RTEMS 6.3
Thread_Configuration Struct Reference
The configuration of a new thread to initialize. More...
#include <threadimpl.h>
const struct _Scheduler_Control * scheduler
 The scheduler control instance for the thread.
void * stack_area
 The starting address of the stack area.
size_t stack_size
 The size of the stack area in bytes.
void(*) stack_free (void *)
 This member contains the handler to free the stack.
Priority_Control priority
 The new thread's priority.
const Thread_CPU_budget_operations * cpu_budget_operations
 The thread's initial CPU budget operations.
uint32_t name
 32-bit unsigned integer name of the object for the thread.
uint32_t isr_level
 The thread's initial ISR level.
bool is_fp
 Indicates whether the thread needs a floating-point area.
bool is_preemptible
 Indicates whether the new thread is preemptible.
Field Documentation
◆ stack_free
void(*) Thread_Configuration::stack_free(void *)
It shall not be NULL. Use _Objects_Free_nothing() if nothing is to free.
