RTEMS 6.3
Thread_Wait_information Struct Reference
Information required to manage a thread while it is blocked. More...
#include <thread.h>
uint32_t count
void * return_argument
Thread_Wait_information_Object_argument_type return_argument_second
uint32_t option
uint32_t return_code
Thread_Wait_flags flags
 This field contains several flags used to control the wait class and state of a thread in case fine-grained locking is used.
Thread_queue_Queue * queue
 The current thread queue.
const Thread_queue_Operations * operations
 The current thread queue operations.
Thread_queue_Heads * spare_heads
This contains the information required to manage a thread while it is blocked and to return information to it.
Field Documentation
◆ count
uint32_t Thread_Wait_information::count
This field is used to return an integer while when blocked.
◆ operations
const Thread_queue_Operations* Thread_Wait_information::operations
This field is protected by the thread lock wait default lock.
See also
_Thread_Wait_claim().
◆ option
uint32_t Thread_Wait_information::option
This field contains any options in effect on this blocking operation.
◆ queue
Thread_queue_Queue* Thread_Wait_information::queue
If this field is NULL the thread is not enqueued on a thread queue. This field is protected by the thread wait default lock.
See also
◆ return_argument
void* Thread_Wait_information::return_argument
This field is for a pointer to a user return argument.
◆ return_argument_second
Thread_Wait_information_Object_argument_type Thread_Wait_information::return_argument_second
This field is for a pointer to a second user return argument.
◆ return_code
uint32_t Thread_Wait_information::return_code
This field will contain the return status from a blocking operation.
Note
The following assumes that all API return codes can be treated as an uint32_t.
