RTEMS  5.1
Data Structures | Macros
Type definitions for the Trace Port Interface (TPI) More...
struct  TPI_Type
 Structure type to access the Trace Port Interface Register (TPI). More...
#define TPI_ACPR_PRESCALER_Pos   0U
#define TPI_ACPR_PRESCALER_Msk   (0x1FFFUL /*<< TPI_ACPR_PRESCALER_Pos*/)
#define TPI_SPPR_TXMODE_Pos   0U
#define TPI_SPPR_TXMODE_Msk   (0x3UL /*<< TPI_SPPR_TXMODE_Pos*/)
#define TPI_FFSR_FtNonStop_Pos   3U
#define TPI_FFSR_FtNonStop_Msk   (0x1UL << TPI_FFSR_FtNonStop_Pos)
#define TPI_FFSR_TCPresent_Pos   2U
#define TPI_FFSR_TCPresent_Msk   (0x1UL << TPI_FFSR_TCPresent_Pos)
#define TPI_FFSR_FtStopped_Pos   1U
#define TPI_FFSR_FtStopped_Msk   (0x1UL << TPI_FFSR_FtStopped_Pos)
#define TPI_FFSR_FlInProg_Pos   0U
#define TPI_FFSR_FlInProg_Msk   (0x1UL /*<< TPI_FFSR_FlInProg_Pos*/)
#define TPI_FFCR_TrigIn_Pos   8U
#define TPI_FFCR_TrigIn_Msk   (0x1UL << TPI_FFCR_TrigIn_Pos)
#define TPI_FFCR_EnFCont_Pos   1U
#define TPI_FFCR_EnFCont_Msk   (0x1UL << TPI_FFCR_EnFCont_Pos)
#define TPI_TRIGGER_TRIGGER_Pos   0U
#define TPI_TRIGGER_TRIGGER_Msk   (0x1UL /*<< TPI_TRIGGER_TRIGGER_Pos*/)
#define TPI_FIFO0_ITM_ATVALID_Pos   29U
#define TPI_FIFO0_ITM_ATVALID_Msk   (0x3UL << TPI_FIFO0_ITM_ATVALID_Pos)
#define TPI_FIFO0_ITM_bytecount_Pos   27U
#define TPI_FIFO0_ITM_bytecount_Msk   (0x3UL << TPI_FIFO0_ITM_bytecount_Pos)
#define TPI_FIFO0_ETM_ATVALID_Pos   26U
#define TPI_FIFO0_ETM_ATVALID_Msk   (0x3UL << TPI_FIFO0_ETM_ATVALID_Pos)
#define TPI_FIFO0_ETM_bytecount_Pos   24U
#define TPI_FIFO0_ETM_bytecount_Msk   (0x3UL << TPI_FIFO0_ETM_bytecount_Pos)
#define TPI_FIFO0_ETM2_Pos   16U
#define TPI_FIFO0_ETM2_Msk   (0xFFUL << TPI_FIFO0_ETM2_Pos)
#define TPI_FIFO0_ETM1_Pos   8U
#define TPI_FIFO0_ETM1_Msk   (0xFFUL << TPI_FIFO0_ETM1_Pos)
#define TPI_FIFO0_ETM0_Pos   0U
#define TPI_FIFO0_ETM0_Msk   (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/)
#define TPI_ITATBCTR2_ATREADY_Pos   0U
#define TPI_ITATBCTR2_ATREADY_Msk   (0x1UL /*<< TPI_ITATBCTR2_ATREADY_Pos*/)
#define TPI_FIFO1_ITM_ATVALID_Pos   29U
#define TPI_FIFO1_ITM_ATVALID_Msk   (0x3UL << TPI_FIFO1_ITM_ATVALID_Pos)
#define TPI_FIFO1_ITM_bytecount_Pos   27U
#define TPI_FIFO1_ITM_bytecount_Msk   (0x3UL << TPI_FIFO1_ITM_bytecount_Pos)
#define TPI_FIFO1_ETM_ATVALID_Pos   26U
#define TPI_FIFO1_ETM_ATVALID_Msk   (0x3UL << TPI_FIFO1_ETM_ATVALID_Pos)
#define TPI_FIFO1_ETM_bytecount_Pos   24U
#define TPI_FIFO1_ETM_bytecount_Msk   (0x3UL << TPI_FIFO1_ETM_bytecount_Pos)
#define TPI_FIFO1_ITM2_Pos   16U
