34. Timespec Helpers¶
34.1. Introduction¶
The Timespec helpers manager provides directives to assist in manipulating
instances of the POSIX struct timespec structure.
The directives provided by the timespec helpers manager are:
- rtems_timespec_set - Set timespec’s value
- rtems_timespec_zero - Zero timespec’s value
- rtems_timespec_is_valid - Check if timespec is valid
- rtems_timespec_add_to - Add two timespecs
- rtems_timespec_subtract - Subtract two timespecs
- rtems_timespec_divide - Divide two timespecs
- rtems_timespec_divide_by_integer - Divide timespec by integer
- rtems_timespec_less_than - Less than operator
- rtems_timespec_greater_than - Greater than operator
- rtems_timespec_equal_to - Check if two timespecs are equal
- rtems_timespec_get_seconds - Obtain seconds portion of timespec
- rtems_timespec_get_nanoseconds - Obtain nanoseconds portion of timespec
- rtems_timespec_to_ticks - Convert timespec to number of ticks
- rtems_timespec_from_ticks - Convert ticks to timespec
34.2. Background¶
34.2.1. Time Storage Conventions¶
Time can be stored in many ways. One of them is the struct timespec format
which is a structure that consists of the fields tv_sec to represent
seconds and tv_nsec to represent nanoseconds. The``struct timeval``
structure is simular and consists of seconds (stored in tv_sec) and
microseconds (stored in tv_usec). Either``struct timespec`` or struct
timeval can be used to represent elapsed time, time of executing some
operations, or time of day.
34.3. Operations¶
34.3.1. Set and Obtain Timespec Value¶
A user may write a specific time by passing the desired seconds and nanoseconds
values and the destination struct timespec using the rtems_timespec_set
directive.
The rtems_timespec_zero directive is used to zero the seconds
and nanoseconds portions of a struct timespec instance.
Users may obtain the seconds or nanoseconds portions of a struct timespec
instance with the rtems_timespec_get_seconds or
rtems_timespec_get_nanoseconds methods, respectively.
34.3.2. Timespec Math¶
A user can perform multiple operations on struct timespec instances. The
helpers in this manager assist in adding, subtracting, and performing divison
- Adding two
struct timespeccan be done using thertems_timespec_add_todirective. This directive is used mainly to calculate total amount of time consumed by multiple operations. - The
rtems_timespec_subtractis used to subtract twostruct timespecsinstances and determine the elapsed time between those two points in time. - The
rtems_timespec_divideis used to use to divide onestruct timespecinstance by another. This calculates the percentage with a precision to three decimal points. - The
rtems_timespec_divide_by_integeris used to divide astruct timespecinstance by an integer. It is commonly used in benchmark calculations to dividing duration by the number of iterations performed.
34.3.3. Comparing struct timespec Instances¶
A user can compare two struct timespec instances using the
rtems_timespec_less_than, rtems_timespec_greater_than or
rtems_timespec_equal_to routines.
34.3.4. Conversions and Validity Check¶
Conversion to and from clock ticks may be performed by using the
rtems_timespec_to_ticks and rtems_timespec_from_ticks directives.
User can also check validity of timespec with rtems_timespec_is_valid
routine.
34.4. Directives¶
This section details the Timespec Helpers manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
34.4.1. TIMESPEC_SET - Set struct timespec Instance¶
- CALLING SEQUENCE:
void rtems_timespec_set( struct timespec *time, time_t seconds, uint32_t nanoseconds );
- DIRECTIVE STATUS CODES:
- NONE
- DESCRIPTION:
- This directive sets the
struct timespectime to the desiredsecondsandnanosecondsvalues. - NOTES:
- This method does NOT check if
nanosecondsis less than the maximum number of nanoseconds in a second.
34.4.2. TIMESPEC_ZERO - Zero struct timespec Instance¶
- CALLING SEQUENCE:
void rtems_timespec_zero( struct timespec *time );
- NONE
- DESCRIPTION:
- This routine sets the contents of the
struct timespecinstancetimeto zero. - NOTES:
- NONE
34.4.3. TIMESPEC_IS_VALID - Check validity of a struct timespec instance¶
- CALLING SEQUENCE:
bool rtems_timespec_is_valid( const struct timespec *time );
- This method returns
trueif the instance is valid, andfalseotherwise. - DESCRIPTION:
- This routine check validity of a
struct timespecinstance. It checks if the nanoseconds portion of thestruct timespecinstanceis in allowed range (less than the maximum number of nanoseconds per second). - NOTES:
- NONE
34.4.4. TIMESPEC_ADD_TO - Add Two struct timespec Instances¶
- CALLING SEQUENCE:
uint32_t rtems_timespec_add_to( struct timespec *time, const struct timespec *add );
- The method returns the number of seconds
timeincreased by. - DESCRIPTION:
- This routine adds two
struct timespecinstances. The second argument is added to the first. The parametertimeis the base time to which theaddparameter is added. - NOTES:
- NONE
34.4.5. TIMESPEC_SUBTRACT - Subtract Two struct timespec Instances¶
- CALLING SEQUENCE:
void rtems_timespec_subtract( const struct timespec *start, const struct timespec *end, struct timespec *result );
- NONE
- DESCRIPTION:
- This routine subtracts
startfromendsaves the difference inresult. The primary use of this directive is to calculate elapsed time. - NOTES:
- It is possible to subtract when
endis less thanstartand it produce negativeresult. When doing this you should be careful and remember that only the seconds portion of astruct timespecinstance is signed, which means that nanoseconds portion is always increasing. Due to that when your timespec has seconds = -1 and nanoseconds = 500,000,000 it means that result is -0.5 second, NOT the expected -1.5!
