RTEMS 6.1-rc2
This group contains the DSU4 interfaces. More...
Modules | |
AHB trace buffer break address registers (ATBBA) | |
This group contains register bit definitions. | |
AHB trace buffer break mask registers (ATBBM) | |
AHB trace buffer control register (ATBC) | |
AHB trace buffer filter control register (ATBFC) | |
AHB trace buffer filter mask register (ATBFM) | |
AHB trace buffer index register (ATBI) | |
AHB watchpoint control register (AHBWPC) | |
AHB watchpoint data registers (AHBWPD) | |
AHB watchpoint mask registers (AHBWPM) | |
DSU ASI diagnostic access register (DASI) | |
DSU break and single step register (BRSS) | |
DSU control register (CTRL) | |
DSU debug mode mask register (DBGM) | |
DSU time tag counter register (DTTC) | |
DSU trap register (DTR) | |
Instruction trace buffer control register 0 (ITBC0) | |
Instruction trace buffer control register 1 (ITBC1) | |
Instruction trace count register (ICNT) | |
Files | |
file | dsu4-regs.h |
This header file defines the DSU4 register block interface. | |
struct | dsu4 |
This structure defines the DSU4 register block memory map. More... | |
Typedefs | |
typedef struct dsu4 | dsu4 |
This structure defines the DSU4 register block memory map. | |
