RTEMS
5.1
Structure type to access the System Control Block (SCB). More...
#include <core_cm7.h>
Data Fields | |
__IM uint32_t | CPUID |
__IOM uint32_t | ICSR |
__IOM uint32_t | VTOR |
__IOM uint32_t | AIRCR |
__IOM uint32_t | SCR |
__IOM uint32_t | CCR |
__IOM uint8_t | SHPR [12U] |
__IOM uint32_t | SHCSR |
__IOM uint32_t | CFSR |
__IOM uint32_t | HFSR |
__IOM uint32_t | DFSR |
__IOM uint32_t | MMFAR |
__IOM uint32_t | BFAR |
__IOM uint32_t | AFSR |
__IM uint32_t | ID_PFR [2U] |
__IM uint32_t | ID_DFR |
__IM uint32_t | ID_AFR |
__IM uint32_t | ID_MFR [4U] |
__IM uint32_t | ID_ISAR [5U] |
uint32_t | RESERVED0 [1U] |
__IM uint32_t | CLIDR |
__IM uint32_t | CTR |
__IM uint32_t | CCSIDR |
__IOM uint32_t | CSSELR |
__IOM uint32_t | CPACR |
uint32_t | RESERVED3 [93U] |
__OM uint32_t | STIR |
uint32_t | RESERVED4 [15U] |
__IM uint32_t | MVFR0 |
__IM uint32_t | MVFR1 |
__IM uint32_t | MVFR2 |
uint32_t | RESERVED5 [1U] |
__OM uint32_t | ICIALLU |
uint32_t | RESERVED6 [1U] |
__OM uint32_t | ICIMVAU |
__OM uint32_t | DCIMVAC |
__OM uint32_t | DCISW |
__OM uint32_t | DCCMVAU |
__OM uint32_t | DCCMVAC |
__OM uint32_t | DCCSW |
__OM uint32_t | DCCIMVAC |
__OM uint32_t | DCCISW |
uint32_t | RESERVED7 [6U] |
__IOM uint32_t | ITCMCR |
__IOM uint32_t | DTCMCR |
__IOM uint32_t | AHBPCR |
__IOM uint32_t | CACR |
__IOM uint32_t | AHBSCR |
uint32_t | RESERVED8 [1U] |
__IOM uint32_t | ABFSR |
__IOM uint32_t SCB_Type::ABFSR |
Offset: 0x2A8 (R/W) Auxiliary Bus Fault Status Register
__IOM uint32_t SCB_Type::AFSR |
Offset: 0x03C (R/W) Auxiliary Fault Status Register
__IOM uint32_t SCB_Type::AHBPCR |
Offset: 0x298 (R/W) AHBP Control Register
__IOM uint32_t SCB_Type::AHBSCR |
Offset: 0x2A0 (R/W) AHB Slave Control Register
__IOM uint32_t SCB_Type::AIRCR |
Offset: 0x00C (R/W) Application Interrupt and Reset Control Register
__IOM uint32_t SCB_Type::BFAR |
Offset: 0x038 (R/W) BusFault Address Register
__IOM uint32_t SCB_Type::CACR |
Offset: 0x29C (R/W) L1 Cache Control Register
__IOM uint32_t SCB_Type::CCR |
Offset: 0x014 (R/W) Configuration Control Register
__IM uint32_t SCB_Type::CCSIDR |
Offset: 0x080 (R/ ) Cache Size ID Register
__IOM uint32_t SCB_Type::CFSR |
Offset: 0x028 (R/W) Configurable Fault Status Register
__IM uint32_t SCB_Type::CLIDR |
Offset: 0x078 (R/ ) Cache Level ID register
__IOM uint32_t SCB_Type::CPACR |
Offset: 0x088 (R/W) Coprocessor Access Control Register
__IM uint32_t SCB_Type::CPUID |
Offset: 0x000 (R/ ) CPUID Base Register
__IOM uint32_t SCB_Type::CSSELR |
Offset: 0x084 (R/W) Cache Size Selection Register
