RTEMS 6.1-rc2
This group contains the RTEMS implementation components. More...
Modules | |
Application Configuration | |
The application configuration defines system parameters according to configuration options (defines) provided by the application. | |
Base64 Encoding and Decoding | |
This group contains support functions for base64 and base64url encoding and decoding. | |
Build Options | |
This group contains files generated by the build system. | |
CPU Usage Reporting | |
This group contains the implementation of CPU Usage Reporting. | |
Classic API | |
This group contains the Classic API implementation. | |
Cyclic Redundancy Check (CRC) Support | |
This group contains functions to calculate Cyclic Redundancy Check (CRC) values. | |
Doxygen Support | |
FreeBSD Kernel Space Support | |
This group contains the interfaces used by FreeBSD kernel space components ported to RTEMS. | |
GNAT/RTEMS interrupts and exception handling | |
Hash Algorithms | |
This group contains items related to the implementation of hash algorithms. | |
IO Library | |
Provides system call and file system interface definitions. | |
POSIX API | |
This group contains definitions and modules which are used to implement the POSIX APIs supported by RTEMS. | |
RTEMS Test Framework Implementation | |
Implementation details. | |
Standard C Library Support | |
RTEMS Specific Support for the Standard C Library. | |
SuperCore | |
This group contains the SuperCore implementation. | |
Files | |
file | cpucounterconverter.c |
This source file contains a implementation of the counter value conversion functions. | |
#define | _RTEMS_SYSINIT_INDEX_ITEM(handler, index) |
Creates the system initialization item associated with the handler and index. | |
#define | _RTEMS_SYSINIT_ITEM(handler, module, order) _RTEMS_SYSINIT_INDEX_ITEM( handler, 0x##module##order ) |
Creates the system initialization item associated with the handler, module, and order. | |
void | _Sysinit_Verbose (void) |
Enables a verbose system initialization. | |
#define _RTEMS_SYSINIT_INDEX_ITEM | ( | handler, | |
index | |||
The enum helps to detect typos in the module and order parameters of RTEMS_SYSINIT_ITEM().
#define _RTEMS_SYSINIT_ITEM | ( | handler, | |
module, | |||
order | |||
) | _RTEMS_SYSINIT_INDEX_ITEM( handler, 0x##module##order ) |
This helper macro is used to perform parameter expansion in RTEMS_SYSINIT_ITEM().
