35 #if defined ( __ICCARM__ ) 36 #pragma system_include 37 #elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050) 38 #pragma clang system_header 41 #ifndef __CORE_CM7_H_GENERIC 42 #define __CORE_CM7_H_GENERIC 74 #define __CM7_CMSIS_VERSION_MAIN (0x04U) 75 #define __CM7_CMSIS_VERSION_SUB (0x1EU) 76 #define __CM7_CMSIS_VERSION ((__CM7_CMSIS_VERSION_MAIN << 16U) | \ 77 __CM7_CMSIS_VERSION_SUB ) 79 #define __CORTEX_M (0x07U) 82 #if defined ( __CC_ARM ) 84 #define __INLINE __inline 85 #define __STATIC_INLINE static __inline 87 #elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050) 89 #define __INLINE __inline 90 #define __STATIC_INLINE static __inline 92 #elif defined ( __GNUC__ ) 94 #define __INLINE inline 95 #define __STATIC_INLINE static inline 97 #elif defined ( __ICCARM__ ) 99 #define __INLINE inline 100 #define __STATIC_INLINE static inline 102 #elif defined ( __TMS470__ ) 104 #define __STATIC_INLINE static inline 106 #elif defined ( __TASKING__ ) 108 #define __INLINE inline 109 #define __STATIC_INLINE static inline 111 #elif defined ( __CSMC__ ) 114 #define __INLINE inline 115 #define __STATIC_INLINE static inline 118 #error Unknown compiler 124 #if defined ( __CC_ARM ) 125 #if defined __TARGET_FPU_VFP 126 #if (__FPU_PRESENT == 1U) 127 #define __FPU_USED 1U 129 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" 130 #define __FPU_USED 0U 133 #define __FPU_USED 0U 136 #elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050) 137 #if defined __ARM_PCS_VFP 138 #if (__FPU_PRESENT == 1) 139 #define __FPU_USED 1U 141 #warning "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" 142 #define __FPU_USED 0U 145 #define __FPU_USED 0U 148 #elif defined ( __GNUC__ ) 149 #if defined (__VFP_FP__) && !defined(__SOFTFP__) 150 #if (__FPU_PRESENT == 1U) 151 #define __FPU_USED 1U 153 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" 154 #define __FPU_USED 0U 157 #define __FPU_USED 0U 160 #elif defined ( __ICCARM__ ) 161 #if defined __ARMVFP__ 162 #if (__FPU_PRESENT == 1U) 163 #define __FPU_USED 1U 165 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" 166 #define __FPU_USED 0U 169 #define __FPU_USED 0U 172 #elif defined ( __TMS470__ ) 173 #if defined __TI_VFP_SUPPORT__ 174 #if (__FPU_PRESENT == 1U) 175 #define __FPU_USED 1U 177 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" 178 #define __FPU_USED 0U 181 #define __FPU_USED 0U 184 #elif defined ( __TASKING__ ) 185 #if defined __FPU_VFP__ 186 #if (__FPU_PRESENT == 1U) 187 #define __FPU_USED 1U 189 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" 190 #define __FPU_USED 0U 193 #define __FPU_USED 0U 196 #elif defined ( __CSMC__ ) 197 #if ( __CSMC__ & 0x400U) 198 #if (__FPU_PRESENT == 1U) 199 #define __FPU_USED 1U 201 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" 202 #define __FPU_USED 0U 205 #define __FPU_USED 0U 220 #ifndef __CMSIS_GENERIC 222 #ifndef __CORE_CM7_H_DEPENDANT 223 #define __CORE_CM7_H_DEPENDANT 230 #if defined __CHECK_DEVICE_DEFINES 232 #define __CM7_REV 0x0000U 233 #warning "__CM7_REV not defined in device header file; using default!" 236 #ifndef __FPU_PRESENT 237 #define __FPU_PRESENT 0U 238 #warning "__FPU_PRESENT not defined in device header file; using default!" 241 #ifndef __MPU_PRESENT 242 #define __MPU_PRESENT 0U 243 #warning "__MPU_PRESENT not defined in device header file; using default!" 246 #ifndef __ICACHE_PRESENT 247 #define __ICACHE_PRESENT 0U 248 #warning "__ICACHE_PRESENT not defined in device header file; using default!" 251 #ifndef __DCACHE_PRESENT 252 #define __DCACHE_PRESENT 0U 253 #warning "__DCACHE_PRESENT not defined in device header file; using default!" 256 #ifndef __DTCM_PRESENT 257 #define __DTCM_PRESENT 0U 258 #warning "__DTCM_PRESENT not defined in device header file; using default!" 261 #ifndef __NVIC_PRIO_BITS 262 #define __NVIC_PRIO_BITS 3U 263 #warning "__NVIC_PRIO_BITS not defined in device header file; using default!" 266 #ifndef __Vendor_SysTickConfig 267 #define __Vendor_SysTickConfig 0U 268 #warning "__Vendor_SysTickConfig not defined in device header file; using default!" 284 #define __I volatile const 287 #define __IO volatile 290 #define __IM volatile const 291 #define __OM volatile 292 #define __IOM volatile 342 #define APSR_N_Pos 31U 343 #define APSR_N_Msk (1UL << APSR_N_Pos) 345 #define APSR_Z_Pos 30U 346 #define APSR_Z_Msk (1UL << APSR_Z_Pos) 348 #define APSR_C_Pos 29U 349 #define APSR_C_Msk (1UL << APSR_C_Pos) 351 #define APSR_V_Pos 28U 352 #define APSR_V_Msk (1UL << APSR_V_Pos) 354 #define APSR_Q_Pos 27U 355 #define APSR_Q_Msk (1UL << APSR_Q_Pos) 357 #define APSR_GE_Pos 16U 358 #define APSR_GE_Msk (0xFUL << APSR_GE_Pos) 375 #define IPSR_ISR_Pos 0U 376 #define IPSR_ISR_Msk (0x1FFUL ) 402 #define xPSR_N_Pos 31U 403 #define xPSR_N_Msk (1UL << xPSR_N_Pos) 405 #define xPSR_Z_Pos 30U 406 #define xPSR_Z_Msk (1UL << xPSR_Z_Pos) 408 #define xPSR_C_Pos 29U 409 #define xPSR_C_Msk (1UL << xPSR_C_Pos) 411 #define xPSR_V_Pos 28U 412 #define xPSR_V_Msk (1UL << xPSR_V_Pos) 414 #define xPSR_Q_Pos 27U 415 #define xPSR_Q_Msk (1UL << xPSR_Q_Pos) 417 #define xPSR_IT_Pos 25U 418 #define xPSR_IT_Msk (3UL << xPSR_IT_Pos) 420 #define xPSR_T_Pos 24U 421 #define xPSR_T_Msk (1UL << xPSR_T_Pos) 423 #define xPSR_GE_Pos 16U 424 #define xPSR_GE_Msk (0xFUL << xPSR_GE_Pos) 426 #define xPSR_ISR_Pos 0U 427 #define xPSR_ISR_Msk (0x1FFUL ) 446 #define CONTROL_FPCA_Pos 2U 447 #define CONTROL_FPCA_Msk (1UL << CONTROL_FPCA_Pos) 449 #define CONTROL_SPSEL_Pos 1U 450 #define CONTROL_SPSEL_Msk (1UL << CONTROL_SPSEL_Pos) 452 #define CONTROL_nPRIV_Pos 0U 453 #define CONTROL_nPRIV_Msk (1UL ) 470 __IOM uint32_t ISER[8U];
471 uint32_t RESERVED0[24U];
472 __IOM uint32_t ICER[8U];
473 uint32_t RSERVED1[24U];
474 __IOM uint32_t ISPR[8U];
475 uint32_t RESERVED2[24U];
476 __IOM uint32_t ICPR[8U];
477 uint32_t RESERVED3[24U];
478 __IOM uint32_t IABR[8U];
479 uint32_t RESERVED4[56U];
480 __IOM uint8_t IP[240U];
481 uint32_t RESERVED5[644U];
486 #define NVIC_STIR_INTID_Pos 0U 487 #define NVIC_STIR_INTID_Msk (0x1FFUL ) 507 __IOM uint32_t AIRCR;
510 __IOM uint8_t SHPR[12U];
511 __IOM uint32_t SHCSR;
515 __IOM uint32_t MMFAR;
518 __IM uint32_t ID_PFR[2U];
519 __IM uint32_t ID_DFR;
520 __IM uint32_t ID_AFR;
