RTEMS
5.1
Data Associated with the Manipulation of Global RTEMS Objects. More...
void | _Objects_MP_Handler_initialization (void) |
Intializes the inactive global object chain based on the maximum number of global objects configured. More... | |
void | _Objects_MP_Handler_early_initialization (void) |
Intializes the global object node number used in the ID field of all objects. More... | |
void | _Objects_MP_Open (Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id) |
Place the specified global object in the specified information table. More... | |
bool | _Objects_MP_Allocate_and_open (Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error) |
Allocates a global object control block and places it in the specified information table. More... | |
void | _Objects_MP_Close (Objects_Information *information, Objects_Id the_id) |
Removes a global object from the specified information table. More... | |
Objects_Name_or_id_lookup_errors | _Objects_MP_Global_name_search (Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id) |
Looks for the object with the_name in the global object tables indicated by information. More... | |
bool | _Objects_MP_Is_remote (Objects_Id id, const Objects_Information *information) |
Checks if the object identifier is in the global object identifier cache of the specified object information. More... | |
Objects_MP_Control * | _Objects_MP_Allocate_global_object (void) |
This function allocates a Global Object control block. | |
void | _Objects_MP_Free_global_object (Objects_MP_Control *the_object) |
This routine deallocates a Global Object control block. More... | |
RTEMS_INLINE_ROUTINE bool | _Objects_MP_Is_null_global_object (Objects_MP_Control *the_object) |
Checks if the global object is NULL or not. More... | |
uint32_t | _Objects_MP_Maximum_global_objects |
This include file contains all the constants and structures associated with the manipulation of Global RTEMS Objects.
