RTEMS 6.1-rc2
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
threadqimpl.h File Reference
This header file provides interfaces of the Thread Queue Handler which are only used by the implementation. More...
#include <rtems/score/threadq.h>
#include <rtems/score/priorityimpl.h>
#include <rtems/score/smp.h>
#include <rtems/score/status.h>
struct  Thread_queue_Syslock_queue
 Thread queue with a layout compatible to struct _Thread_queue_Queue defined in Newlib <sys/lock.h>. More...
struct  Thread_queue_Object
 Helper structure to ensure that all objects containing a thread queue have the right layout. More...
#define THREAD_QUEUE_LINK_OF_PATH_NODE(node)    RTEMS_CONTAINER_OF( node, Thread_queue_Link, Path_node );
#define _Thread_queue_Context_ISR_disable(queue_context, level)
#define _Thread_queue_Context_set_MP_callout(queue_context, mp_callout)
 Sets the MP callout in the thread queue context.
#define _Thread_queue_Queue_acquire_critical(queue, lock_stats, lock_context)    _Thread_queue_Queue_do_acquire_critical( queue, lock_context )
#define THREAD_QUEUE_INITIALIZER(_name)
#define THREAD_QUEUE_OBJECT_ASSERT(object_type, wait_queue_member, msg)
#define THREAD_QUEUE_QUEUE_TO_OBJECT(queue)
typedef Thread_Control *(* Thread_queue_Flush_filter) (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Thread queue flush filter function.
enum  Thread_queue_Deadlock_status { THREAD_QUEUE_NO_DEADLOCK , THREAD_QUEUE_DEADLOCK_DETECTED }
 This is a status code to indicate if a deadlock was detected or not. More...
void _Thread_queue_Enqueue_do_nothing_extra (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Does nothing.
void _Thread_queue_Add_timeout_ticks (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Adds timeout ticks of the queue to the thread.
void _Thread_queue_Add_timeout_monotonic_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Adds a monotonic timespec to the thread and sets the watchdog header to monotonic.
void _Thread_queue_Add_timeout_realtime_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Adds a monotonic timespec to the thread and sets the watchdog header to realtime.
void _Thread_queue_Deadlock_status (Thread_Control *the_thread)
 Sets the thread wait return code to STATUS_DEADLOCK.
void _Thread_queue_Deadlock_fatal (Thread_Control *the_thread)
 Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error.
size_t _Thread_queue_Queue_get_name_and_id (const Thread_queue_Queue *queue, char *buffer, size_t buffer_size, Objects_Id *id)
 Copies the thread queue name to the specified buffer.
void _Thread_queue_Enqueue (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Blocks the thread and places it on the thread queue.
bool _Thread_queue_Extract_locked (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Extracts the thread from the thread queue, restores the default wait operations and restores the default thread lock.
void _Thread_queue_Resume (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Resumes the extracted or surrendered thread.
void _Thread_queue_Extract (Thread_Control *the_thread)
 Extracts thread from thread queue.
void _Thread_queue_Surrender (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
 Surrenders the thread queue previously owned by the thread to the first enqueued thread.
void _Thread_queue_Surrender_no_priority (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
Status_Control _Thread_queue_Surrender_priority_ceiling (Thread_queue_Queue *queue, Thread_Control *executing, Priority_Node *ceiling_priority, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
Thread_Control_Thread_queue_First (Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations)
 Returns the first thread on the thread queue if it exists, otherwise NULL.
Thread_Control_Thread_queue_Flush_default_filter (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Default thread queue flush filter function.
Thread_Control_Thread_queue_Flush_status_unavailable (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Status unavailable thread queue flush filter function.
Thread_Control_Thread_queue_Flush_status_object_was_deleted (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Status object was deleted thread queue flush filter function.
size_t _Thread_queue_Flush_critical (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context)
 Unblocks all threads enqueued on the thread queue.
void _Thread_queue_Initialize (Thread_queue_Control *the_thread_queue, const char *name)
 Initializes the thread queue control to the given name.
void _Thread_queue_Object_initialize (Thread_queue_Control *the_thread_queue)
 Initializes a thread queue embedded in an object with identifier.
const Thread_queue_Operations _Thread_queue_Operations_default
 The default thread queue operations are used when a thread is not enqueued on a thread queue.
const Thread_queue_Operations _Thread_queue_Operations_FIFO
 The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide FIFO ordering of enqueued threads.
const Thread_queue_Operations _Thread_queue_Operations_priority
 The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads.
const Thread_queue_Operations _Thread_queue_Operations_priority_inherit
 The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads with support for priority inheritance.
const char _Thread_queue_Object_name []
 The special thread queue name to indicated that the thread queue is embedded in an object with identifier.