521 __IM uint32_t ID_MFR[4U];
522 __IM uint32_t ID_ISAR[5U];
523 uint32_t RESERVED0[1U];
526 __IM uint32_t CCSIDR;
527 __IOM uint32_t CSSELR;
528 __IOM uint32_t CPACR;
529 uint32_t RESERVED3[93U];
531 uint32_t RESERVED4[15U];
535 uint32_t RESERVED5[1U];
536 __OM uint32_t ICIALLU;
537 uint32_t RESERVED6[1U];
538 __OM uint32_t ICIMVAU;
539 __OM uint32_t DCIMVAC;
541 __OM uint32_t DCCMVAU;
542 __OM uint32_t DCCMVAC;
544 __OM uint32_t DCCIMVAC;
545 __OM uint32_t DCCISW;
546 uint32_t RESERVED7[6U];
547 __IOM uint32_t ITCMCR;
548 __IOM uint32_t DTCMCR;
549 __IOM uint32_t AHBPCR;
551 __IOM uint32_t AHBSCR;
552 uint32_t RESERVED8[1U];
553 __IOM uint32_t ABFSR;
557 #define SCB_CPUID_IMPLEMENTER_Pos 24U 558 #define SCB_CPUID_IMPLEMENTER_Msk (0xFFUL << SCB_CPUID_IMPLEMENTER_Pos) 560 #define SCB_CPUID_VARIANT_Pos 20U 561 #define SCB_CPUID_VARIANT_Msk (0xFUL << SCB_CPUID_VARIANT_Pos) 563 #define SCB_CPUID_ARCHITECTURE_Pos 16U 564 #define SCB_CPUID_ARCHITECTURE_Msk (0xFUL << SCB_CPUID_ARCHITECTURE_Pos) 566 #define SCB_CPUID_PARTNO_Pos 4U 567 #define SCB_CPUID_PARTNO_Msk (0xFFFUL << SCB_CPUID_PARTNO_Pos) 569 #define SCB_CPUID_REVISION_Pos 0U 570 #define SCB_CPUID_REVISION_Msk (0xFUL ) 573 #define SCB_ICSR_NMIPENDSET_Pos 31U 574 #define SCB_ICSR_NMIPENDSET_Msk (1UL << SCB_ICSR_NMIPENDSET_Pos) 576 #define SCB_ICSR_PENDSVSET_Pos 28U 577 #define SCB_ICSR_PENDSVSET_Msk (1UL << SCB_ICSR_PENDSVSET_Pos) 579 #define SCB_ICSR_PENDSVCLR_Pos 27U 580 #define SCB_ICSR_PENDSVCLR_Msk (1UL << SCB_ICSR_PENDSVCLR_Pos) 582 #define SCB_ICSR_PENDSTSET_Pos 26U 583 #define SCB_ICSR_PENDSTSET_Msk (1UL << SCB_ICSR_PENDSTSET_Pos) 585 #define SCB_ICSR_PENDSTCLR_Pos 25U 586 #define SCB_ICSR_PENDSTCLR_Msk (1UL << SCB_ICSR_PENDSTCLR_Pos) 588 #define SCB_ICSR_ISRPREEMPT_Pos 23U 589 #define SCB_ICSR_ISRPREEMPT_Msk (1UL << SCB_ICSR_ISRPREEMPT_Pos) 591 #define SCB_ICSR_ISRPENDING_Pos 22U 592 #define SCB_ICSR_ISRPENDING_Msk (1UL << SCB_ICSR_ISRPENDING_Pos) 594 #define SCB_ICSR_VECTPENDING_Pos 12U 595 #define SCB_ICSR_VECTPENDING_Msk (0x1FFUL << SCB_ICSR_VECTPENDING_Pos) 597 #define SCB_ICSR_RETTOBASE_Pos 11U 598 #define SCB_ICSR_RETTOBASE_Msk (1UL << SCB_ICSR_RETTOBASE_Pos) 600 #define SCB_ICSR_VECTACTIVE_Pos 0U 601 #define SCB_ICSR_VECTACTIVE_Msk (0x1FFUL ) 604 #define SCB_VTOR_TBLOFF_Pos 7U 605 #define SCB_VTOR_TBLOFF_Msk (0x1FFFFFFUL << SCB_VTOR_TBLOFF_Pos) 608 #define SCB_AIRCR_VECTKEY_Pos 16U 609 #define SCB_AIRCR_VECTKEY_Msk (0xFFFFUL << SCB_AIRCR_VECTKEY_Pos) 611 #define SCB_AIRCR_VECTKEYSTAT_Pos 16U 612 #define SCB_AIRCR_VECTKEYSTAT_Msk (0xFFFFUL << SCB_AIRCR_VECTKEYSTAT_Pos) 614 #define SCB_AIRCR_ENDIANESS_Pos 15U 615 #define SCB_AIRCR_ENDIANESS_Msk (1UL << SCB_AIRCR_ENDIANESS_Pos) 617 #define SCB_AIRCR_PRIGROUP_Pos 8U 618 #define SCB_AIRCR_PRIGROUP_Msk (7UL << SCB_AIRCR_PRIGROUP_Pos) 620 #define SCB_AIRCR_SYSRESETREQ_Pos 2U 621 #define SCB_AIRCR_SYSRESETREQ_Msk (1UL << SCB_AIRCR_SYSRESETREQ_Pos) 623 #define SCB_AIRCR_VECTCLRACTIVE_Pos 1U 624 #define SCB_AIRCR_VECTCLRACTIVE_Msk (1UL << SCB_AIRCR_VECTCLRACTIVE_Pos) 626 #define SCB_AIRCR_VECTRESET_Pos 0U 627 #define SCB_AIRCR_VECTRESET_Msk (1UL ) 630 #define SCB_SCR_SEVONPEND_Pos 4U 631 #define SCB_SCR_SEVONPEND_Msk (1UL << SCB_SCR_SEVONPEND_Pos) 633 #define SCB_SCR_SLEEPDEEP_Pos 2U 634 #define SCB_SCR_SLEEPDEEP_Msk (1UL << SCB_SCR_SLEEPDEEP_Pos) 636 #define SCB_SCR_SLEEPONEXIT_Pos 1U 637 #define SCB_SCR_SLEEPONEXIT_Msk (1UL << SCB_SCR_SLEEPONEXIT_Pos) 640 #define SCB_CCR_BP_Pos 18U 641 #define SCB_CCR_BP_Msk (1UL << SCB_CCR_BP_Pos) 643 #define SCB_CCR_IC_Pos 17U 644 #define SCB_CCR_IC_Msk (1UL << SCB_CCR_IC_Pos) 646 #define SCB_CCR_DC_Pos 16U 647 #define SCB_CCR_DC_Msk (1UL << SCB_CCR_DC_Pos) 649 #define SCB_CCR_STKALIGN_Pos 9U 650 #define SCB_CCR_STKALIGN_Msk (1UL << SCB_CCR_STKALIGN_Pos) 652 #define SCB_CCR_BFHFNMIGN_Pos 8U 653 #define SCB_CCR_BFHFNMIGN_Msk (1UL << SCB_CCR_BFHFNMIGN_Pos) 655 #define SCB_CCR_DIV_0_TRP_Pos 4U 656 #define SCB_CCR_DIV_0_TRP_Msk (1UL << SCB_CCR_DIV_0_TRP_Pos) 658 #define SCB_CCR_UNALIGN_TRP_Pos 3U 659 #define SCB_CCR_UNALIGN_TRP_Msk (1UL << SCB_CCR_UNALIGN_TRP_Pos) 661 #define SCB_CCR_USERSETMPEND_Pos 1U 662 #define SCB_CCR_USERSETMPEND_Msk (1UL << SCB_CCR_USERSETMPEND_Pos) 664 #define SCB_CCR_NONBASETHRDENA_Pos 0U 665 #define SCB_CCR_NONBASETHRDENA_Msk (1UL ) 668 #define SCB_SHCSR_USGFAULTENA_Pos 18U 669 #define SCB_SHCSR_USGFAULTENA_Msk (1UL << SCB_SHCSR_USGFAULTENA_Pos) 671 #define SCB_SHCSR_BUSFAULTENA_Pos 17U 672 #define SCB_SHCSR_BUSFAULTENA_Msk (1UL << SCB_SHCSR_BUSFAULTENA_Pos) 674 #define SCB_SHCSR_MEMFAULTENA_Pos 16U 675 #define SCB_SHCSR_MEMFAULTENA_Msk (1UL << SCB_SHCSR_MEMFAULTENA_Pos) 677 #define SCB_SHCSR_SVCALLPENDED_Pos 15U 678 #define SCB_SHCSR_SVCALLPENDED_Msk (1UL << SCB_SHCSR_SVCALLPENDED_Pos) 680 #define SCB_SHCSR_BUSFAULTPENDED_Pos 14U 681 #define SCB_SHCSR_BUSFAULTPENDED_Msk (1UL << SCB_SHCSR_BUSFAULTPENDED_Pos) 683 #define SCB_SHCSR_MEMFAULTPENDED_Pos 13U 684 #define SCB_SHCSR_MEMFAULTPENDED_Msk (1UL << SCB_SHCSR_MEMFAULTPENDED_Pos) 686 #define SCB_SHCSR_USGFAULTPENDED_Pos 12U 687 #define SCB_SHCSR_USGFAULTPENDED_Msk (1UL << SCB_SHCSR_USGFAULTPENDED_Pos) 689 #define SCB_SHCSR_SYSTICKACT_Pos 11U 690 #define SCB_SHCSR_SYSTICKACT_Msk (1UL << SCB_SHCSR_SYSTICKACT_Pos) 692 #define SCB_SHCSR_PENDSVACT_Pos 10U 693 #define SCB_SHCSR_PENDSVACT_Msk (1UL << SCB_SHCSR_PENDSVACT_Pos) 695 #define SCB_SHCSR_MONITORACT_Pos 8U 696 #define SCB_SHCSR_MONITORACT_Msk (1UL << SCB_SHCSR_MONITORACT_Pos) 698 #define SCB_SHCSR_SVCALLACT_Pos 7U 699 #define SCB_SHCSR_SVCALLACT_Msk (1UL << SCB_SHCSR_SVCALLACT_Pos) 701 #define SCB_SHCSR_USGFAULTACT_Pos 3U 702 #define SCB_SHCSR_USGFAULTACT_Msk (1UL << SCB_SHCSR_USGFAULTACT_Pos) 704 #define SCB_SHCSR_BUSFAULTACT_Pos 1U 705 #define SCB_SHCSR_BUSFAULTACT_Msk (1UL << SCB_SHCSR_BUSFAULTACT_Pos) 707 #define SCB_SHCSR_MEMFAULTACT_Pos 0U 708 #define SCB_SHCSR_MEMFAULTACT_Msk (1UL ) 711 #define SCB_CFSR_USGFAULTSR_Pos 16U 712 #define SCB_CFSR_USGFAULTSR_Msk (0xFFFFUL << SCB_CFSR_USGFAULTSR_Pos) 714 #define SCB_CFSR_BUSFAULTSR_Pos 8U 715 #define SCB_CFSR_BUSFAULTSR_Msk (0xFFUL << SCB_CFSR_BUSFAULTSR_Pos) 717 #define SCB_CFSR_MEMFAULTSR_Pos 0U 718 #define SCB_CFSR_MEMFAULTSR_Msk (0xFFUL ) 721 #define