compare names are prototyped like this.
enum Objects_APIs |
This enumerated type is used in the class field of the object ID.
enum Objects_Classic_API |
This enumerated type is used in the class field of the object ID for the RTEMS Classic API.
enum Objects_Internal_API |
This enumerated type is used in the class field of the object ID for RTEMS internal object classes.
enum Objects_POSIX_API |
This enumerated type is used in the class field of the object ID for the POSIX API.
Objects_Maximum _Objects_Active_count | ( | const Objects_Information * | information | ) |
information | The object information table. |
Objects_Control * _Objects_Allocate | ( | Objects_Information * | information | ) |
This function locks the object allocator mutex via _Objects_Allocator_lock(). The caller must later unlock the object allocator mutex via _Objects_Allocator_unlock(). The caller must unlock the mutex in any case, even if the allocation failed due to resource shortage.
A typical object allocation code looks like this:
[in,out] | information | The object information block. |
object | The allocated object. |
NULL | No object available. |
Objects_Control * _Objects_Allocate_none | ( | Objects_Information * | information | ) |
Always return NULL.
information | The objects information. |
NULL | Always. |
Objects_Control * _Objects_Allocate_static | ( | Objects_Information * | information | ) |
NULL | No inactive object is available. |
object | An inactive object. |
Objects_Control * _Objects_Allocate_unlimited | ( | Objects_Information * | information | ) |
Try to extend the objects information if necessary.
unsigned int _Objects_API_maximum_class | ( | uint32_t | api | ) |
This function returns the highest numeric value of a valid API for the specified api.
api | The API of interest. |
some_value | Positive integer on success. |
0 | The method failed. |
void _Objects_Close | ( | const Objects_Information * | information, |
Objects_Control * | the_object | ||
Closes object.
This function removes the_object control pointer and object name in the Local Pointer and Local Name Tables.
information | Points to an Object Information Table. | |
[out] | the_object | A pointer to an object. |
Objects_Maximum _Objects_Extend_information | ( | Objects_Information * | information | ) |
information | Points to an object class information block. |
0 | The extend operation failed. |
block | The block index of the new objects block. |
void _Objects_Free_nothing | ( | void * | ptr | ) |
ptr | is not used. |
void _Objects_Free_objects_block | ( | Objects_Information * | information, |
Objects_Maximum | block | ||
block | The block index. |
void _Objects_Free_static | ( | Objects_Information * | information, |
Free the object.
Append the object to the inactive chain of the objects information.
the_object | The object to free. |
void _Objects_Free_unlimited | ( | Objects_Information * | information, |
Free the object.
Append the object to the inactive chain of the objects information and shrink the objects information if necessary.
Objects_Control * _Objects_Get | ( | Objects_Id | id, |
ISR_lock_Context * | lock_context, | ||
const Objects_Information * | information | ||
In this function interrupts are disabled during the object lookup. In case an associated object exists, then interrupts remain disabled, otherwise the previous interrupt state is restored.
id | The object identifier. This is the first parameter since usual callers get the object identifier as the first parameter themself. |
lock_context | The interrupt lock context. This is the second parameter since usual callers get the interrupt lock context as the second parameter themself. |
information | The object class information block. |
pointer | The pointer to the associated object control block. Interrupts are now disabled and must be restored using the specified lock context via _ISR_lock_ISR_enable() or _ISR_lock_Release_and_ISR_enable(). |
NULL | No associated object exists. |
Objects_Control * _Objects_Get_by_name | ( | const Objects_Information * | information, |
const char * | name, | ||
size_t * | name_length_p, | ||
Objects_Get_by_name_error * | error | ||
The object information must use string names.
information | The object information. Must not be NULL. | |
name | The object name. | |
[out] | name_length_p | Optional parameter to return the name length. |
[out] | error | The error indication in case of failure. Must not be NULL. |
pointer | The first object according to object index associated with this name. |
NULL | No object exists for this name or invalid parameters. |
Objects_Information * _Objects_Get_information | ( | Objects_APIs | the_api, |
uint16_t | the_class | ||
This function returns the information structure given an API and Class. This can be done independent of the existence of any objects created by the API.
the_api | Indicates the API for the information we want |
the_class | Indicates the Class for the information we want |
pointer | Pointer to the Object Information Table for the class of objects which corresponds to this object ID. |
NULL | An error occurred. |
Objects_Information * _Objects_Get_information_id | ( | Objects_Id | id | ) |
This function returns the information structure given an id of an object.
id | The object ID to get the information from. |
char * _Objects_Get_name_as_string | ( | Objects_Id | id, |
size_t | length, | ||
char * | name | ||
This method gets the name of an object and returns its name in the form of a C string. It attempts to be careful about overflowing the user's string and about returning unprintable characters.
id | The object to obtain the name of. | |
length | Indicates the length of the caller's buffer. | |
[out] | name | A string which will be filled in. |
a name The operation was succeeded and the string was correctly filled in.
