RTEMS  5.1
Modules | Data Structures | Macros | Functions
Example CPU Architecture Support. More...
 CPUEndian
 CPUEndian.
 Example Assembler Support
 Management
 Management.
 Processor Dependent Bitfield Manipulation
 Processor Dependent Context Management
 Destroys the context of the thread.
 Processor Dependent Interrupt Management
struct  CPU_Per_CPU_control
 The CPU specific per-CPU control. More...
#define CPU_PER_CPU_CONTROL_SIZE   0
 The size of the CPU specific per-CPU control. More...
#define _CPU_Get_current_per_CPU_control()   ( _CPU_Per_CPU_current )
 Optional method to obtain the per-CPU control of the current processor. More...
#define _CPU_Get_thread_executing()   ( _CPU_Per_CPU_current->executing )
 Optional method to get the executing thread. More...
register struct Per_CPU_Control *_CPU_Per_CPU_current asm ("rX")
 Special register pointing to the per-CPU control of the current processor. More...
void _CPU_Context_volatile_clobber (uintptr_t pattern)
void _CPU_Context_validate (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal (void)
 Emits an illegal instruction. More...
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation (void)
 Emits a no operation instruction (nop). More...
◆ _CPU_Get_current_per_CPU_control
#define _CPU_Get_current_per_CPU_control ( )    ( _CPU_Per_CPU_current )
This is optional. Not every CPU port needs this. It is only an optional optimization variant. In case this macro is undefined, the default implementation using the current processor index will be used.
◆ _CPU_Get_thread_executing
#define _CPU_Get_thread_executing ( )    ( _CPU_Per_CPU_current->executing )
This is optional. Not every CPU port needs this. It is only an optional optimization variant. In case this macro is undefined, the default implementation uses the per-CPU information and the current processor index to get the executing thread.
◆ CPU_PER_CPU_CONTROL_SIZE
This define must be visible to assember files since it is used to derive structure offsets.
◆ _CPU_Instruction_illegal()
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal ( void  )
This function is used only in test sptests/spfatal26.
◆ _CPU_Instruction_no_operation()
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation ( void  )
This function is used only in test sptests/spcache01.
◆ asm()
register struct Per_CPU_Control* _CPU_Per_CPU_current asm ( "rX"  )
