RTEMS
5.1
Structure type to access the Instrumentation Trace Macrocell Register (ITM). More...
#include <core_cm7.h>
Data Fields | |
union { | |
__OM uint8_t u8 | |
__OM uint16_t u16 | |
__OM uint32_t u32 | |
} | PORT [32U] |
uint32_t | RESERVED0 [864U] |
__IOM uint32_t | TER |
uint32_t | RESERVED1 [15U] |
__IOM uint32_t | TPR |
uint32_t | RESERVED2 [15U] |
__IOM uint32_t | TCR |
uint32_t | RESERVED3 [29U] |
__OM uint32_t | IWR |
__IM uint32_t | IRR |
__IOM uint32_t | IMCR |
uint32_t | RESERVED4 [43U] |
__OM uint32_t | LAR |
__IM uint32_t | LSR |
uint32_t | RESERVED5 [6U] |
__IM uint32_t | PID4 |
__IM uint32_t | PID5 |
__IM uint32_t | PID6 |
__IM uint32_t | PID7 |
__IM uint32_t | PID0 |
__IM uint32_t | PID1 |
__IM uint32_t | PID2 |
__IM uint32_t | PID3 |
__IM uint32_t | CID0 |
__IM uint32_t | CID1 |
__IM uint32_t | CID2 |
__IM uint32_t | CID3 |
__IM uint32_t ITM_Type::CID0 |
Offset: 0xFF0 (R/ ) ITM Component Identification Register #0
__IM uint32_t ITM_Type::CID1 |
Offset: 0xFF4 (R/ ) ITM Component Identification Register #1
__IM uint32_t ITM_Type::CID2 |
Offset: 0xFF8 (R/ ) ITM Component Identification Register #2
__IM uint32_t ITM_Type::CID3 |
Offset: 0xFFC (R/ ) ITM Component Identification Register #3
__IOM uint32_t ITM_Type::IMCR |
Offset: 0xF00 (R/W) ITM Integration Mode Control Register
__IM uint32_t ITM_Type::IRR |
Offset: 0xEFC (R/ ) ITM Integration Read Register
__OM uint32_t ITM_Type::IWR |
Offset: 0xEF8 ( /W) ITM Integration Write Register
__OM uint32_t ITM_Type::LAR |
Offset: 0xFB0 ( /W) ITM Lock Access Register
__IM uint32_t ITM_Type::LSR |
Offset: 0xFB4 (R/ ) ITM Lock Status Register
__IM uint32_t ITM_Type::PID0 |
Offset: 0xFE0 (R/ ) ITM Peripheral Identification Register #0
__IM uint32_t ITM_Type::PID1 |
Offset: 0xFE4 (R/ ) ITM Peripheral Identification Register #1
__IM uint32_t ITM_Type::PID2 |
Offset: 0xFE8 (R/ ) ITM Peripheral Identification Register #2
__IM uint32_t ITM_Type::PID3 |
Offset: 0xFEC (R/ ) ITM Peripheral Identification Register #3
__IM uint32_t ITM_Type::PID4 |
Offset: 0xFD0 (R/ ) ITM Peripheral Identification Register #4
__IM uint32_t ITM_Type::PID5 |
Offset: 0xFD4 (R/ ) ITM Peripheral Identification Register #5
__IM uint32_t ITM_Type::PID6 |
Offset: 0xFD8 (R/ ) ITM Peripheral Identification Register #6
__IM uint32_t ITM_Type::PID7 |
Offset: 0xFDC (R/ ) ITM Peripheral Identification Register #7
__OM { ... } ITM_Type::PORT[32U] |
Offset: 0x000 ( /W) ITM Stimulus Port Registers
__IOM uint32_t ITM_Type::TCR |
Offset: 0xE80 (R/W) ITM Trace Control Register
__IOM uint32_t ITM_Type::TER |
Offset: 0xE00 (R/W) ITM Trace Enable Register
__IOM uint32_t ITM_Type::TPR |
Offset: 0xE40 (R/W) ITM Trace Privilege Register
__OM uint16_t ITM_Type::u16 |
Offset: 0x000 ( /W) ITM Stimulus Port 16-bit
__OM uint32_t ITM_Type::u32 |
Offset: 0x000 ( /W) ITM Stimulus Port 32-bit
__OM uint8_t ITM_Type::u8 |
Offset: 0x000 ( /W) ITM Stimulus Port 8-bit
