RTEMS  5.1
objectimpl.h
1
12 /*
13  * COPYRIGHT (c) 1989-2011.
14  * On-Line Applications Research Corporation (OAR).
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_SCORE_OBJECTIMPL_H
22 #define _RTEMS_SCORE_OBJECTIMPL_H
23
24 #include <rtems/score/objectdata.h>
25 #include <rtems/score/apimutex.h>
26 #include <rtems/score/assert.h>
27 #include <rtems/score/isrlock.h>
28 #include <rtems/score/sysstate.h>
30
31 #ifdef __cplusplus
32 extern "C" {
33 #endif
34
44 typedef bool (*Objects_Name_comparators)(
45  void * /* name_1 */,
46  void * /* name_2 */,
47  uint16_t /* length */
48 );
49
51 #define OBJECTS_INTERNAL_CLASSES_LAST OBJECTS_INTERNAL_THREADS
52
54 #define OBJECTS_RTEMS_CLASSES_LAST OBJECTS_RTEMS_BARRIERS
55
57 #define OBJECTS_POSIX_CLASSES_LAST OBJECTS_POSIX_SHMS
58
59 /*
60  * For fake objects, which have an object identifier, but no objects
61  * information block.
62  */
63 typedef enum {
64  OBJECTS_FAKE_OBJECTS_NO_CLASS = 0,
65  OBJECTS_FAKE_OBJECTS_SCHEDULERS = 1
66 } Objects_Fake_objects_API;
67
71 #if defined(RTEMS_MULTIPROCESSING)
72 extern uint16_t _Objects_Maximum_nodes;
73 #else
74 #define _Objects_Maximum_nodes 1
75 #endif
76
80 #define OBJECTS_INDEX_MINIMUM 1U
81
87 extern Objects_Information ** const
89
99  Objects_Information *information
100 );
101
109  Objects_Information *information,
110  Objects_Maximum block
111 );
112
124  Objects_Information *information
125 );
126
136
148 unsigned int _Objects_API_maximum_class(
149  uint32_t api
150 );
151
192
203 typedef enum {
204  OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL,
205  OBJECTS_INVALID_NAME,
206  OBJECTS_INVALID_ADDRESS,
207  OBJECTS_INVALID_ID,
208  OBJECTS_INVALID_NODE
210
215 #define OBJECTS_NAME_ERRORS_FIRST OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL
216
221 #define OBJECTS_NAME_ERRORS_LAST OBJECTS_INVALID_NODE
222
240  Objects_Information *information,
241  uint32_t name,
242  uint32_t node,
243  Objects_Id *id
244 );
245
246 typedef enum {
247  OBJECTS_GET_BY_NAME_INVALID_NAME,
248  OBJECTS_GET_BY_NAME_NAME_TOO_LONG,
249  OBJECTS_GET_BY_NAME_NO_OBJECT
250 } Objects_Get_by_name_error;
251
267  const Objects_Information *information,
268  const char *name,
269  size_t *name_length_p,
270  Objects_Get_by_name_error *error
271 );
272
290  Objects_Id id,
291  Objects_Name *name
292 );
293
315  Objects_Id id,
316  ISR_lock_Context *lock_context,
317  const Objects_Information *information
318 );
319
341  Objects_Id id,
342  const Objects_Information *information
343 );
344
360  Objects_Id id,
361  const Objects_Information *information,
362  Objects_Id *next_id_p
363 );
364
380  Objects_APIs the_api,
381  uint16_t the_class
382 );
383
397  Objects_Id id
398 );
399
409  const Objects_Information *information
410 )
411 {
412  return information->name_length > 0;
413 }
414
430  Objects_Id id,
431  size_t length,
432  char *name
433 );
434
450  Objects_Name name,
451  bool is_string,
452  char *buffer,
453  size_t buffer_size
454 );
455
470 bool _Objects_Set_name(
471  const Objects_Information *information,
472  Objects_Control *the_object,
473  const char *name
474 );
475
483  const Objects_Information *information,
484  Objects_Control *the_object
485 )
486 {
487  _Assert( !_Objects_Has_string_name( information ) );
488  the_object->name.name_u32 = 0;
489 }
490
498  const Objects_Information *information,
499  Objects_Control *the_object
500 );
501
511 void _Objects_Close(
512  const Objects_Information *information,
513  Objects_Control *the_object
514 );
515
524  const Objects_Information *information
525 );
526
535  const Objects_Information *information
536 )
537 {
538  return information->objects_per_block;
539 }
540
550  uint32_t the_api
551 )
552 {
553  if ( !the_api || the_api > OBJECTS_APIS_LAST )
554  return false;
555  return true;
556 }
557
568  uint32_t node
569 )
570 {
571  return ( node == _Objects_Local_node );
572 }
573
585 #if defined(RTEMS_MULTIPROCESSING)
586  Objects_Id id
587 #else
589 #endif
590 )
591 {
592 #if defined(RTEMS_MULTIPROCESSING)
594 #else
595  return true;
596 #endif
597 }
598
609  Objects_Id left,
610  Objects_Id right
611 )
612 {
613  return ( left == right );
614 }
615
626 {
627  id &= ~OBJECTS_INDEX_MASK;
629  return id;
630 }
631
640  const Objects_Information *information
641 )
642 {
643  return _Objects_Get_index( information->maximum_id );
644 }
645
653  Objects_Information *information
654 )
655 {
656  return (Objects_Control *) _Chain_Get_unprotected( &information->Inactive );
657 }
658
669  const Objects_Information *information
670 )
671 {
672  return information->objects_per_block != 0;
673 }
674
690  const Objects_Information *information,
691  uint32_t index,
692  Objects_Control *the_object
693 )
694 {
695  /*
696  * This routine is ONLY to be called from places in the code
697  * where the Id is known to be good. Therefore, this should NOT
698  * occur in normal situations.
