38. Directive Status Codes¶
38.1. Introduction¶
The directive status code directives are:
- rtems_status_text - Return the name for the status code
38.2. Directives¶
The directives are:
RTEMS_SUCCESSFUL |
successful completion |
RTEMS_TASK_EXITTED |
returned from a task |
RTEMS_MP_NOT_CONFIGURED |
multiprocessing not configured |
RTEMS_INVALID_NAME |
invalid object name |
RTEMS_INVALID_ID |
invalid object id |
RTEMS_TOO_MANY |
too many |
RTEMS_TIMEOUT |
timed out waiting |
RTEMS_OBJECT_WAS_DELETED |
object was deleted while waiting |
RTEMS_INVALID_SIZE |
invalid specified size |
RTEMS_INVALID_ADDRESS |
invalid address specified |
RTEMS_INVALID_NUMBER |
number was invalid |
RTEMS_NOT_DEFINED |
item not initialized |
RTEMS_RESOURCE_IN_USE |
resources outstanding |
RTEMS_UNSATISFIED |
request not satisfied |
RTEMS_INCORRECT_STATE |
task is in wrong state |
RTEMS_ALREADY_SUSPENDED |
task already in state |
RTEMS_ILLEGAL_ON_SELF |
illegal for calling task |
RTEMS_ILLEGAL_ON_REMOTE_OBJECT |
illegal for remote object |
RTEMS_CALLED_FROM_ISR |
invalid environment |
RTEMS_INVALID_PRIORITY |
invalid task priority |
RTEMS_INVALID_CLOCK |
invalid time buffer |
RTEMS_INVALID_NODE |
invalid node id |
RTEMS_NOT_CONFIGURED |
directive not configured |
RTEMS_NOT_OWNER_OF_RESOURCE |
not owner of resource |
RTEMS_NOT_IMPLEMENTED |
directive not implemented or feature not available in configuration |
RTEMS_INTERNAL_ERROR |
RTEMS inconsistency detected |
RTEMS_NO_MEMORY |
could not get enough memory |
38.2.1. STATUS_TEXT - Returns the enumeration name for a status code¶
- CALLING SEQUENCE:
const char *rtems_status_text( rtems_status_code code );
- DIRECTIVE STATUS CODES
- The status code enumeration name or “?” in case the status code is invalid.
- DESCRIPTION:
- Returns the enumeration name for the specified status code.