SCB_HFSR_DEBUGEVT_Pos 31U 722 #define SCB_HFSR_DEBUGEVT_Msk (1UL << SCB_HFSR_DEBUGEVT_Pos) 724 #define SCB_HFSR_FORCED_Pos 30U 725 #define SCB_HFSR_FORCED_Msk (1UL << SCB_HFSR_FORCED_Pos) 727 #define SCB_HFSR_VECTTBL_Pos 1U 728 #define SCB_HFSR_VECTTBL_Msk (1UL << SCB_HFSR_VECTTBL_Pos) 731 #define SCB_DFSR_EXTERNAL_Pos 4U 732 #define SCB_DFSR_EXTERNAL_Msk (1UL << SCB_DFSR_EXTERNAL_Pos) 734 #define SCB_DFSR_VCATCH_Pos 3U 735 #define SCB_DFSR_VCATCH_Msk (1UL << SCB_DFSR_VCATCH_Pos) 737 #define SCB_DFSR_DWTTRAP_Pos 2U 738 #define SCB_DFSR_DWTTRAP_Msk (1UL << SCB_DFSR_DWTTRAP_Pos) 740 #define SCB_DFSR_BKPT_Pos 1U 741 #define SCB_DFSR_BKPT_Msk (1UL << SCB_DFSR_BKPT_Pos) 743 #define SCB_DFSR_HALTED_Pos 0U 744 #define SCB_DFSR_HALTED_Msk (1UL ) 747 #define SCB_CLIDR_LOUU_Pos 27U 748 #define SCB_CLIDR_LOUU_Msk (7UL << SCB_CLIDR_LOUU_Pos) 750 #define SCB_CLIDR_LOC_Pos 24U 751 #define SCB_CLIDR_LOC_Msk (7UL << SCB_CLIDR_LOC_Pos) 754 #define SCB_CTR_FORMAT_Pos 29U 755 #define SCB_CTR_FORMAT_Msk (7UL << SCB_CTR_FORMAT_Pos) 757 #define SCB_CTR_CWG_Pos 24U 758 #define SCB_CTR_CWG_Msk (0xFUL << SCB_CTR_CWG_Pos) 760 #define SCB_CTR_ERG_Pos 20U 761 #define SCB_CTR_ERG_Msk (0xFUL << SCB_CTR_ERG_Pos) 763 #define SCB_CTR_DMINLINE_Pos 16U 764 #define SCB_CTR_DMINLINE_Msk (0xFUL << SCB_CTR_DMINLINE_Pos) 766 #define SCB_CTR_IMINLINE_Pos 0U 767 #define SCB_CTR_IMINLINE_Msk (0xFUL ) 770 #define SCB_CCSIDR_WT_Pos 31U 771 #define SCB_CCSIDR_WT_Msk (1UL << SCB_CCSIDR_WT_Pos) 773 #define SCB_CCSIDR_WB_Pos 30U 774 #define SCB_CCSIDR_WB_Msk (1UL << SCB_CCSIDR_WB_Pos) 776 #define SCB_CCSIDR_RA_Pos 29U 777 #define SCB_CCSIDR_RA_Msk (1UL << SCB_CCSIDR_RA_Pos) 779 #define SCB_CCSIDR_WA_Pos 28U 780 #define SCB_CCSIDR_WA_Msk (1UL << SCB_CCSIDR_WA_Pos) 782 #define SCB_CCSIDR_NUMSETS_Pos 13U 783 #define SCB_CCSIDR_NUMSETS_Msk (0x7FFFUL << SCB_CCSIDR_NUMSETS_Pos) 785 #define SCB_CCSIDR_ASSOCIATIVITY_Pos 3U 786 #define SCB_CCSIDR_ASSOCIATIVITY_Msk (0x3FFUL << SCB_CCSIDR_ASSOCIATIVITY_Pos) 788 #define SCB_CCSIDR_LINESIZE_Pos 0U 789 #define SCB_CCSIDR_LINESIZE_Msk (7UL ) 792 #define SCB_CSSELR_LEVEL_Pos 1U 793 #define SCB_CSSELR_LEVEL_Msk (7UL << SCB_CSSELR_LEVEL_Pos) 795 #define SCB_CSSELR_IND_Pos 0U 796 #define SCB_CSSELR_IND_Msk (1UL ) 799 #define SCB_STIR_INTID_Pos 0U 800 #define SCB_STIR_INTID_Msk (0x1FFUL ) 803 #define SCB_DCISW_WAY_Pos 30U 804 #define SCB_DCISW_WAY_Msk (3UL << SCB_DCISW_WAY_Pos) 806 #define SCB_DCISW_SET_Pos 5U 807 #define SCB_DCISW_SET_Msk (0x1FFUL << SCB_DCISW_SET_Pos) 810 #define SCB_DCCSW_WAY_Pos 30U 811 #define SCB_DCCSW_WAY_Msk (3UL << SCB_DCCSW_WAY_Pos) 813 #define SCB_DCCSW_SET_Pos 5U 814 #define SCB_DCCSW_SET_Msk (0x1FFUL << SCB_DCCSW_SET_Pos) 817 #define SCB_DCCISW_WAY_Pos 30U 818 #define SCB_DCCISW_WAY_Msk (3UL << SCB_DCCISW_WAY_Pos) 820 #define SCB_DCCISW_SET_Pos 5U 821 #define SCB_DCCISW_SET_Msk (0x1FFUL << SCB_DCCISW_SET_Pos) 824 #define SCB_ITCMCR_SZ_Pos 3U 825 #define SCB_ITCMCR_SZ_Msk (0xFUL << SCB_ITCMCR_SZ_Pos) 827 #define SCB_ITCMCR_RETEN_Pos 2U 828 #define SCB_ITCMCR_RETEN_Msk (1UL << SCB_ITCMCR_RETEN_Pos) 830 #define SCB_ITCMCR_RMW_Pos 1U 831 #define SCB_ITCMCR_RMW_Msk (1UL << SCB_ITCMCR_RMW_Pos) 833 #define SCB_ITCMCR_EN_Pos 0U 834 #define SCB_ITCMCR_EN_Msk (1UL ) 837 #define SCB_DTCMCR_SZ_Pos 3U 838 #define SCB_DTCMCR_SZ_Msk (0xFUL << SCB_DTCMCR_SZ_Pos) 840 #define SCB_DTCMCR_RETEN_Pos 2U 841 #define SCB_DTCMCR_RETEN_Msk (1UL << SCB_DTCMCR_RETEN_Pos) 843 #define SCB_DTCMCR_RMW_Pos 1U 844 #define SCB_DTCMCR_RMW_Msk (1UL << SCB_DTCMCR_RMW_Pos) 846 #define SCB_DTCMCR_EN_Pos 0U 847 #define SCB_DTCMCR_EN_Msk (1UL ) 850 #define SCB_AHBPCR_SZ_Pos 1U 851 #define SCB_AHBPCR_SZ_Msk (7UL << SCB_AHBPCR_SZ_Pos) 853 #define SCB_AHBPCR_EN_Pos 0U 854 #define SCB_AHBPCR_EN_Msk (1UL ) 857 #define SCB_CACR_FORCEWT_Pos 2U 858 #define SCB_CACR_FORCEWT_Msk (1UL << SCB_CACR_FORCEWT_Pos) 860 #define SCB_CACR_ECCEN_Pos 1U 861 #define SCB_CACR_ECCEN_Msk (1UL << SCB_CACR_ECCEN_Pos) 863 #define SCB_CACR_SIWT_Pos 0U 864 #define SCB_CACR_SIWT_Msk (1UL ) 867 #define SCB_AHBSCR_INITCOUNT_Pos 11U 868 #define SCB_AHBSCR_INITCOUNT_Msk (0x1FUL << SCB_AHBPCR_INITCOUNT_Pos) 870 #define SCB_AHBSCR_TPRI_Pos 2U 871 #define SCB_AHBSCR_TPRI_Msk (0x1FFUL << SCB_AHBPCR_TPRI_Pos) 873 #define SCB_AHBSCR_CTL_Pos 0U 874 #define SCB_AHBSCR_CTL_Msk (3UL ) 877 #define SCB_ABFSR_AXIMTYPE_Pos 8U 878 #define SCB_ABFSR_AXIMTYPE_Msk (3UL << SCB_ABFSR_AXIMTYPE_Pos) 880 #define SCB_ABFSR_EPPB_Pos 4U 881 #define SCB_ABFSR_EPPB_Msk (1UL << SCB_ABFSR_EPPB_Pos) 883 #define SCB_ABFSR_AXIM_Pos 3U 884 #define SCB_ABFSR_AXIM_Msk (1UL << SCB_ABFSR_AXIM_Pos) 886 #define SCB_ABFSR_AHBP_Pos 2U 887 #define SCB_ABFSR_AHBP_Msk (1UL << SCB_ABFSR_AHBP_Pos) 889 #define SCB_ABFSR_DTCM_Pos 1U 890 #define SCB_ABFSR_DTCM_Msk (1UL << SCB_ABFSR_DTCM_Pos) 892 #define SCB_ABFSR_ITCM_Pos 0U 893 #define SCB_ABFSR_ITCM_Msk (1UL ) 910 uint32_t RESERVED0[1U];
912 __IOM uint32_t ACTLR;
916 #define SCnSCB_ICTR_INTLINESNUM_Pos 0U 917 #define SCnSCB_ICTR_INTLINESNUM_Msk (0xFUL ) 920 #define SCnSCB_ACTLR_DISITMATBFLUSH_Pos 12U 921 #define SCnSCB_ACTLR_DISITMATBFLUSH_Msk (1UL << SCnSCB_ACTLR_DISITMATBFLUSH_Pos) 923 #define SCnSCB_ACTLR_DISRAMODE_Pos 11U 924 #define SCnSCB_ACTLR_DISRAMODE_Msk (1UL << SCnSCB_ACTLR_DISRAMODE_Pos) 926 #define SCnSCB_ACTLR_FPEXCODIS_Pos 10U 927 #define SCnSCB_ACTLR_FPEXCODIS_Msk (1UL << SCnSCB_ACTLR_FPEXCODIS_Pos) 929 #define SCnSCB_ACTLR_DISFOLD_Pos 2U 930 #define SCnSCB_ACTLR_DISFOLD_Msk (1UL << SCnSCB_ACTLR_DISFOLD_Pos) 932 #define SCnSCB_ACTLR_DISMCYCINT_Pos 0U 933 #define SCnSCB_ACTLR_DISMCYCINT_Msk (1UL ) 957 #define SysTick_CTRL_COUNTFLAG_Pos 16U 958 #define SysTick_CTRL_COUNTFLAG_Msk (1UL << SysTick_CTRL_COUNTFLAG_Pos) 960 #define SysTick_CTRL_CLKSOURCE_Pos 2U 961 #define SysTick_CTRL_CLKSOURCE_Msk (1UL << SysTick_CTRL_CLKSOURCE_Pos) 963 #define SysTick_CTRL_TICKINT_Pos 1U 964 #define SysTick_CTRL_TICKINT_Msk (1UL << SysTick_CTRL_TICKINT_Pos) 966 #define SysTick_CTRL_ENABLE_Pos 0U 967 #define SysTick_CTRL_ENABLE_Msk (1UL ) 970 #define SysTick_LOAD_RELOAD_Pos 0U 971 #define SysTick_LOAD_RELOAD_Msk (0xFFFFFFUL ) 974 #define SysTick_VAL_CURRENT_Pos 0U 975 #define SysTick_VAL_CURRENT_Msk (0xFFFFFFUL ) 978 #define SysTick_CALIB_NOREF_Pos 31U 979 #define SysTick_CALIB_NOREF_Msk (1UL << SysTick_CALIB_NOREF_Pos) 981 #define SysTick_CALIB_SKEW_Pos 30U 982 #define SysTick_CALIB_SKEW_Msk (1UL << SysTick_CALIB_SKEW_Pos) 984 #define SysTick_CALIB_TENMS_Pos 0U 985 #define SysTick_CALIB_TENMS_Msk (0xFFFFFFUL ) 1008 uint32_t RESERVED0[864U];