34.4.6. TIMESPEC_DIVIDE - Divide Two struct timespec Instances¶
- CALLING SEQUENCE:
void rtems_timespec_divide( const struct timespec *lhs, const struct timespec *rhs, uint32_t *ival_percentage, uint32_t *fval_percentage );
- NONE
- DESCRIPTION:
This routine divides the
struct timespecinstancelhsby thestruct timespecinstancerhs. The result is returned in theival_percentageandfval_percentage, representing the integer and fractional results of the division respectively.The
ival_percentageis integer value of calculated percentage andfval_percentageis fractional part of calculated percentage.- NOTES:
The intended use is calculating percentges to three decimal points.
When dividing by zero, this routine return both
ival_percentageandfval_percentageequal zero.The division is performed using exclusively integer operations.
34.4.7. TIMESPEC_DIVIDE_BY_INTEGER - Divide a struct timespec Instance by an Integer¶
- CALLING SEQUENCE:
int rtems_timespec_divide_by_integer( const struct timespec *time, uint32_t iterations, struct timespec *result );
- NONE
- DESCRIPTION:
- This routine divides the
struct timespecinstancetimeby the integer valueiterations. The result is saved inresult. - NOTES:
- The expected use is to assist in benchmark calculations where you typically
divide a duration (
time) by a number of iterations what gives average time.
34.4.8. TIMESPEC_LESS_THAN - Less than operator¶
- CALLING SEQUENCE:
bool rtems_timespec_less_than( const struct timespec *lhs, const struct timespec *rhs );
struct trueiflhsis less thanrhsandstruct falseotherwise. - DESCRIPTION:
- This method is the less than operator for
struct timespecinstances. The first parameter is the left hand side and the second is the right hand side of the comparison. - NOTES:
- NONE
34.4.9. TIMESPEC_GREATER_THAN - Greater than operator¶
- CALLING SEQUENCE:
bool rtems_timespec_greater_than( const struct timespec *_lhs, const struct timespec *_rhs );
struct trueiflhsis greater thanrhsandstruct falseotherwise. - DESCRIPTION:
- This method is greater than operator for
struct timespecinstances. - NOTES:
- NONE
34.4.10. TIMESPEC_EQUAL_TO - Check equality of timespecs¶
- CALLING SEQUENCE:
bool rtems_timespec_equal_to( const struct timespec *lhs, const struct timespec *rhs );
struct trueiflhsis equal torhsandstruct falseotherwise. - DESCRIPTION:
- This method is equality operator for
- NONE
34.4.11. TIMESPEC_GET_SECONDS - Get Seconds Portion of struct timespec Instance¶
- CALLING SEQUENCE:
time_t rtems_timespec_get_seconds( struct timespec *time );
- This method returns the seconds portion of the specified
struct timespecinstance. - DESCRIPTION:
struct timespecinstancetime. - NOTES:
- NONE
34.4.12. TIMESPEC_GET_NANOSECONDS - Get Nanoseconds Portion of the struct timespec Instance¶
- CALLING SEQUENCE:
uint32_t rtems_timespec_get_nanoseconds( struct timespec *_time );
- This method returns the nanoseconds portion of the specified
- This method returns the nanoseconds portion of the specified timespec which
is pointed by
_time. - NOTES:
- NONE
34.4.13. TIMESPEC_TO_TICKS - Convert struct timespec Instance to Ticks¶
- CALLING SEQUENCE:
uint32_t rtems_timespec_to_ticks( const struct timespec *time );
- This directive returns the number of ticks computed.
- DESCRIPTION:
- This directive converts the
timetimespec to the corresponding number of clock ticks. - NOTES:
- NONE
34.4.14. TIMESPEC_FROM_TICKS - Convert Ticks to struct timespec Representation¶
- CALLING SEQUENCE:
void rtems_timespec_from_ticks( uint32_t ticks, struct timespec *time );
- NONE
- DESCRIPTION:
- This routine converts the
ticksto the correspondingstruct timespecrepresentation and stores it intime. - NOTES:
- NONE