699  */
700  _Assert( index >= OBJECTS_INDEX_MINIMUM );
701  _Assert( index <= _Objects_Get_maximum_index( information ) );
702
703  information->local_table[ index - OBJECTS_INDEX_MINIMUM ] = the_object;
704 }
705
723  const Objects_Information *information,
724  Objects_Control *the_object
725 )
726 {
727  _Assert( information != NULL );
728  _Assert( the_object != NULL );
729
731  information,
732  _Objects_Get_index( the_object->id ),
733  NULL
734  );
735 }
736
748  Objects_Information *information,
749  Objects_Control *the_object,
750  Objects_Name name
751 )
752 {
753  _Assert( information != NULL );
754  _Assert( the_object != NULL );
755
756  the_object->name = name;
757
759  information,
760  _Objects_Get_index( the_object->id ),
761  the_object
762  );
763 }
764
776  const Objects_Information *information,
777  Objects_Control *the_object,
778  uint32_t name
779 )
780 {
781  _Assert( !_Objects_Has_string_name( information ) );
782  the_object->name.name_u32 = name;
783
785  information,
786  _Objects_Get_index( the_object->id ),
787  the_object
788  );
789 }
790
802  const Objects_Information *information,
803  Objects_Control *the_object,
804  const char *name
805 )
806 {
807  _Assert( _Objects_Has_string_name( information ) );
808  the_object->name.name_p = name;
809
811  information,
812  _Objects_Get_index( the_object->id ),
813  the_object
814  );
815 }
816
832 {
833  _RTEMS_Lock_allocator();
834 }
835
844 {
845  _RTEMS_Unlock_allocator();
846 }
847
855 {
856  return _RTEMS_Allocator_is_owner();
857 }
858
875  Objects_Information *information
876 )
877 {
878  _Assert(
881  );
882
883  return ( *information->allocate )( information );
884 }
885
931  Objects_Information *information,
932  Objects_Control *the_object
933 )
934 {
936  _Assert( information->deallocate != NULL );
937  ( *information->deallocate )( information, the_object );
938 }
939
950  Objects_Information *information,
951  Objects_Control *the_object
952 )
953 {
954  Objects_Maximum objects_per_block;
955  Objects_Maximum block;
956
957  _Assert( _Objects_Is_auto_extend( information ) );
958
959  objects_per_block = information->objects_per_block;
960  block = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
961
962  if ( block > objects_per_block ) {
963  block /= objects_per_block;
964
965  information->inactive_per_block[ block ]--;
966  information->inactive--;
967  }
968 }
969
980  Objects_Information *information,
981  void ( *extend )( Objects_Information * )
982 )
983 {
984  Objects_Control *the_object;
985
986  _Assert( _Objects_Is_auto_extend( information ) );
987
988  the_object = _Objects_Get_inactive( information );
989
990  if ( the_object == NULL ) {
991  ( *extend )( information );
992  the_object = _Objects_Get_inactive( information );
993  }
994
995  if ( the_object != NULL ) {
996  _Objects_Activate_unlimited( information, the_object );
997  }
998
999  return the_object;
1000 }
1001
1004 #ifdef __cplusplus
1005 }
1006 #endif
1007
1008 #if defined(RTEMS_MULTIPROCESSING)
1009 #include <rtems/score/objectmp.h>
1010 #endif
1011
1012
1013 #endif
1014 /* end of include file */
RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_maximum_index(const Objects_Information *information)
Returns the maximum index of the specified object class.
Definition: objectimpl.h:639
uint32_t name_u32
Definition: object.h:68
void _Objects_Shrink_information(Objects_Information *information)
Shrinks an object class information record.