1010 uint32_t RESERVED1[15U];
1012 uint32_t RESERVED2[15U];
1014 uint32_t RESERVED3[29U];
1017 __IOM uint32_t IMCR;
1018 uint32_t RESERVED4[43U];
1021 uint32_t RESERVED5[6U];
1037 #define ITM_TPR_PRIVMASK_Pos 0U 1038 #define ITM_TPR_PRIVMASK_Msk (0xFUL ) 1041 #define ITM_TCR_BUSY_Pos 23U 1042 #define ITM_TCR_BUSY_Msk (1UL << ITM_TCR_BUSY_Pos) 1044 #define ITM_TCR_TraceBusID_Pos 16U 1045 #define ITM_TCR_TraceBusID_Msk (0x7FUL << ITM_TCR_TraceBusID_Pos) 1047 #define ITM_TCR_GTSFREQ_Pos 10U 1048 #define ITM_TCR_GTSFREQ_Msk (3UL << ITM_TCR_GTSFREQ_Pos) 1050 #define ITM_TCR_TSPrescale_Pos 8U 1051 #define ITM_TCR_TSPrescale_Msk (3UL << ITM_TCR_TSPrescale_Pos) 1053 #define ITM_TCR_SWOENA_Pos 4U 1054 #define ITM_TCR_SWOENA_Msk (1UL << ITM_TCR_SWOENA_Pos) 1056 #define ITM_TCR_DWTENA_Pos 3U 1057 #define ITM_TCR_DWTENA_Msk (1UL << ITM_TCR_DWTENA_Pos) 1059 #define ITM_TCR_SYNCENA_Pos 2U 1060 #define ITM_TCR_SYNCENA_Msk (1UL << ITM_TCR_SYNCENA_Pos) 1062 #define ITM_TCR_TSENA_Pos 1U 1063 #define ITM_TCR_TSENA_Msk (1UL << ITM_TCR_TSENA_Pos) 1065 #define ITM_TCR_ITMENA_Pos 0U 1066 #define ITM_TCR_ITMENA_Msk (1UL ) 1069 #define ITM_IWR_ATVALIDM_Pos 0U 1070 #define ITM_IWR_ATVALIDM_Msk (1UL ) 1073 #define ITM_IRR_ATREADYM_Pos 0U 1074 #define ITM_IRR_ATREADYM_Msk (1UL ) 1077 #define ITM_IMCR_INTEGRATION_Pos 0U 1078 #define ITM_IMCR_INTEGRATION_Msk (1UL ) 1081 #define ITM_LSR_ByteAcc_Pos 2U 1082 #define ITM_LSR_ByteAcc_Msk (1UL << ITM_LSR_ByteAcc_Pos) 1084 #define ITM_LSR_Access_Pos 1U 1085 #define ITM_LSR_Access_Msk (1UL << ITM_LSR_Access_Pos) 1087 #define ITM_LSR_Present_Pos 0U 1088 #define ITM_LSR_Present_Msk (1UL ) 1105 __IOM uint32_t CTRL;
1106 __IOM uint32_t CYCCNT;
1107 __IOM uint32_t CPICNT;
1108 __IOM uint32_t EXCCNT;
1109 __IOM uint32_t SLEEPCNT;
1110 __IOM uint32_t LSUCNT;
1111 __IOM uint32_t FOLDCNT;
1113 __IOM uint32_t COMP0;
1114 __IOM uint32_t MASK0;
1115 __IOM uint32_t FUNCTION0;
1116 uint32_t RESERVED0[1U];
1117 __IOM uint32_t COMP1;
1118 __IOM uint32_t MASK1;
1119 __IOM uint32_t FUNCTION1;
1120 uint32_t RESERVED1[1U];
1121 __IOM uint32_t COMP2;
1122 __IOM uint32_t MASK2;
1123 __IOM uint32_t FUNCTION2;
1124 uint32_t RESERVED2[1U];
1125 __IOM uint32_t COMP3;
1126 __IOM uint32_t MASK3;
1127 __IOM uint32_t FUNCTION3;
1128 uint32_t RESERVED3[981U];
1134 #define DWT_CTRL_NUMCOMP_Pos 28U 1135 #define DWT_CTRL_NUMCOMP_Msk (0xFUL << DWT_CTRL_NUMCOMP_Pos) 1137 #define DWT_CTRL_NOTRCPKT_Pos 27U 1138 #define DWT_CTRL_NOTRCPKT_Msk (0x1UL << DWT_CTRL_NOTRCPKT_Pos) 1140 #define DWT_CTRL_NOEXTTRIG_Pos 26U 1141 #define DWT_CTRL_NOEXTTRIG_Msk (0x1UL << DWT_CTRL_NOEXTTRIG_Pos) 1143 #define DWT_CTRL_NOCYCCNT_Pos 25U 1144 #define DWT_CTRL_NOCYCCNT_Msk (0x1UL << DWT_CTRL_NOCYCCNT_Pos) 1146 #define DWT_CTRL_NOPRFCNT_Pos 24U 1147 #define DWT_CTRL_NOPRFCNT_Msk (0x1UL << DWT_CTRL_NOPRFCNT_Pos) 1149 #define DWT_CTRL_CYCEVTENA_Pos 22U 1150 #define DWT_CTRL_CYCEVTENA_Msk (0x1UL << DWT_CTRL_CYCEVTENA_Pos) 1152 #define DWT_CTRL_FOLDEVTENA_Pos 21U 1153 #define DWT_CTRL_FOLDEVTENA_Msk (0x1UL << DWT_CTRL_FOLDEVTENA_Pos) 1155 #define DWT_CTRL_LSUEVTENA_Pos 20U 1156 #define DWT_CTRL_LSUEVTENA_Msk (0x1UL << DWT_CTRL_LSUEVTENA_Pos) 1158 #define DWT_CTRL_SLEEPEVTENA_Pos 19U 1159 #define DWT_CTRL_SLEEPEVTENA_Msk (0x1UL << DWT_CTRL_SLEEPEVTENA_Pos) 1161 #define DWT_CTRL_EXCEVTENA_Pos 18U 1162 #define DWT_CTRL_EXCEVTENA_Msk (0x1UL << DWT_CTRL_EXCEVTENA_Pos) 1164 #define DWT_CTRL_CPIEVTENA_Pos 17U 1165 #define DWT_CTRL_CPIEVTENA_Msk (0x1UL << DWT_CTRL_CPIEVTENA_Pos) 1167 #define DWT_CTRL_EXCTRCENA_Pos 16U 1168 #define DWT_CTRL_EXCTRCENA_Msk (0x1UL << DWT_CTRL_EXCTRCENA_Pos) 1170 #define DWT_CTRL_PCSAMPLENA_Pos 12U 1171 #define DWT_CTRL_PCSAMPLENA_Msk (0x1UL << DWT_CTRL_PCSAMPLENA_Pos) 1173 #define DWT_CTRL_SYNCTAP_Pos 10U 1174 #define DWT_CTRL_SYNCTAP_Msk (0x3UL << DWT_CTRL_SYNCTAP_Pos) 1176 #define DWT_CTRL_CYCTAP_Pos 9U 1177 #define DWT_CTRL_CYCTAP_Msk (0x1UL << DWT_CTRL_CYCTAP_Pos) 1179 #define DWT_CTRL_POSTINIT_Pos 5U 1180 #define DWT_CTRL_POSTINIT_Msk (0xFUL << DWT_CTRL_POSTINIT_Pos) 1182 #define DWT_CTRL_POSTPRESET_Pos 1U 1183 #define DWT_CTRL_POSTPRESET_Msk (0xFUL << DWT_CTRL_POSTPRESET_Pos) 1185 #define DWT_CTRL_CYCCNTENA_Pos 0U 1186 #define DWT_CTRL_CYCCNTENA_Msk (0x1UL ) 1189 #define DWT_CPICNT_CPICNT_Pos 0U 1190 #define DWT_CPICNT_CPICNT_Msk (0xFFUL ) 1193 #define DWT_EXCCNT_EXCCNT_Pos 0U 1194 #define DWT_EXCCNT_EXCCNT_Msk (0xFFUL ) 1197 #define DWT_SLEEPCNT_SLEEPCNT_Pos 0U 1198 #define DWT_SLEEPCNT_SLEEPCNT_Msk (0xFFUL ) 1201 #define DWT_LSUCNT_LSUCNT_Pos 0U 1202 #define DWT_LSUCNT_LSUCNT_Msk (0xFFUL ) 1205 #define DWT_FOLDCNT_FOLDCNT_Pos 0U 1206 #define DWT_FOLDCNT_FOLDCNT_Msk (0xFFUL ) 1209 #define DWT_MASK_MASK_Pos 0U 1210 #define DWT_MASK_MASK_Msk (0x1FUL ) 1213 #define DWT_FUNCTION_MATCHED_Pos 24U 1214 #define DWT_FUNCTION_MATCHED_Msk (0x1UL << DWT_FUNCTION_MATCHED_Pos) 1216 #define DWT_FUNCTION_DATAVADDR1_Pos 16U 1217 #define DWT_FUNCTION_DATAVADDR1_Msk (0xFUL << DWT_FUNCTION_DATAVADDR1_Pos) 1219 #define DWT_FUNCTION_DATAVADDR0_Pos 12U 1220 #define DWT_FUNCTION_DATAVADDR0_Msk (0xFUL << DWT_FUNCTION_DATAVADDR0_Pos) 1222 #define DWT_FUNCTION_DATAVSIZE_Pos 10U 1223 #define DWT_FUNCTION_DATAVSIZE_Msk (0x3UL << DWT_FUNCTION_DATAVSIZE_Pos) 1225 #define DWT_FUNCTION_LNK1ENA_Pos 9U 1226 #define DWT_FUNCTION_LNK1ENA_Msk (0x1UL << DWT_FUNCTION_LNK1ENA_Pos) 1228 #define DWT_FUNCTION_DATAVMATCH_Pos 8U 1229 #define DWT_FUNCTION_DATAVMATCH_Msk (0x1UL << DWT_FUNCTION_DATAVMATCH_Pos) 1231 #define DWT_FUNCTION_CYCMATCH_Pos 7U 1232 #define DWT_FUNCTION_CYCMATCH_Msk (0x1UL << DWT_FUNCTION_CYCMATCH_Pos) 1234 #define DWT_FUNCTION_EMITRANGE_Pos 5U 1235 #define DWT_FUNCTION_EMITRANGE_Msk (0x1UL << DWT_FUNCTION_EMITRANGE_Pos) 1237 #define DWT_FUNCTION_FUNCTION_Pos 0U 1238 #define DWT_FUNCTION_FUNCTION_Msk (0xFUL ) 1255 __IOM uint32_t SSPSR;
1256 __IOM uint32_t CSPSR;
1257 uint32_t RESERVED0[2U];
1258 __IOM uint32_t ACPR;
1259 uint32_t RESERVED1[55U];
