RTEMS
5.1
Type definitions for the Instrumentation Trace Macrocell (ITM) More...
struct | ITM_Type |
Structure type to access the Instrumentation Trace Macrocell Register (ITM). More... | |
#define | ITM_TPR_PRIVMASK_Pos 0U |
#define | ITM_TPR_PRIVMASK_Msk (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/) |
#define | ITM_TCR_BUSY_Pos 23U |
#define | ITM_TCR_BUSY_Msk (1UL << ITM_TCR_BUSY_Pos) |
#define | ITM_TCR_TraceBusID_Pos 16U |
#define | ITM_TCR_TraceBusID_Msk (0x7FUL << ITM_TCR_TraceBusID_Pos) |
#define | ITM_TCR_GTSFREQ_Pos 10U |
#define | ITM_TCR_GTSFREQ_Msk (3UL << ITM_TCR_GTSFREQ_Pos) |
#define | ITM_TCR_TSPrescale_Pos 8U |
#define | ITM_TCR_TSPrescale_Msk (3UL << ITM_TCR_TSPrescale_Pos) |
#define | ITM_TCR_SWOENA_Pos 4U |
#define | ITM_TCR_SWOENA_Msk (1UL << ITM_TCR_SWOENA_Pos) |
#define | ITM_TCR_DWTENA_Pos 3U |
#define | ITM_TCR_DWTENA_Msk (1UL << ITM_TCR_DWTENA_Pos) |
#define | ITM_TCR_SYNCENA_Pos 2U |
#define | ITM_TCR_SYNCENA_Msk (1UL << ITM_TCR_SYNCENA_Pos) |
#define | ITM_TCR_TSENA_Pos 1U |
#define | ITM_TCR_TSENA_Msk (1UL << ITM_TCR_TSENA_Pos) |
#define | ITM_TCR_ITMENA_Pos 0U |
#define | ITM_TCR_ITMENA_Msk (1UL /*<< ITM_TCR_ITMENA_Pos*/) |
#define | ITM_IWR_ATVALIDM_Pos 0U |
#define | ITM_IWR_ATVALIDM_Msk (1UL /*<< ITM_IWR_ATVALIDM_Pos*/) |
#define | ITM_IRR_ATREADYM_Pos 0U |
#define | ITM_IRR_ATREADYM_Msk (1UL /*<< ITM_IRR_ATREADYM_Pos*/) |
#define | ITM_IMCR_INTEGRATION_Pos 0U |
#define | ITM_IMCR_INTEGRATION_Msk (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/) |
#define | ITM_LSR_ByteAcc_Pos 2U |
#define | ITM_LSR_ByteAcc_Msk (1UL << ITM_LSR_ByteAcc_Pos) |
#define | ITM_LSR_Access_Pos 1U |
#define | ITM_LSR_Access_Msk (1UL << ITM_LSR_Access_Pos) |
#define | ITM_LSR_Present_Pos 0U |
#define | ITM_LSR_Present_Msk (1UL /*<< ITM_LSR_Present_Pos*/) |
#define ITM_IMCR_INTEGRATION_Msk (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/) |
ITM IMCR: INTEGRATION Mask
#define ITM_IMCR_INTEGRATION_Pos 0U |
ITM IMCR: INTEGRATION Position
#define ITM_IRR_ATREADYM_Msk (1UL /*<< ITM_IRR_ATREADYM_Pos*/) |
ITM IRR: ATREADYM Mask
#define ITM_IRR_ATREADYM_Pos 0U |
ITM IRR: ATREADYM Position
#define ITM_IWR_ATVALIDM_Msk (1UL /*<< ITM_IWR_ATVALIDM_Pos*/) |
ITM IWR: ATVALIDM Mask
#define ITM_IWR_ATVALIDM_Pos 0U |
ITM IWR: ATVALIDM Position
#define ITM_LSR_Access_Msk (1UL << ITM_LSR_Access_Pos) |
ITM LSR: Access Mask
#define ITM_LSR_Access_Pos 1U |
ITM LSR: Access Position
#define ITM_LSR_ByteAcc_Msk (1UL << ITM_LSR_ByteAcc_Pos) |
ITM LSR: ByteAcc Mask
#define ITM_LSR_ByteAcc_Pos 2U |
ITM LSR: ByteAcc Position
#define ITM_LSR_Present_Msk (1UL /*<< ITM_LSR_Present_Pos*/) |
ITM LSR: Present Mask
#define ITM_LSR_Present_Pos 0U |
ITM LSR: Present Position
#define ITM_TCR_BUSY_Msk (1UL << ITM_TCR_BUSY_Pos) |
ITM TCR: BUSY Mask
#define ITM_TCR_BUSY_Pos 23U |
ITM TCR: BUSY Position
#define ITM_TCR_DWTENA_Msk (1UL << ITM_TCR_DWTENA_Pos) |
ITM TCR: DWTENA Mask
#define ITM_TCR_DWTENA_Pos 3U |
ITM TCR: DWTENA Position
#define ITM_TCR_GTSFREQ_Msk (3UL << ITM_TCR_GTSFREQ_Pos) |
ITM TCR: Global timestamp frequency Mask
#define ITM_TCR_GTSFREQ_Pos 10U |
ITM TCR: Global timestamp frequency Position
#define ITM_TCR_ITMENA_Msk (1UL /*<< ITM_TCR_ITMENA_Pos*/) |
ITM TCR: ITM Enable bit Mask
#define ITM_TCR_ITMENA_Pos 0U |
ITM TCR: ITM Enable bit Position
#define ITM_TCR_SWOENA_Msk (1UL << ITM_TCR_SWOENA_Pos) |
ITM TCR: SWOENA Mask
#define ITM_TCR_SWOENA_Pos 4U |
ITM TCR: SWOENA Position
#define ITM_TCR_SYNCENA_Msk (1UL << ITM_TCR_SYNCENA_Pos) |
ITM TCR: SYNCENA Mask
#define ITM_TCR_SYNCENA_Pos 2U |
ITM TCR: SYNCENA Position
#define ITM_TCR_TraceBusID_Msk (0x7FUL << ITM_TCR_TraceBusID_Pos) |
ITM TCR: ATBID Mask
#define ITM_TCR_TraceBusID_Pos 16U |
ITM TCR: ATBID Position
#define ITM_TCR_TSENA_Msk (1UL << ITM_TCR_TSENA_Pos) |
ITM TCR: TSENA Mask
#define ITM_TCR_TSENA_Pos 1U |
ITM TCR: TSENA Position
#define ITM_TCR_TSPrescale_Msk (3UL << ITM_TCR_TSPrescale_Pos) |
ITM TCR: TSPrescale Mask
#define ITM_TCR_TSPrescale_Pos 8U |
ITM TCR: TSPrescale Position
#define ITM_TPR_PRIVMASK_Msk (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/) |
ITM TPR: PRIVMASK Mask
#define ITM_TPR_PRIVMASK_Pos 0U |
ITM TPR: PRIVMASK Position