Definition: objectshrinkinformation.c:77
#define OBJECTS_APIS_LAST
Definition: object.h:183
void _Objects_Free_objects_block(Objects_Information *information, Objects_Maximum block)
Free the objects block with the specified index.
Definition: objectshrinkinformation.c:25
RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_unprotected(Objects_Information *information)
Allocates an object without locking the allocator mutex.
Definition: objectimpl.h:874
Definition: objectimpl.h:74
#define OBJECTS_INDEX_START_BIT
Definition: object.h:92
Definition: objectdata.h:39
RTEMS_INLINE_ROUTINE bool _Objects_Is_local_id(Objects_Id id RTEMS_UNUSED)
Checks if the id is of a local object.
Definition: objectimpl.h:584
Objects_Information * _Objects_Get_information(Objects_APIs the_api, uint16_t the_class)
Gets object information.
Definition: objectgetinfo.c:23
RTEMS_INLINE_ROUTINE bool _Objects_Has_string_name(const Objects_Information *information)
Returns if the object has a string name.
Definition: objectimpl.h:408
RTEMS_INLINE_ROUTINE bool _Objects_Are_ids_equal(Objects_Id left, Objects_Id right)
Checks if two object IDs are equal.
Definition: objectimpl.h:608
RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Get_inactive(Objects_Information *information)
Get an inactive object or NULL.
Definition: objectimpl.h:652
Objects_Information **const _Objects_Information_table[OBJECTS_APIS_LAST+1]
void _Objects_Initialize_information(Objects_Information *information)
Initializes the specified objects information.
Definition: objectinitializeinformation.c:29
Objects_Name_or_id_lookup_errors
Definition: objectimpl.h:203
Definition: objectimpl.h:80
Chain_Control Inactive
This is the chain of inactive object control blocks.
Definition: objectdata.h:256
RTEMS_INLINE_ROUTINE Objects_Id _Objects_Get_minimum_id(Objects_Id id)
Returns the identifier with the minimum index for the specified identifier.
Definition: objectimpl.h:625
uint16_t Objects_Maximum
Definition: object.h:86
Constants and Structures Related with Thread Dispatch.
Objects_Information * _Objects_Get_information_id(Objects_Id id)
Gets information of an object from an ID.
Definition: objectgetinfoid.c:24
Objects_Maximum * inactive_per_block
This is the number of inactive object control blocks per allocation block.
Definition: objectdata.h:264
RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_node(Objects_Id id)
Returns the node portion of the ID.
Definition: object.h:284
size_t _Objects_Name_to_string(Objects_Name name, bool is_string, char *buffer, size_t buffer_size)
Converts the specified object name to a text representation.
Definition: objectgetnameasstring.c:36
RTEMS_INLINE_ROUTINE void _Objects_Open(Objects_Information *information, Objects_Control *the_object, Objects_Name name)
Places the_object control pointer and object name in the Local Pointer and Local Name Tables,...
Definition: objectimpl.h:747
#define RTEMS_UNUSED
Definition: basedefs.h:174
RTEMS_INLINE_ROUTINE void _Objects_Allocator_unlock(void)
Unlocks the object allocator mutex.
Definition: objectimpl.h:843
char * _Objects_Get_name_as_string(Objects_Id id, size_t length, char *name)
Gets object name in the form of a C string.
Definition: objectgetnameasstring.c:87
bool(* Objects_Name_comparators)(void *, void *, uint16_t)
Definition: objectimpl.h:44
Objects_Maximum _Objects_Extend_information(Objects_Information *information)
Extends an object class information record.
Definition: objectextendinformation.c:32
RTEMS_INLINE_ROUTINE bool _System_state_Is_up(System_state_Codes state)
Checks if the state is up.
Definition: sysstate.h:133
Objects_Control *(* allocate)(Objects_Information *)
Allocate an object.
Definition: objectdata.h:203
Objects_Maximum inactive
This is the number of object control blocks on the inactive chain.
Definition: objectdata.h:222
void(* deallocate)(Objects_Information *, Objects_Control *)
Free an object.
Definition: objectdata.h:213
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:42
Object Handler Data Structures.
Information for the Assert Handler.
Objects_Control * _Objects_Get_by_name(const Objects_Information *information, const char *name, size_t *name_length_p, Objects_Get_by_name_error *error)
Gets an object control block identified by its name.
Definition: objectnametoidstring.c:26
Objects_Id maximum_id
This is the maximum valid ID of this object API class.
Definition: objectdata.h:185
Objects_Control ** local_table
This points to the table of local object control blocks.
Definition: objectdata.h:195
Objects_Maximum _Objects_Active_count(const Objects_Information *information)
Returns the count of active objects.
Definition: objectactivecount.c:23
API Mutex Handler API.