1260 __IOM uint32_t SPPR;
1261 uint32_t RESERVED2[131U];
1263 __IOM uint32_t FFCR;
1265 uint32_t RESERVED3[759U];
1266 __IM uint32_t TRIGGER;
1267 __IM uint32_t FIFO0;
1268 __IM uint32_t ITATBCTR2;
1269 uint32_t RESERVED4[1U];
1270 __IM uint32_t ITATBCTR0;
1271 __IM uint32_t FIFO1;
1272 __IOM uint32_t ITCTRL;
1273 uint32_t RESERVED5[39U];
1274 __IOM uint32_t CLAIMSET;
1275 __IOM uint32_t CLAIMCLR;
1276 uint32_t RESERVED7[8U];
1277 __IM uint32_t DEVID;
1278 __IM uint32_t DEVTYPE;
1282 #define TPI_ACPR_PRESCALER_Pos 0U 1283 #define TPI_ACPR_PRESCALER_Msk (0x1FFFUL ) 1286 #define TPI_SPPR_TXMODE_Pos 0U 1287 #define TPI_SPPR_TXMODE_Msk (0x3UL ) 1290 #define TPI_FFSR_FtNonStop_Pos 3U 1291 #define TPI_FFSR_FtNonStop_Msk (0x1UL << TPI_FFSR_FtNonStop_Pos) 1293 #define TPI_FFSR_TCPresent_Pos 2U 1294 #define TPI_FFSR_TCPresent_Msk (0x1UL << TPI_FFSR_TCPresent_Pos) 1296 #define TPI_FFSR_FtStopped_Pos 1U 1297 #define TPI_FFSR_FtStopped_Msk (0x1UL << TPI_FFSR_FtStopped_Pos) 1299 #define TPI_FFSR_FlInProg_Pos 0U 1300 #define TPI_FFSR_FlInProg_Msk (0x1UL ) 1303 #define TPI_FFCR_TrigIn_Pos 8U 1304 #define TPI_FFCR_TrigIn_Msk (0x1UL << TPI_FFCR_TrigIn_Pos) 1306 #define TPI_FFCR_EnFCont_Pos 1U 1307 #define TPI_FFCR_EnFCont_Msk (0x1UL << TPI_FFCR_EnFCont_Pos) 1310 #define TPI_TRIGGER_TRIGGER_Pos 0U 1311 #define TPI_TRIGGER_TRIGGER_Msk (0x1UL ) 1314 #define TPI_FIFO0_ITM_ATVALID_Pos 29U 1315 #define TPI_FIFO0_ITM_ATVALID_Msk (0x3UL << TPI_FIFO0_ITM_ATVALID_Pos) 1317 #define TPI_FIFO0_ITM_bytecount_Pos 27U 1318 #define TPI_FIFO0_ITM_bytecount_Msk (0x3UL << TPI_FIFO0_ITM_bytecount_Pos) 1320 #define TPI_FIFO0_ETM_ATVALID_Pos 26U 1321 #define TPI_FIFO0_ETM_ATVALID_Msk (0x3UL << TPI_FIFO0_ETM_ATVALID_Pos) 1323 #define TPI_FIFO0_ETM_bytecount_Pos 24U 1324 #define TPI_FIFO0_ETM_bytecount_Msk (0x3UL << TPI_FIFO0_ETM_bytecount_Pos) 1326 #define TPI_FIFO0_ETM2_Pos 16U 1327 #define TPI_FIFO0_ETM2_Msk (0xFFUL << TPI_FIFO0_ETM2_Pos) 1329 #define TPI_FIFO0_ETM1_Pos 8U 1330 #define TPI_FIFO0_ETM1_Msk (0xFFUL << TPI_FIFO0_ETM1_Pos) 1332 #define TPI_FIFO0_ETM0_Pos 0U 1333 #define TPI_FIFO0_ETM0_Msk (0xFFUL ) 1336 #define TPI_ITATBCTR2_ATREADY_Pos 0U 1337 #define TPI_ITATBCTR2_ATREADY_Msk (0x1UL ) 1340 #define TPI_FIFO1_ITM_ATVALID_Pos 29U 1341 #define TPI_FIFO1_ITM_ATVALID_Msk (0x3UL << TPI_FIFO1_ITM_ATVALID_Pos) 1343 #define TPI_FIFO1_ITM_bytecount_Pos 27U 1344 #define TPI_FIFO1_ITM_bytecount_Msk (0x3UL << TPI_FIFO1_ITM_bytecount_Pos) 1346 #define TPI_FIFO1_ETM_ATVALID_Pos 26U 1347 #define TPI_FIFO1_ETM_ATVALID_Msk (0x3UL << TPI_FIFO1_ETM_ATVALID_Pos) 1349 #define TPI_FIFO1_ETM_bytecount_Pos 24U 1350 #define TPI_FIFO1_ETM_bytecount_Msk (0x3UL << TPI_FIFO1_ETM_bytecount_Pos) 1352 #define TPI_FIFO1_ITM2_Pos 16U 1353 #define TPI_FIFO1_ITM2_Msk (0xFFUL << TPI_FIFO1_ITM2_Pos) 1355 #define TPI_FIFO1_ITM1_Pos 8U 1356 #define TPI_FIFO1_ITM1_Msk (0xFFUL << TPI_FIFO1_ITM1_Pos) 1358 #define TPI_FIFO1_ITM0_Pos 0U 1359 #define TPI_FIFO1_ITM0_Msk (0xFFUL ) 1362 #define TPI_ITATBCTR0_ATREADY_Pos 0U 1363 #define TPI_ITATBCTR0_ATREADY_Msk (0x1UL ) 1366 #define TPI_ITCTRL_Mode_Pos 0U 1367 #define TPI_ITCTRL_Mode_Msk (0x1UL ) 1370 #define TPI_DEVID_NRZVALID_Pos 11U 1371 #define TPI_DEVID_NRZVALID_Msk (0x1UL << TPI_DEVID_NRZVALID_Pos) 1373 #define TPI_DEVID_MANCVALID_Pos 10U 1374 #define TPI_DEVID_MANCVALID_Msk (0x1UL << TPI_DEVID_MANCVALID_Pos) 1376 #define TPI_DEVID_PTINVALID_Pos 9U 1377 #define TPI_DEVID_PTINVALID_Msk (0x1UL << TPI_DEVID_PTINVALID_Pos) 1379 #define TPI_DEVID_MinBufSz_Pos 6U 1380 #define TPI_DEVID_MinBufSz_Msk (0x7UL << TPI_DEVID_MinBufSz_Pos) 1382 #define TPI_DEVID_AsynClkIn_Pos 5U 1383 #define TPI_DEVID_AsynClkIn_Msk (0x1UL << TPI_DEVID_AsynClkIn_Pos) 1385 #define TPI_DEVID_NrTraceInput_Pos 0U 1386 #define TPI_DEVID_NrTraceInput_Msk (0x1FUL ) 1389 #define TPI_DEVTYPE_MajorType_Pos 4U 1390 #define TPI_DEVTYPE_MajorType_Msk (0xFUL << TPI_DEVTYPE_MajorType_Pos) 1392 #define TPI_DEVTYPE_SubType_Pos 0U 1393 #define TPI_DEVTYPE_SubType_Msk (0xFUL ) 1398 #if (__MPU_PRESENT == 1U) 1412 __IOM uint32_t CTRL;
1414 __IOM uint32_t RBAR;
1415 __IOM uint32_t RASR;
1416 __IOM uint32_t RBAR_A1;
1417 __IOM uint32_t RASR_A1;
1418 __IOM uint32_t RBAR_A2;
1419 __IOM uint32_t RASR_A2;
1420 __IOM uint32_t RBAR_A3;
1421 __IOM uint32_t RASR_A3;
1425 #define MPU_TYPE_IREGION_Pos 16U 1426 #define MPU_TYPE_IREGION_Msk (0xFFUL << MPU_TYPE_IREGION_Pos) 1428 #define MPU_TYPE_DREGION_Pos 8U 1429 #define MPU_TYPE_DREGION_Msk (0xFFUL << MPU_TYPE_DREGION_Pos) 1431 #define MPU_TYPE_SEPARATE_Pos 0U 1432 #define MPU_TYPE_SEPARATE_Msk (1UL ) 1435 #define MPU_CTRL_PRIVDEFENA_Pos 2U 1436 #define MPU_CTRL_PRIVDEFENA_Msk (1UL << MPU_CTRL_PRIVDEFENA_Pos) 1438 #define MPU_CTRL_HFNMIENA_Pos 1U 1439 #define MPU_CTRL_HFNMIENA_Msk (1UL << MPU_CTRL_HFNMIENA_Pos) 1441 #define MPU_CTRL_ENABLE_Pos 0U 1442 #define MPU_CTRL_ENABLE_Msk (1UL ) 1445 #define MPU_RNR_REGION_Pos 0U 1446 #define MPU_RNR_REGION_Msk (0xFFUL ) 1449 #define MPU_RBAR_ADDR_Pos 5U 1450 #define MPU_RBAR_ADDR_Msk (0x7FFFFFFUL << MPU_RBAR_ADDR_Pos) 1452 #define MPU_RBAR_VALID_Pos 4U 1453 #define MPU_RBAR_VALID_Msk (1UL << MPU_RBAR_VALID_Pos) 1455 #define MPU_RBAR_REGION_Pos 0U 1456 #define MPU_RBAR_REGION_Msk (0xFUL ) 1459 #define MPU_RASR_ATTRS_Pos 16U 1460 #define MPU_RASR_ATTRS_Msk (0xFFFFUL << MPU_RASR_ATTRS_Pos) 1462 #define MPU_RASR_XN_Pos 28U 1463 #define MPU_RASR_XN_Msk (1UL << MPU_RASR_XN_Pos) 1465 #define MPU_RASR_AP_Pos 24U 1466 #define MPU_RASR_AP_Msk (0x7UL << MPU_RASR_AP_Pos) 1468 #define MPU_RASR_TEX_Pos 19U 1469 #define MPU_RASR_TEX_Msk (0x7UL << MPU_RASR_TEX_Pos) 1471 #define MPU_RASR_S_Pos 18U 1472 #define MPU_RASR_S_Msk (1UL << MPU_RASR_S_Pos) 1474 #define MPU_RASR_C_Pos 17U 1475 #define MPU_RASR_C_Msk (1UL << MPU_RASR_C_Pos) 1477 #define MPU_RASR_B_Pos 16U 1478 #define MPU_RASR_B_Msk (1UL << MPU_RASR_B_Pos) 1480 #define MPU_RASR_SRD_Pos 8U 1481 #define MPU_RASR_SRD_Msk (0xFFUL << MPU_RASR_SRD_Pos) 1483 #define MPU_RASR_SIZE_Pos 1U 1484 #define MPU_RASR_SIZE_Msk (0x1FUL << MPU_RASR_SIZE_Pos) 1486 #define MPU_RASR_ENABLE_Pos 0U 1487 #define MPU_RASR_ENABLE_Msk (1UL ) 1493 #if (__FPU_PRESENT == 1U) 1506 uint32_t RESERVED0[1U];
1507 __IOM uint32_t FPCCR;
1508 __IOM uint32_t FPCAR;
