RTEMS
5.1
Structure type to access the Nested Vectored Interrupt Controller (NVIC). More...
#include <core_cm7.h>
Data Fields | |
__IOM uint32_t | ISER [8U] |
uint32_t | RESERVED0 [24U] |
__IOM uint32_t | ICER [8U] |
uint32_t | RSERVED1 [24U] |
__IOM uint32_t | ISPR [8U] |
uint32_t | RESERVED2 [24U] |
__IOM uint32_t | ICPR [8U] |
uint32_t | RESERVED3 [24U] |
__IOM uint32_t | IABR [8U] |
uint32_t | RESERVED4 [56U] |
__IOM uint8_t | IP [240U] |
uint32_t | RESERVED5 [644U] |
__OM uint32_t | STIR |
__IOM uint32_t NVIC_Type::IABR[8U] |
Offset: 0x200 (R/W) Interrupt Active bit Register
__IOM uint32_t NVIC_Type::ICER[8U] |
Offset: 0x080 (R/W) Interrupt Clear Enable Register
__IOM uint32_t NVIC_Type::ICPR[8U] |
Offset: 0x180 (R/W) Interrupt Clear Pending Register
__IOM uint8_t NVIC_Type::IP[240U] |
Offset: 0x300 (R/W) Interrupt Priority Register (8Bit wide)
__IOM uint32_t NVIC_Type::ISER[8U] |
Offset: 0x000 (R/W) Interrupt Set Enable Register
__IOM uint32_t NVIC_Type::ISPR[8U] |
Offset: 0x100 (R/W) Interrupt Set Pending Register
__OM uint32_t NVIC_Type::STIR |
Offset: 0xE00 ( /W) Software Trigger Interrupt Register