Objects_Name_or_id_lookup_errors _Objects_Name_to_id_u32(Objects_Information *information, uint32_t name, uint32_t node, Objects_Id *id)
Converts an object name to an Id.
Definition: objectnametoid.c:23
RTEMS_INLINE_ROUTINE System_state_Codes _System_state_Get(void)
Gets the current system state.
Definition: sysstate.h:90
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
RTEMS_INLINE_ROUTINE void _Objects_Open_string(const Objects_Information *information, Objects_Control *the_object, const char *name)
Definition: objectimpl.h:801
RTEMS_INLINE_ROUTINE void _Objects_Invalidate_Id(const Objects_Information *information, Objects_Control *the_object)
Invalidates an object Id.
Definition: objectimpl.h:722
RTEMS_INLINE_ROUTINE void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectimpl.h:930
bool _Objects_Set_name(const Objects_Information *information, Objects_Control *the_object, const char *name)
Sets objects name.
Definition: objectsetname.c:27
RTEMS_INLINE_ROUTINE bool _Objects_Is_api_valid(uint32_t the_api)
Checks if the api is valid.
Definition: objectimpl.h:549
Objects_Control * _Objects_Get_next(Objects_Id id, const Objects_Information *information, Objects_Id *next_id_p)
Gets the next open object after the specified object identifier.
Definition: objectgetnext.c:24
const char * name_p
Definition: object.h:66
uint16_t name_length
This is the maximum length of names.
Definition: objectdata.h:247
RTEMS_INLINE_ROUTINE void _Objects_Open_u32(const Objects_Information *information, Objects_Control *the_object, uint32_t name)
Definition: objectimpl.h:775
#define _Objects_Local_node
The local MPCI node number.
Definition: object.h:347
RTEMS_INLINE_ROUTINE void _Objects_Namespace_remove_u32(const Objects_Information *information, Objects_Control *the_object)
Removes object with a 32-bit integer name from its namespace.
Definition: objectimpl.h:482
RTEMS_INLINE_ROUTINE bool _Objects_Is_local_node(uint32_t node)
Checks if the node is of the local object.
Definition: objectimpl.h:567
Objects_APIs
Definition: object.h:174
#define OBJECTS_INDEX_MASK
Definition: object.h:114
System State Handler API.
RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_with_extend(Objects_Information *information, void(*extend)(Objects_Information *))
Allocate an object and extend the objects information on demand.
Definition: objectimpl.h:979
RTEMS_INLINE_ROUTINE bool _Objects_Allocator_is_owner(void)
Checks if the allocator is the owner of the object allocator mutex.
Definition: objectimpl.h:854
void _Objects_Namespace_remove_string(const Objects_Information *information, Objects_Control *the_object)
Removes object with a string name from its namespace.
Definition: objectnamespaceremove.c:25
uint32_t Objects_Id
Definition: object.h:80
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:28
RTEMS_INLINE_ROUTINE void _Objects_Activate_unlimited(Objects_Information *information, Objects_Control *the_object)
Activate the object.
Definition: objectimpl.h:949
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Objects_Name name
Definition: objectdata.h:45
This is the number of object control blocks in an allocation block.
Definition: objectdata.h:231
RTEMS_INLINE_ROUTINE void _Objects_Allocator_lock(void)
Locks the object allocator mutex.
Definition: objectimpl.h:831
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Get_unprotected(Chain_Control *the_chain)
Gets the first node (unprotected).
Definition: chainimpl.h:630
RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Extend_size(const Objects_Information *information)
Returns the object's objects per block.
Definition: objectimpl.h:534
RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Is_auto_extend(const Objects_Information *information)
Checks if the automatic object extension (unlimited objects) is enabled.
Definition: objectimpl.h:668
RTEMS_INLINE_ROUTINE void _Objects_Set_local_object(const Objects_Information *information, uint32_t index, Objects_Control *the_object)
Sets the pointer to the local_table object referenced by the index.
Definition: objectimpl.h:689
Definition: object.h:64
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
void _Objects_Close(const Objects_Information *information, Objects_Control *the_object)
Closes object.
Definition: objectclose.c:23
Objects_Control * _Objects_Get_no_protection(Objects_Id id, const Objects_Information *information)
Maps object ids to object control blocks.
Definition: objectgetnoprotection.c:23
ISR Locks.
unsigned int _Objects_API_maximum_class(uint32_t api)
Returns highest numeric value of a valid API for the specified API.
Definition: objectapimaximumclass.c:23
RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_index(Objects_Id id)
Returns the index portion of the ID.
Definition: object.h:298
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Data Associated with the Manipulation of Global RTEMS Objects.
Objects_Id id
Definition: objectdata.h:43
Objects_Name_or_id_lookup_errors _Objects_Id_to_name(Objects_Id id, Objects_Name *name)
Returns the name associated with object id.
Definition: objectidtoname.c:23