1509 __IOM uint32_t FPDSCR;
1510 __IM uint32_t MVFR0;
1511 __IM uint32_t MVFR1;
1512 __IM uint32_t MVFR2;
1516 #define FPU_FPCCR_ASPEN_Pos 31U 1517 #define FPU_FPCCR_ASPEN_Msk (1UL << FPU_FPCCR_ASPEN_Pos) 1519 #define FPU_FPCCR_LSPEN_Pos 30U 1520 #define FPU_FPCCR_LSPEN_Msk (1UL << FPU_FPCCR_LSPEN_Pos) 1522 #define FPU_FPCCR_MONRDY_Pos 8U 1523 #define FPU_FPCCR_MONRDY_Msk (1UL << FPU_FPCCR_MONRDY_Pos) 1525 #define FPU_FPCCR_BFRDY_Pos 6U 1526 #define FPU_FPCCR_BFRDY_Msk (1UL << FPU_FPCCR_BFRDY_Pos) 1528 #define FPU_FPCCR_MMRDY_Pos 5U 1529 #define FPU_FPCCR_MMRDY_Msk (1UL << FPU_FPCCR_MMRDY_Pos) 1531 #define FPU_FPCCR_HFRDY_Pos 4U 1532 #define FPU_FPCCR_HFRDY_Msk (1UL << FPU_FPCCR_HFRDY_Pos) 1534 #define FPU_FPCCR_THREAD_Pos 3U 1535 #define FPU_FPCCR_THREAD_Msk (1UL << FPU_FPCCR_THREAD_Pos) 1537 #define FPU_FPCCR_USER_Pos 1U 1538 #define FPU_FPCCR_USER_Msk (1UL << FPU_FPCCR_USER_Pos) 1540 #define FPU_FPCCR_LSPACT_Pos 0U 1541 #define FPU_FPCCR_LSPACT_Msk (1UL ) 1544 #define FPU_FPCAR_ADDRESS_Pos 3U 1545 #define FPU_FPCAR_ADDRESS_Msk (0x1FFFFFFFUL << FPU_FPCAR_ADDRESS_Pos) 1548 #define FPU_FPDSCR_AHP_Pos 26U 1549 #define FPU_FPDSCR_AHP_Msk (1UL << FPU_FPDSCR_AHP_Pos) 1551 #define FPU_FPDSCR_DN_Pos 25U 1552 #define FPU_FPDSCR_DN_Msk (1UL << FPU_FPDSCR_DN_Pos) 1554 #define FPU_FPDSCR_FZ_Pos 24U 1555 #define FPU_FPDSCR_FZ_Msk (1UL << FPU_FPDSCR_FZ_Pos) 1557 #define FPU_FPDSCR_RMode_Pos 22U 1558 #define FPU_FPDSCR_RMode_Msk (3UL << FPU_FPDSCR_RMode_Pos) 1561 #define FPU_MVFR0_FP_rounding_modes_Pos 28U 1562 #define FPU_MVFR0_FP_rounding_modes_Msk (0xFUL << FPU_MVFR0_FP_rounding_modes_Pos) 1564 #define FPU_MVFR0_Short_vectors_Pos 24U 1565 #define FPU_MVFR0_Short_vectors_Msk (0xFUL << FPU_MVFR0_Short_vectors_Pos) 1567 #define FPU_MVFR0_Square_root_Pos 20U 1568 #define FPU_MVFR0_Square_root_Msk (0xFUL << FPU_MVFR0_Square_root_Pos) 1570 #define FPU_MVFR0_Divide_Pos 16U 1571 #define FPU_MVFR0_Divide_Msk (0xFUL << FPU_MVFR0_Divide_Pos) 1573 #define FPU_MVFR0_FP_excep_trapping_Pos 12U 1574 #define FPU_MVFR0_FP_excep_trapping_Msk (0xFUL << FPU_MVFR0_FP_excep_trapping_Pos) 1576 #define FPU_MVFR0_Double_precision_Pos 8U 1577 #define FPU_MVFR0_Double_precision_Msk (0xFUL << FPU_MVFR0_Double_precision_Pos) 1579 #define FPU_MVFR0_Single_precision_Pos 4U 1580 #define FPU_MVFR0_Single_precision_Msk (0xFUL << FPU_MVFR0_Single_precision_Pos) 1582 #define FPU_MVFR0_A_SIMD_registers_Pos 0U 1583 #define FPU_MVFR0_A_SIMD_registers_Msk (0xFUL ) 1586 #define FPU_MVFR1_FP_fused_MAC_Pos 28U 1587 #define FPU_MVFR1_FP_fused_MAC_Msk (0xFUL << FPU_MVFR1_FP_fused_MAC_Pos) 1589 #define FPU_MVFR1_FP_HPFP_Pos 24U 1590 #define FPU_MVFR1_FP_HPFP_Msk (0xFUL << FPU_MVFR1_FP_HPFP_Pos) 1592 #define FPU_MVFR1_D_NaN_mode_Pos 4U 1593 #define FPU_MVFR1_D_NaN_mode_Msk (0xFUL << FPU_MVFR1_D_NaN_mode_Pos) 1595 #define FPU_MVFR1_FtZ_mode_Pos 0U 1596 #define FPU_MVFR1_FtZ_mode_Msk (0xFUL ) 1616 __IOM uint32_t DHCSR;
1617 __OM uint32_t DCRSR;
1618 __IOM uint32_t DCRDR;
1619 __IOM uint32_t DEMCR;
1623 #define CoreDebug_DHCSR_DBGKEY_Pos 16U 1624 #define CoreDebug_DHCSR_DBGKEY_Msk (0xFFFFUL << CoreDebug_DHCSR_DBGKEY_Pos) 1626 #define CoreDebug_DHCSR_S_RESET_ST_Pos 25U 1627 #define CoreDebug_DHCSR_S_RESET_ST_Msk (1UL << CoreDebug_DHCSR_S_RESET_ST_Pos) 1629 #define CoreDebug_DHCSR_S_RETIRE_ST_Pos 24U 1630 #define CoreDebug_DHCSR_S_RETIRE_ST_Msk (1UL << CoreDebug_DHCSR_S_RETIRE_ST_Pos) 1632 #define CoreDebug_DHCSR_S_LOCKUP_Pos 19U 1633 #define CoreDebug_DHCSR_S_LOCKUP_Msk (1UL << CoreDebug_DHCSR_S_LOCKUP_Pos) 1635 #define CoreDebug_DHCSR_S_SLEEP_Pos 18U 1636 #define CoreDebug_DHCSR_S_SLEEP_Msk (1UL << CoreDebug_DHCSR_S_SLEEP_Pos) 1638 #define CoreDebug_DHCSR_S_HALT_Pos 17U 1639 #define CoreDebug_DHCSR_S_HALT_Msk (1UL << CoreDebug_DHCSR_S_HALT_Pos) 1641 #define CoreDebug_DHCSR_S_REGRDY_Pos 16U 1642 #define CoreDebug_DHCSR_S_REGRDY_Msk (1UL << CoreDebug_DHCSR_S_REGRDY_Pos) 1644 #define CoreDebug_DHCSR_C_SNAPSTALL_Pos 5U 1645 #define CoreDebug_DHCSR_C_SNAPSTALL_Msk (1UL << CoreDebug_DHCSR_C_SNAPSTALL_Pos) 1647 #define CoreDebug_DHCSR_C_MASKINTS_Pos 3U 1648 #define CoreDebug_DHCSR_C_MASKINTS_Msk (1UL << CoreDebug_DHCSR_C_MASKINTS_Pos) 1650 #define CoreDebug_DHCSR_C_STEP_Pos 2U 1651 #define CoreDebug_DHCSR_C_STEP_Msk (1UL << CoreDebug_DHCSR_C_STEP_Pos) 1653 #define CoreDebug_DHCSR_C_HALT_Pos 1U 1654 #define CoreDebug_DHCSR_C_HALT_Msk (1UL << CoreDebug_DHCSR_C_HALT_Pos) 1656 #define CoreDebug_DHCSR_C_DEBUGEN_Pos 0U 1657 #define CoreDebug_DHCSR_C_DEBUGEN_Msk (1UL ) 1660 #define CoreDebug_DCRSR_REGWnR_Pos 16U 1661 #define CoreDebug_DCRSR_REGWnR_Msk (1UL << CoreDebug_DCRSR_REGWnR_Pos) 1663 #define CoreDebug_DCRSR_REGSEL_Pos 0U 1664 #define CoreDebug_DCRSR_REGSEL_Msk (0x1FUL ) 1667 #define CoreDebug_DEMCR_TRCENA_Pos 24U 1668 #define CoreDebug_DEMCR_TRCENA_Msk (1UL << CoreDebug_DEMCR_TRCENA_Pos) 1670 #define CoreDebug_DEMCR_MON_REQ_Pos 19U 1671 #define CoreDebug_DEMCR_MON_REQ_Msk (1UL << CoreDebug_DEMCR_MON_REQ_Pos) 1673 #define CoreDebug_DEMCR_MON_STEP_Pos 18U 1674 #define CoreDebug_DEMCR_MON_STEP_Msk (1UL << CoreDebug_DEMCR_MON_STEP_Pos) 1676 #define CoreDebug_DEMCR_MON_PEND_Pos 17U 1677 #define CoreDebug_DEMCR_MON_PEND_Msk (1UL << CoreDebug_DEMCR_MON_PEND_Pos) 1679 #define CoreDebug_DEMCR_MON_EN_Pos 16U 1680 #define CoreDebug_DEMCR_MON_EN_Msk (1UL << CoreDebug_DEMCR_MON_EN_Pos) 1682 #define CoreDebug_DEMCR_VC_HARDERR_Pos 10U 1683 #define CoreDebug_DEMCR_VC_HARDERR_Msk (1UL << CoreDebug_DEMCR_VC_HARDERR_Pos) 1685 #define CoreDebug_DEMCR_VC_INTERR_Pos 9U 1686 #define CoreDebug_DEMCR_VC_INTERR_Msk (1UL << CoreDebug_DEMCR_VC_INTERR_Pos) 1688 #define CoreDebug_DEMCR_VC_BUSERR_Pos 8U 1689 #define CoreDebug_DEMCR_VC_BUSERR_Msk (1UL << CoreDebug_DEMCR_VC_BUSERR_Pos) 1691 #define CoreDebug_DEMCR_VC_STATERR_Pos 7U 1692 #define CoreDebug_DEMCR_VC_STATERR_Msk (1UL << CoreDebug_DEMCR_VC_STATERR_Pos) 1694 #define CoreDebug_DEMCR_VC_CHKERR_Pos 6U 1695 #define CoreDebug_DEMCR_VC_CHKERR_Msk (1UL << CoreDebug_DEMCR_VC_CHKERR_Pos) 1697 #define CoreDebug_DEMCR_VC_NOCPERR_Pos 5U 1698 #define CoreDebug_DEMCR_VC_NOCPERR_Msk (1UL << CoreDebug_DEMCR_VC_NOCPERR_Pos) 1700 #define CoreDebug_DEMCR_VC_MMERR_Pos 4U 1701 #define CoreDebug_DEMCR_VC_MMERR_Msk (1UL << CoreDebug_DEMCR_VC_MMERR_Pos) 