RTEMS  5.1
objectdata.h
1
9 /*
10  * COPYRIGHT (c) 1989-2011.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _RTEMS_SCORE_OBJECTDATA_H
19 #define _RTEMS_SCORE_OBJECTDATA_H
20
21 #include <rtems/score/object.h>
22 #include <rtems/score/chainimpl.h>
23 #include <rtems/score/rbtree.h>
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
39 typedef struct {
47
52 typedef enum {
53  OBJECTS_INTERNAL_NO_CLASS = 0,
54
55  /* Must be one, see __Thread_Get_objects_information() */
56  OBJECTS_INTERNAL_THREADS = 1
58
63 typedef enum {
64  OBJECTS_CLASSIC_NO_CLASS = 0,
65
66  /* Must be one, see __Thread_Get_objects_information() */
67  OBJECTS_RTEMS_TASKS = 1,
68
69  OBJECTS_RTEMS_TIMERS,
70  OBJECTS_RTEMS_SEMAPHORES,
71  OBJECTS_RTEMS_MESSAGE_QUEUES,
72  OBJECTS_RTEMS_PARTITIONS,
73  OBJECTS_RTEMS_REGIONS,
74  OBJECTS_RTEMS_PORTS,
75  OBJECTS_RTEMS_PERIODS,
76  OBJECTS_RTEMS_EXTENSIONS,
77  OBJECTS_RTEMS_BARRIERS
79
84 typedef enum {
85  OBJECTS_POSIX_NO_CLASS = 0,
86
87  /* Must be one, see __Thread_Get_objects_information() */
88  OBJECTS_POSIX_THREADS = 1,
89
90  OBJECTS_POSIX_KEYS,
91  OBJECTS_POSIX_MESSAGE_QUEUES,
92  OBJECTS_POSIX_SEMAPHORES,
93  OBJECTS_POSIX_TIMERS,
94  OBJECTS_POSIX_SHMS
96
101 #define OBJECTS_NO_STRING_NAME 0
102
103 #if defined( RTEMS_MULTIPROCESSING )
104 struct _Thread_Control;
105
110 typedef struct {
114  union {
118  Chain_Node Inactive;
119
120  struct {
124  RBTree_Node Id_lookup;
125
129  RBTree_Node Name_lookup;
130  } Active;
131  } Nodes;
132
136  Objects_Id id;
137
144  uint32_t name;
145 } Objects_MP_Control;
146
152 extern Objects_MP_Control _Objects_MP_Controls[];
153
159 typedef void ( *Objects_Thread_queue_Extract_callout )(
160  struct _Thread_Control *,
161  Objects_Id
162 );
163 #endif
164
166
186
196
204
214
223
232
238  uint16_t object_size;
239
247  uint16_t name_length;
248
257
265
273
283
284 #if defined(RTEMS_MULTIPROCESSING)
285
290  Objects_Thread_queue_Extract_callout extract;
291
298  RBTree_Control Global_by_id;
299
309  RBTree_Control Global_by_name;
310 #endif
311 };
312
321
331
343
353  Objects_Information *information,
354  Objects_Control *the_object
355 );
356
367  Objects_Information *information,
368  Objects_Control *the_object
369 );
370
371 #if defined(RTEMS_MULTIPROCESSING)
372 #define OBJECTS_INFORMATION_MP( name, extract ) \
373  , \
374  extract, \
375  RBTREE_INITIALIZER_EMPTY( name.Global_by_id ), \
376  RBTREE_INITIALIZER_EMPTY( name.Global_by_name )
377 #else
378 #define OBJECTS_INFORMATION_MP( name, extract )
379 #endif
380
392 #define OBJECTS_INFORMATION_DEFINE_ZERO( name, api, cls, nl ) \
393 Objects_Information name##_Information = { \
394  _Objects_Build_id( api, cls, 1, 0 ), \
395  NULL, \
396  _Objects_Allocate_none, \
397  NULL, \
398  0, \
399  0, \
400  0, \
401  nl, \
402  CHAIN_INITIALIZER_EMPTY( name##_Information.Inactive ), \
403  NULL, \
404  NULL, \
405  NULL \
406  OBJECTS_INFORMATION_MP( name##_Information, NULL ) \
407 }
408
427 #define OBJECTS_INFORMATION_DEFINE( name, api, cls, type, max, nl, ex ) \
428 static Objects_Control * \
429 name##_Local_table[ _Objects_Maximum_per_allocation( max ) ]; \
430 static type name##_Objects[ _Objects_Maximum_per_allocation( max ) ]; \
431 Objects_Information name##_Information = { \