Objects_Control * _Objects_Get_next | ( | Objects_Id | id, |
const Objects_Information * | information, | ||
Objects_Id * | next_id_p | ||
Locks the object allocator mutex in case a next object exists.
id | The Id of the object whose name we are locating. This is the first parameter since usual callers get the object identifier as the first parameter themself. | |
information | Points to an object class information block. | |
[in,out] | next_id_p | The Id of the next object we will look at. |
pointer | Pointer to the located object. |
Objects_Control * _Objects_Get_no_protection | ( | Objects_Id | id, |
This function maps object ids to object control blocks. If id corresponds to a local object, then it returns the_object control pointer which maps to id and location is set to OBJECTS_LOCAL. If the object class supports global objects and the object id is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_object is undefined. Otherwise, location is set to OBJECTS_ERROR and the_object is undefined.
pointer | The local object corresponding to the given id. |
NULL | The object to the given id was not found locally. |
Status_Control _Objects_Id_to_name | ( | Objects_Id | id, |
Objects_Name * | name | ||
This function implements the common portion of the object Id to name directives. This function returns the name associated with object id.
id | is the Id of the object whose name we are locating. | |
[out] | name | will contain the name of the object, if found. |
STATUS_SUCCESSFUL | The operation succeeded. name contains the name of the object. |
STATUS_INVALID_ID | The id is invalid, the operation failed. |
void _Objects_Initialize_information | ( | Objects_Information * | information | ) |
The objects information must be statically pre-initialized with the OBJECTS_INFORMATION_DEFINE() macro before this function is called.
information | The object information to be initialized. |
Status_Control _Objects_Name_to_id_u32 | ( | uint32_t | name, |
uint32_t | node, | ||
Objects_Id * | id, | ||
This method converts an object name to an identifier. It performs a look up using the object information block for this object class.
name | is the name of the object to find. | |
node | is the set of nodes to search. | |
[out] | id | is the pointer to an object identifier variable or NULL. The object identifier will be stored in the referenced variable, if the operation was successful. |
information | is the pointer to an object class information block. |
STATUS_SUCCESSFUL | The operations was successful. |
STATUS_INVALID_ADDRESS | The id parameter was NULL. |
STATUS_INVALID_NAME | No object exists with the specified name on the specified node set. |
size_t _Objects_Name_to_string | ( | Objects_Name | name, |
bool | is_string, | ||
char * | buffer, | ||
size_t | buffer_size | ||
Non-printable characters according to isprint() are converted to '*'.
is_string | Indicates if the object name is a string or a four character array (32-bit unsigned integer). | |
[out] | buffer | The string buffer for the text representation. |
buffer_size | The buffer size in characters. |
void _Objects_Namespace_remove_string | ( | const Objects_Information * | information, |
information | The corresponding object information table. | |
[out] | the_object | The object the object to operate upon. |
Status_Control _Objects_Set_name | ( | const Objects_Information * | information, |
Objects_Control * | the_object, | ||
const char * | name | ||
Sets objects name.
This method sets the object name to either a copy of a string or up to the first four characters of the string based upon whether this object class uses strings for names.
information | points to the object information. | |
[out] | the_object | is the object to operate upon. |
name | is a pointer to the name to use. |
STATUS_SUCCESSFUL | The operation succeeded. |
STATUS_NO_MEMORY | There was no memory available to duplicate the name. |
void _Objects_Shrink_information | ( | Objects_Information * | information | ) |
This function shrinks an object class information record. The object's name and object space are released. The local_table etc block does not shrink. The InActive list needs to be scanned to find the objects are remove them.
extern |
The following is the list of information blocks per API for each object class. From the ID, we can go to one of these information blocks, and obtain a pointer to the appropriate object control block.