1703 #define CoreDebug_DEMCR_VC_CORERESET_Pos 0U 1704 #define CoreDebug_DEMCR_VC_CORERESET_Msk (1UL ) 1722 #define _VAL2FLD(field, value) ((value << field ## _Pos) & field ## _Msk) 1730 #define _FLD2VAL(field, value) ((value & field ## _Msk) >> field ## _Pos) 1743 #define SCS_BASE (0xE000E000UL) 1744 #define ITM_BASE (0xE0000000UL) 1745 #define DWT_BASE (0xE0001000UL) 1746 #define TPI_BASE (0xE0040000UL) 1747 #define CoreDebug_BASE (0xE000EDF0UL) 1748 #define SysTick_BASE (SCS_BASE + 0x0010UL) 1749 #define NVIC_BASE (SCS_BASE + 0x0100UL) 1750 #define SCB_BASE (SCS_BASE + 0x0D00UL) 1752 #define SCnSCB ((SCnSCB_Type *) SCS_BASE ) 1753 #define SCB ((SCB_Type *) SCB_BASE ) 1754 #define SysTick ((SysTick_Type *) SysTick_BASE ) 1755 #define NVIC ((NVIC_Type *) NVIC_BASE ) 1756 #define ITM ((ITM_Type *) ITM_BASE ) 1757 #define DWT ((DWT_Type *) DWT_BASE ) 1758 #define TPI ((TPI_Type *) TPI_BASE ) 1759 #define CoreDebug ((CoreDebug_Type *) CoreDebug_BASE) 1761 #if (__MPU_PRESENT == 1U) 1762 #define MPU_BASE (SCS_BASE + 0x0D90UL) 1763 #define MPU ((MPU_Type *) MPU_BASE ) 1766 #if (__FPU_PRESENT == 1U) 1767 #define FPU_BASE (SCS_BASE + 0x0F30UL) 1768 #define FPU ((FPU_Type *) FPU_BASE ) 1810 uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL);
1812 reg_value =
SCB->AIRCR;
1814 reg_value = (reg_value |
1816 (PriorityGroupTmp << 8U) );
1817 SCB->AIRCR = reg_value;
1839 NVIC->ISER[(((uint32_t)(int32_t)
IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)
IRQn) & 0x1FUL));
1850 NVIC->ICER[(((uint32_t)(int32_t)
IRQn) & 0x1FUL));
1863 return((uint32_t)(((
NVIC->ISPR[(((uint32_t)(int32_t)
IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)
IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
1874 NVIC->ISPR[(((uint32_t)(int32_t)
IRQn) & 0x1FUL));
1885 NVIC->ICPR[(((uint32_t)(int32_t)
IRQn) & 0x1FUL));
1898 return((uint32_t)(((
NVIC->IABR[(((uint32_t)(int32_t)
1911 if ((int32_t)(
IRQn) < 0)
1913 SCB->SHPR[(((uint32_t)(int32_t)
IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U -
__NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
1934 if ((int32_t)(
IRQn) < 0)
1956 __STATIC_INLINE uint32_t
NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
1958 uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL);
1959 uint32_t PreemptPriorityBits;
1960 uint32_t SubPriorityBits;
1963 SubPriorityBits = ((PriorityGroupTmp + (uint32_t)(
__NVIC_PRIO_BITS)) < (uint32_t)7UL) ? (uint32_t)0UL : (uint32_t)((PriorityGroupTmp - 7UL) + (uint32_t)(
__NVIC_PRIO_BITS));
1966 ((PreemptPriority & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL)) << SubPriorityBits) |
1967 ((SubPriority & (uint32_t)((1UL << (SubPriorityBits )) - 1UL)))
1983 __STATIC_INLINE
void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t*
const pPreemptPriority, uint32_t*
const pSubPriority)
1985 uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL);
1986 uint32_t PreemptPriorityBits;
1987 uint32_t SubPriorityBits;
1990 SubPriorityBits = ((PriorityGroupTmp + (uint32_t)(
__NVIC_PRIO_BITS));
1992 *pPreemptPriority = (Priority >> SubPriorityBits) & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL);
1993 *pSubPriority = (Priority ) & (uint32_t)((1UL << (SubPriorityBits )) - 1UL);
2040 if ((mvfr0 & 0x00000FF0UL) == 0x220UL)
2044 else if ((mvfr0 & 0x00000FF0UL) == 0x020UL)
2068 #define CCSIDR_WAYS(x) (((x) & SCB_CCSIDR_ASSOCIATIVITY_Msk) >> SCB_CCSIDR_ASSOCIATIVITY_Pos) 2069 #define CCSIDR_SETS(x) (((x) & SCB_CCSIDR_NUMSETS_Msk ) >> SCB_CCSIDR_NUMSETS_Pos ) 2078 #if (__ICACHE_PRESENT == 1U) 2095 #if (__ICACHE_PRESENT == 1U) 2112 #if (__ICACHE_PRESENT == 1U) 2128 #if (__DCACHE_PRESENT == 1U) 2133 SCB->CSSELR = (0U << 1U) | 0U;
2136 ccsidr =
SCB->CCSIDR;
2139 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2141 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2145 #if defined ( __CC_ARM ) 2146 __schedule_barrier();
2166 #if (__DCACHE_PRESENT == 1U) 2171 SCB->CSSELR = (0U << 1U) | 0U;
2174 ccsidr =
SCB->CCSIDR;
2179 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2181 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2185 #if defined ( __CC_ARM ) 2186 __schedule_barrier();
2203 #if (__DCACHE_PRESENT == 1U) 2208 SCB->CSSELR = (0U << 1U) | 0U;
2211 ccsidr =
SCB->CCSIDR;
2214 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2216 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2220 #if defined ( __CC_ARM ) 2221 __schedule_barrier();
2238 #if (__DCACHE_PRESENT == 1U) 2243 SCB->CSSELR = (0U << 1U) | 0U;
2246 ccsidr =
SCB->CCSIDR;
2249 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2251 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2255 #if defined ( __CC_ARM ) 2256 __schedule_barrier();
2273 #if (__DCACHE_PRESENT == 1U) 2278 SCB->CSSELR = (0U << 1U) | 0U;
2281 ccsidr =
SCB->CCSIDR;
2284 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2286 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2290 #if defined ( __CC_ARM ) 2291 __schedule_barrier();
2310 #if (__DCACHE_PRESENT == 1U) 2311 int32_t op_size = dsize;
2312 uint32_t op_addr = (uint32_t)addr;
2313 int32_t linesize = 32U;
2317 while (op_size > 0) {
2318 SCB->DCIMVAC = op_addr;
2319 op_addr += linesize;
2320 op_size -= linesize;
2337 #if (__DCACHE_PRESENT == 1) 2338 int32_t op_size = dsize;
2339 uint32_t op_addr = (uint32_t) addr;
2340 int32_t linesize = 32U;
2344 while (op_size > 0) {
2345 SCB->DCCMVAC = op_addr;
2346 op_addr += linesize;
2347 op_size -= linesize;
2364 #if (__DCACHE_PRESENT == 1U) 2365 int32_t op_size = dsize;
2366 uint32_t op_addr = (uint32_t) addr;
2367 int32_t linesize = 32U;
2371 while (op_size > 0) {
2372 SCB->DCCIMVAC = op_addr;
2373 op_addr += linesize;
2374 op_size -= linesize;
2395 #if (__Vendor_SysTickConfig == 0U) 2415 SysTick->LOAD = (uint32_t)(ticks - 1UL);
2439 #define ITM_RXBUFFER_EMPTY 0x5AA55AA5U 2450 __STATIC_INLINE uint32_t ITM_SendChar (uint32_t ch) 2453 ((
ITM->TER & 1UL ) != 0UL) )
2455 while (
ITM->PORT[0U].u32 == 0UL)
2459 ITM->PORT[0U].u8 = (uint8_t)ch;
uint32_t Q
Definition: core_cm7.h:392
uint32_t GE
Definition: core_cm7.h:330
__STATIC_INLINE void NVIC_DecodePriority(uint32_t Priority, uint32_t PriorityGroup, uint32_t *const pPreemptPriority, uint32_t *const pSubPriority)
Decode Priority.