432  _Objects_Build_id( api, cls, 1, _Objects_Maximum_per_allocation( max ) ), \
433  name##_Local_table, \
434  _Objects_Is_unlimited( max ) ? \
435  _Objects_Allocate_unlimited : _Objects_Allocate_static, \
436  _Objects_Is_unlimited( max ) ? \
437  _Objects_Free_unlimited : _Objects_Free_static, \
438  0, \
439  _Objects_Is_unlimited( max ) ? _Objects_Maximum_per_allocation( max ) : 0, \
440  sizeof( type ), \
441  nl, \
442  CHAIN_INITIALIZER_EMPTY( name##_Information.Inactive ), \
443  NULL, \
444  NULL, \
445  &name##_Objects[ 0 ].Object \
446  OBJECTS_INFORMATION_MP( name##_Information, ex ) \
447 }
448
451 #ifdef __cplusplus
452 }
453 #endif
454
455 #endif
456 /* end of include file */
Definition: chain.h:68
Definition: objectdata.h:39
void _Objects_Free_unlimited(Objects_Information *information, Objects_Control *the_object)
Free the object.
Definition: objectfree.c:24
Chain_Control Inactive
This is the chain of inactive object control blocks.
Definition: objectdata.h:256
Constants and Structures Associated with the Object Handler.
Objects_Internal_API
Definition: objectdata.h:52
uint16_t Objects_Maximum
Definition: object.h:86
Objects_Maximum * inactive_per_block
This is the number of inactive object control blocks per allocation block.
Definition: objectdata.h:264
Definition: chain.h:86
Objects_Maximum inactive
This is the number of object control blocks on the inactive chain.
Definition: objectdata.h:222
Red-black tree node.
Definition: rbtree.h:55
Objects_Control * initial_objects
This points to the object control blocks initially available.
Definition: objectdata.h:282
void(* deallocate)(Objects_Information *, Objects_Control *)
Free an object.
Definition: objectdata.h:213
Objects_Classic_API
Definition: objectdata.h:63
Objects_Control * _Objects_Allocate_unlimited(Objects_Information *information)
Return an inactive object or NULL.
Definition: objectallocateunlimited.c:46
Objects_Id maximum_id
This is the maximum valid ID of this object API class.
Definition: objectdata.h:185
void _Objects_Free_static(Objects_Information *information, Objects_Control *the_object)
Free the object.
Definition: objectfreestatic.c:41
Objects_Control ** local_table
This points to the table of local object control blocks.
Definition: objectdata.h:195
Definition: thread.h:732
Chain_Node Node
Definition: objectdata.h:41
Objects_POSIX_API
Definition: objectdata.h:84
Constants and Structures Associated with the Red-Black Tree Handler.
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
Chain Handler API.
This is the maximum length of names.
Definition: objectdata.h:247
Objects_Control * _Objects_Allocate_none(Objects_Information *information)
Always return NULL.
Definition: objectallocatenone.c:40
uint32_t Objects_Id
Definition: object.h:80
Objects_Name name
Definition: objectdata.h:45
Objects_Maximum objects_per_block
This is the number of object control blocks in an allocation block.
Definition: objectdata.h:231
Definition: object.h:64
Objects_Control ** object_blocks
This is a table to allocation blocks of object control blocks.
Definition: objectdata.h:272
Objects_Control * _Objects_Allocate_static(Objects_Information *information)
Definition: objectallocatestatic.c:41
This is the size in bytes of each object control block.
Definition: objectdata.h:238
Objects_Id id
Definition: objectdata.h:43