#define TPI_FIFO1_ITM2_Msk   (0xFFUL << TPI_FIFO1_ITM2_Pos)
#define TPI_FIFO1_ITM1_Pos   8U
#define TPI_FIFO1_ITM1_Msk   (0xFFUL << TPI_FIFO1_ITM1_Pos)
#define TPI_FIFO1_ITM0_Pos   0U
#define TPI_FIFO1_ITM0_Msk   (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/)
#define TPI_ITATBCTR0_ATREADY_Pos   0U
#define TPI_ITATBCTR0_ATREADY_Msk   (0x1UL /*<< TPI_ITATBCTR0_ATREADY_Pos*/)
#define TPI_ITCTRL_Mode_Pos   0U
#define TPI_ITCTRL_Mode_Msk   (0x1UL /*<< TPI_ITCTRL_Mode_Pos*/)
#define TPI_DEVID_NRZVALID_Pos   11U
#define TPI_DEVID_NRZVALID_Msk   (0x1UL << TPI_DEVID_NRZVALID_Pos)
#define TPI_DEVID_MANCVALID_Pos   10U
#define TPI_DEVID_MANCVALID_Msk   (0x1UL << TPI_DEVID_MANCVALID_Pos)
#define TPI_DEVID_PTINVALID_Pos   9U
#define TPI_DEVID_PTINVALID_Msk   (0x1UL << TPI_DEVID_PTINVALID_Pos)
#define TPI_DEVID_MinBufSz_Pos   6U
#define TPI_DEVID_MinBufSz_Msk   (0x7UL << TPI_DEVID_MinBufSz_Pos)
#define TPI_DEVID_AsynClkIn_Pos   5U
#define TPI_DEVID_AsynClkIn_Msk   (0x1UL << TPI_DEVID_AsynClkIn_Pos)
#define TPI_DEVID_NrTraceInput_Pos   0U
#define TPI_DEVID_NrTraceInput_Msk   (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/)
#define TPI_DEVTYPE_MajorType_Pos   4U
#define TPI_DEVTYPE_MajorType_Msk   (0xFUL << TPI_DEVTYPE_MajorType_Pos)
#define TPI_DEVTYPE_SubType_Pos   0U
#define TPI_DEVTYPE_SubType_Msk   (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/)
◆ TPI_ACPR_PRESCALER_Msk
TPI ACPR: PRESCALER Mask
◆ TPI_ACPR_PRESCALER_Pos
TPI ACPR: PRESCALER Position
◆ TPI_DEVID_AsynClkIn_Msk
TPI DEVID: AsynClkIn Mask
◆ TPI_DEVID_AsynClkIn_Pos
TPI DEVID: AsynClkIn Position
◆ TPI_DEVID_MANCVALID_Msk
TPI DEVID: MANCVALID Mask
◆ TPI_DEVID_MANCVALID_Pos
TPI DEVID: MANCVALID Position
◆ TPI_DEVID_MinBufSz_Msk
TPI DEVID: MinBufSz Mask
◆ TPI_DEVID_MinBufSz_Pos
TPI DEVID: MinBufSz Position
◆ TPI_DEVID_NrTraceInput_Msk
TPI DEVID: NrTraceInput Mask
◆ TPI_DEVID_NrTraceInput_Pos
TPI DEVID: NrTraceInput Position
◆ TPI_DEVID_NRZVALID_Msk
TPI DEVID: NRZVALID Mask
◆ TPI_DEVID_NRZVALID_Pos
TPI DEVID: NRZVALID Position
◆ TPI_DEVID_PTINVALID_Msk
TPI DEVID: PTINVALID Mask
◆ TPI_DEVID_PTINVALID_Pos
TPI DEVID: PTINVALID Position
◆ TPI_DEVTYPE_MajorType_Msk
TPI DEVTYPE: MajorType Mask
◆ TPI_DEVTYPE_MajorType_Pos
TPI DEVTYPE: MajorType Position
◆ TPI_DEVTYPE_SubType_Msk
TPI DEVTYPE: SubType Mask
◆ TPI_DEVTYPE_SubType_Pos
TPI DEVTYPE: SubType Position
◆ TPI_FFCR_EnFCont_Msk
TPI FFCR: EnFCont Mask
◆ TPI_FFCR_EnFCont_Pos
TPI FFCR: EnFCont Position
◆ TPI_FFCR_TrigIn_Msk