Definition: core_cm7.h:1983
uint32_t w
Definition: core_cm7.h:371
Definition: same70j19.h:68
#define TCR
tx configuration reg
Definition: wd80x3.h:99
Definition: core_cm7.h:811
Definition: core_cm7.h:821
uint32_t C
Definition: core_cm7.h:394
CMSIS Cortex-M Core Function Access Header File.
__STATIC_INLINE void SCB_InvalidateICache(void)
Invalidate I-Cache.
Definition: core_cm7.h:2110
__STATIC_INLINE uint32_t SCB_GetFPUType(void)
get FPU type
Definition: core_cm7.h:2035
__STATIC_INLINE int32_t ITM_CheckChar(void)
ITM Check Character.
Definition: core_cm7.h:2491
uint32_t IT
Definition: core_cm7.h:391
__STATIC_INLINE void SCB_DisableDCache(void)
Disable D-Cache.
Definition: core_cm7.h:2164
Definition: core_cm7.h:608
Structure type to access the Nested Vectored Interrupt Controller (NVIC).
Definition: core_cm7.h:468
Definition: core_cm7.h:644
Definition: core_cm7.h:961
Structure type to access the System Control Block (SCB).
Definition: core_cm7.h:502
#define ITM
Definition: core_cm7.h:1756
Structure type to access the Data Watchpoint and Trace Register (DWT).
Definition: core_cm7.h:1103
uint32_t w
Definition: core_cm7.h:442
CMSIS Cortex-M Core Instruction Access Header File.
__STATIC_INLINE void SCB_CleanDCache_by_Addr(uint32_t *addr, int32_t dsize)
D-Cache Clean by address.
Definition: core_cm7.h:2335
Definition: core_cm7.h:818
__STATIC_INLINE uint32_t NVIC_EncodePriority(uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
Encode Priority.
Definition: core_cm7.h:1956
Definition: core_cm7.h:2439
uint32_t _reserved1
Definition: core_cm7.h:331
#define SCR
Scratch register.
Definition: uart.h:94
__STATIC_INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
Set Interrupt Priority.
Definition: core_cm7.h:1909
uint32_t _reserved0
Definition: core_cm7.h:440
Definition: core_cm7.h:817
uint32_t _reserved0
Definition: core_cm7.h:369
__STATIC_INLINE void SCB_EnableDCache(void)
Enable D-Cache.
Definition: core_cm7.h:2126
uint32_t _reserved0
Definition: core_cm7.h:387
__STATIC_INLINE void SCB_DisableICache(void)
Disable I-Cache.
Definition: core_cm7.h:2093
volatile int32_t ITM_RxBuffer
__STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr(uint32_t *addr, int32_t dsize)
D-Cache Clean and Invalidate by address.
Definition: core_cm7.h:2362
uint32_t _reserved0
Definition: core_cm7.h:329
__STATIC_INLINE void SCB_EnableICache(void)
Enable I-Cache.
Definition: core_cm7.h:2076
__STATIC_INLINE void SCB_InvalidateDCache(void)
Invalidate D-Cache.
Definition: core_cm7.h:2201
Definition: core_cm7.h:964
#define SCB
Definition: core_cm7.h:1753
__STATIC_INLINE void NVIC_DisableIRQ(IRQn_Type IRQn)
Disable External Interrupt.
Definition: core_cm7.h:1848
uint32_t ISR
Definition: core_cm7.h:386
uint32_t Z
Definition: core_cm7.h:395
Structure type to access the System Timer (SysTick).
Definition: core_cm7.h:948
Definition: core_cm7.h:813
Structure type to access the Core Debug Register (CoreDebug).
Definition: core_cm7.h:1614
Definition: core_cm7.h:804
CMSIS Cortex-M SIMD Header File.
__STATIC_INLINE void NVIC_SystemReset(void)
System Reset.
Definition: core_cm7.h:2001
Union type to access the Application Program Status Register (APSR).
Definition: core_cm7.h:325
uint32_t V
Definition: core_cm7.h:333
__STATIC_INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
Enable External Interrupt.
Definition: core_cm7.h:1837
Definition: core_cm7.h:609
uint32_t N
Definition: core_cm7.h:396
Definition: same70j19.h:276
__STATIC_INLINE uint32_t NVIC_GetPendingIRQ(IRQn_Type IRQn)
Get Pending Interrupt.
Definition: core_cm7.h:1861
uint32_t V
Definition: core_cm7.h:393
uint32_t C
Definition: core_cm7.h:334
__STATIC_INLINE void SCB_CleanInvalidateDCache(void)
Clean & Invalidate D-Cache.
Definition: core_cm7.h:2271
#define SysTick
Definition: core_cm7.h:1754
Definition: core_cm7.h:814
uint32_t Z
Definition: core_cm7.h:335
uint32_t SPSEL
Definition: core_cm7.h:438
Definition: core_cm7.h:618
uint32_t GE
Definition: core_cm7.h:388
__STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
System Tick Configuration.
Definition: core_cm7.h:2408
Definition: core_cm7.h:803
Definition: core_cm7.h:806
Union type to access the Control Registers (CONTROL).
Definition: core_cm7.h:433
Structure type to access the Trace Port Interface Register (TPI).
Definition: core_cm7.h:1253
#define NVIC
Definition: core_cm7.h:1755
Definition: core_cm7.h:971
Structure type to access the System Control and ID Register not in the SCB.
Definition: core_cm7.h:908
__STATIC_INLINE void NVIC_SetPendingIRQ(IRQn_Type IRQn)
Set Pending Interrupt.
Definition: core_cm7.h:1872
uint32_t _reserved1
Definition: core_cm7.h:389
__STATIC_INLINE void NVIC_ClearPendingIRQ(IRQn_Type IRQn)
Clear Pending Interrupt.
Definition: core_cm7.h:1883
Union type to access the Interrupt Program Status Register (IPSR).
Definition: core_cm7.h:364
__STATIC_INLINE int32_t ITM_ReceiveChar(void)
ITM Receive Character.
Definition: core_cm7.h:2471
Union type to access the Special-Purpose Program Status Registers (xPSR).
Definition: core_cm7.h:382
uint32_t T
Definition: core_cm7.h:390
__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn)
Get Interrupt Priority.
Definition: core_cm7.h:1931
Definition: core_cm7.h:810
uint32_t FPCA
Definition: core_cm7.h:439
Definition: core_cm7.h:967
__STATIC_INLINE void SCB_CleanDCache(void)
Clean D-Cache.
Definition: core_cm7.h:2236
Definition: core_cm7.h:820
Definition: core_cm7.h:647
uint32_t nPRIV
Definition: core_cm7.h:437
uint32_t Q
Definition: core_cm7.h:332
Definition: core_cm7.h:807
__STATIC_INLINE uint32_t NVIC_GetActive(IRQn_Type IRQn)
Get Active Interrupt.
Definition: core_cm7.h:1896
__STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
Set Priority Grouping.
Definition: core_cm7.h:1807
IRQn
Definition: same70j19.h:57
uint32_t w
Definition: core_cm7.h:398
__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping(void)
Get Priority Grouping.
Definition: core_cm7.h:1826
Definition: core_cm7.h:1066
uint32_t N
Definition: core_cm7.h:336
Definition: core_cm7.h:621
uint32_t w
Definition: core_cm7.h:338
__STATIC_INLINE void SCB_InvalidateDCache_by_Addr(uint32_t *addr, int32_t dsize)
D-Cache Invalidate by address.
Definition: core_cm7.h:2308
Structure type to access the Instrumentation Trace Macrocell Register (ITM).
Definition: core_cm7.h:1000
#define LSR
Line Status Register.
Definition: uart.h:92
uint32_t ISR
Definition: core_cm7.h:368
Definition: core_cm7.h:617