__IM uint32_t SCB_Type::CTR |
Offset: 0x07C (R/ ) Cache Type register
__OM uint32_t SCB_Type::DCCIMVAC |
Offset: 0x270 ( /W) D-Cache Clean and Invalidate by MVA to PoC
__OM uint32_t SCB_Type::DCCISW |
Offset: 0x274 ( /W) D-Cache Clean and Invalidate by Set-way
__OM uint32_t SCB_Type::DCCMVAC |
Offset: 0x268 ( /W) D-Cache Clean by MVA to PoC
__OM uint32_t SCB_Type::DCCMVAU |
Offset: 0x264 ( /W) D-Cache Clean by MVA to PoU
__OM uint32_t SCB_Type::DCCSW |
Offset: 0x26C ( /W) D-Cache Clean by Set-way
__OM uint32_t SCB_Type::DCIMVAC |
Offset: 0x25C ( /W) D-Cache Invalidate by MVA to PoC
__OM uint32_t SCB_Type::DCISW |
Offset: 0x260 ( /W) D-Cache Invalidate by Set-way
__IOM uint32_t SCB_Type::DFSR |
Offset: 0x030 (R/W) Debug Fault Status Register
__IOM uint32_t SCB_Type::DTCMCR |
Offset: 0x294 (R/W) Data Tightly-Coupled Memory Control Registers
__IOM uint32_t SCB_Type::HFSR |
Offset: 0x02C (R/W) HardFault Status Register
__OM uint32_t SCB_Type::ICIALLU |
Offset: 0x250 ( /W) I-Cache Invalidate All to PoU
__OM uint32_t SCB_Type::ICIMVAU |
Offset: 0x258 ( /W) I-Cache Invalidate by MVA to PoU
__IOM uint32_t SCB_Type::ICSR |
Offset: 0x004 (R/W) Interrupt Control and State Register
__IM uint32_t SCB_Type::ID_AFR |
Offset: 0x04C (R/ ) Auxiliary Feature Register
__IM uint32_t SCB_Type::ID_DFR |
Offset: 0x048 (R/ ) Debug Feature Register
__IM uint32_t SCB_Type::ID_ISAR[5U] |
Offset: 0x060 (R/ ) Instruction Set Attributes Register
__IM uint32_t SCB_Type::ID_MFR[4U] |
Offset: 0x050 (R/ ) Memory Model Feature Register
__IM uint32_t SCB_Type::ID_PFR[2U] |
Offset: 0x040 (R/ ) Processor Feature Register
__IOM uint32_t SCB_Type::ITCMCR |
Offset: 0x290 (R/W) Instruction Tightly-Coupled Memory Control Register
__IOM uint32_t SCB_Type::MMFAR |
Offset: 0x034 (R/W) MemManage Fault Address Register
__IM uint32_t SCB_Type::MVFR0 |
Offset: 0x240 (R/ ) Media and VFP Feature Register 0
__IM uint32_t SCB_Type::MVFR1 |
Offset: 0x244 (R/ ) Media and VFP Feature Register 1
__IM uint32_t SCB_Type::MVFR2 |
Offset: 0x248 (R/ ) Media and VFP Feature Register 1
__IOM uint32_t SCB_Type::SCR |
Offset: 0x010 (R/W) System Control Register
__IOM uint32_t SCB_Type::SHCSR |
Offset: 0x024 (R/W) System Handler Control and State Register
__IOM uint8_t SCB_Type::SHPR[12U] |
Offset: 0x018 (R/W) System Handlers Priority Registers (4-7, 8-11, 12-15)
__OM uint32_t SCB_Type::STIR |
Offset: 0x200 ( /W) Software Triggered Interrupt Register
__IOM uint32_t SCB_Type::VTOR |
Offset: 0x008 (R/W) Vector Table Offset Register