TPI FFCR: TrigIn Mask
◆ TPI_FFCR_TrigIn_Pos
TPI FFCR: TrigIn Position
◆ TPI_FFSR_FlInProg_Msk
TPI FFSR: FlInProg Mask
◆ TPI_FFSR_FlInProg_Pos
TPI FFSR: FlInProg Position
◆ TPI_FFSR_FtNonStop_Msk
TPI FFSR: FtNonStop Mask
◆ TPI_FFSR_FtNonStop_Pos
TPI FFSR: FtNonStop Position
◆ TPI_FFSR_FtStopped_Msk
TPI FFSR: FtStopped Mask
◆ TPI_FFSR_FtStopped_Pos
TPI FFSR: FtStopped Position
◆ TPI_FFSR_TCPresent_Msk
TPI FFSR: TCPresent Mask
◆ TPI_FFSR_TCPresent_Pos
TPI FFSR: TCPresent Position
◆ TPI_FIFO0_ETM0_Msk
TPI FIFO0: ETM0 Mask
◆ TPI_FIFO0_ETM0_Pos
TPI FIFO0: ETM0 Position
◆ TPI_FIFO0_ETM1_Msk
TPI FIFO0: ETM1 Mask
◆ TPI_FIFO0_ETM1_Pos
TPI FIFO0: ETM1 Position
◆ TPI_FIFO0_ETM2_Msk
TPI FIFO0: ETM2 Mask
◆ TPI_FIFO0_ETM2_Pos
TPI FIFO0: ETM2 Position
◆ TPI_FIFO0_ETM_ATVALID_Msk
TPI FIFO0: ETM_ATVALID Mask
◆ TPI_FIFO0_ETM_ATVALID_Pos
TPI FIFO0: ETM_ATVALID Position
◆ TPI_FIFO0_ETM_bytecount_Msk
TPI FIFO0: ETM_bytecount Mask
◆ TPI_FIFO0_ETM_bytecount_Pos
TPI FIFO0: ETM_bytecount Position
◆ TPI_FIFO0_ITM_ATVALID_Msk
TPI FIFO0: ITM_ATVALID Mask
◆ TPI_FIFO0_ITM_ATVALID_Pos
TPI FIFO0: ITM_ATVALID Position
◆ TPI_FIFO0_ITM_bytecount_Msk
TPI FIFO0: ITM_bytecount Mask
◆ TPI_FIFO0_ITM_bytecount_Pos
TPI FIFO0: ITM_bytecount Position
◆ TPI_FIFO1_ETM_ATVALID_Msk
TPI FIFO1: ETM_ATVALID Mask
◆ TPI_FIFO1_ETM_ATVALID_Pos
TPI FIFO1: ETM_ATVALID Position
◆ TPI_FIFO1_ETM_bytecount_Msk
TPI FIFO1: ETM_bytecount Mask
◆ TPI_FIFO1_ETM_bytecount_Pos
TPI FIFO1: ETM_bytecount Position
◆ TPI_FIFO1_ITM0_Msk
TPI FIFO1: ITM0 Mask
◆ TPI_FIFO1_ITM0_Pos
TPI FIFO1: ITM0 Position
◆ TPI_FIFO1_ITM1_Msk
TPI FIFO1: ITM1 Mask
◆ TPI_FIFO1_ITM1_Pos
TPI FIFO1: ITM1 Position
◆ TPI_FIFO1_ITM2_Msk
TPI FIFO1: ITM2 Mask
◆ TPI_FIFO1_ITM2_Pos
TPI FIFO1: ITM2 Position
◆ TPI_FIFO1_ITM_ATVALID_Msk
TPI FIFO1: ITM_ATVALID Mask
◆ TPI_FIFO1_ITM_ATVALID_Pos
TPI FIFO1: ITM_ATVALID Position
◆ TPI_FIFO1_ITM_bytecount_Msk
TPI FIFO1: ITM_bytecount Mask
◆ TPI_FIFO1_ITM_bytecount_Pos
TPI FIFO1: ITM_bytecount Position
◆ TPI_ITATBCTR0_ATREADY_Msk
TPI ITATBCTR0: ATREADY Mask
◆ TPI_ITATBCTR0_ATREADY_Pos
TPI ITATBCTR0: ATREADY Position
◆ TPI_ITATBCTR2_ATREADY_Msk
TPI ITATBCTR2: ATREADY Mask
◆ TPI_ITATBCTR2_ATREADY_Pos
TPI ITATBCTR2: ATREADY Position
◆ TPI_ITCTRL_Mode_Msk
TPI ITCTRL: Mode Mask
◆ TPI_ITCTRL_Mode_Pos
TPI ITCTRL: Mode Position
◆ TPI_SPPR_TXMODE_Msk
TPI SPPR: TXMODE Mask
◆ TPI_SPPR_TXMODE_Pos
TPI SPPR: TXMODE Position
◆ TPI_TRIGGER_TRIGGER_Msk
TPI TRIGGER: TRIGGER Mask
◆ TPI_TRIGGER_TRIGGER_Pos
TPI TRIGGER: TRIGGER Position
