13. Barrier Manager¶
13.1. Introduction¶
The barrier manager provides a unique synchronization capability which can be used to have a set of tasks block and be unblocked as a set. The directives provided by the barrier manager are:
- rtems_barrier_create - Create a barrier
- rtems_barrier_ident - Get ID of a barrier
- rtems_barrier_delete - Delete a barrier
- rtems_barrier_wait - Wait at a barrier
- rtems_barrier_release - Release a barrier
13.2. Background¶
A barrier can be viewed as a gate at which tasks wait until the gate is opened. This has many analogies in the real world. Horses and other farm animals may approach a closed gate and gather in front of it, waiting for someone to open the gate so they may proceed. Similarly, cticket holders gather at the gates of arenas before concerts or sporting events waiting for the arena personnel to open the gates so they may enter.
Barriers are useful during application initialization. Each application task can perform its local initialization before waiting for the application as a whole to be initialized. Once all tasks have completed their independent initializations, the “application ready” barrier can be released.
13.2.1. Automatic Versus Manual Barriers¶
Just as with a real-world gate, barriers may be configured to be manually
opened or automatically opened. All tasks calling the rtems_barrier_wait
directive will block until a controlling task invokes
the rtems_barrier_release
directive.
Automatic barriers are created with a limit to the number of tasks which may
simultaneously block at the barrier. Once this limit is reached, all of the
tasks are released. For example, if the automatic limit is ten tasks, then the
first nine tasks calling the rtems_barrier_wait
directive will block. When
the tenth task calls the rtems_barrier_wait
directive, the nine blocked
tasks will be released and the tenth task returns to the caller without
blocking.
13.2.2. Building a Barrier Attribute Set¶
In general, an attribute set is built by a bitwise OR of the desired attribute components. The following table lists the set of valid barrier attributes:
RTEMS_BARRIER_AUTOMATIC_RELEASE
- automatically release the barrier when the configured number of tasks are blocked
RTEMS_BARRIER_MANUAL_RELEASE
- only release the barrier when the application invokes the
directive. (default)
Note
Barriers only support FIFO blocking order because all waiting tasks are released as a set. Thus the released tasks will all become ready to execute at the same time and compete for the processor based upon their priority.
Attribute values are specifically designed to be mutually exclusive, therefore
bitwise OR and addition operations are equivalent as long as each attribute
appears exactly once in the component list. An attribute listed as a default
is not required to appear in the attribute list, although it is a good
programming practice to specify default attributes. If all defaults are
desired, the attribute RTEMS_DEFAULT_ATTRIBUTES
should be specified on this
call.
This example demonstrates the attribute_set parameter needed to create a
barrier with the automatic release policy. The attribute_set
parameter
passed to the rtems_barrier_create
directive will be
. In this case, the user must also specify
the maximum_waiters
parameter.
13.3. Operations¶
13.3.1. Creating a Barrier¶
The rtems_barrier_create
directive creates a barrier with a user-specified
name and the desired attributes. RTEMS allocates a Barrier Control Block (BCB)
from the BCB free list. This data structure is used by RTEMS to manage the
newly created barrier. Also, a unique barrier ID is generated and returned to
the calling task.
13.3.2. Obtaining Barrier IDs¶
When a barrier is created, RTEMS generates a unique barrier ID and assigns it
to the created barrier until it is deleted. The barrier ID may be obtained by
either of two methods. First, as the result of an invocation of the
directive, the barrier ID is stored in a user provided
location. Second, the barrier ID may be obtained later using the
rtems_barrier_ident
directive. The barrier ID is used by other barrier
manager directives to access this barrier.
13.3.3. Waiting at a Barrier¶
The rtems_barrier_wait
directive is used to wait at
the specified barrier. Since a barrier is, by definition, never immediately,
the task may wait forever for the barrier to be released or it may
specify a timeout. Specifying a timeout limits the interval the task will
wait before returning with an error status code.
If the barrier is configured as automatic and there are already one less then the maximum number of waiters, then the call will unblock all tasks waiting at the barrier and the caller will return immediately.
When the task does wait to acquire the barrier, then it is placed in the barrier’s task wait queue in FIFO order. All tasks waiting on a barrier are returned an error code when the barrier is deleted.
13.3.4. Releasing a Barrier¶
The rtems_barrier_release
directive is used to release the specified
barrier. When the rtems_barrier_release
is invoked, all tasks waiting at
the barrier are immediately made ready to execute and begin to compete for the
processor to execute.
13.3.5. Deleting a Barrier¶
The rtems_barrier_delete
directive removes a barrier from the system and
frees its control block. A barrier can be deleted by any local task that knows
the barrier’s ID. As a result of this directive, all tasks blocked waiting for
the barrier to be released, will be readied and returned a status code which
indicates that the barrier was deleted. Any subsequent references to the
barrier’s name and ID are invalid.
13.4. Directives¶
This section details the barrier manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
13.4.1. BARRIER_CREATE - Create a barrier¶
- CALLING SEQUENCE:
rtems_status_code rtems_barrier_create( rtems_name name, rtems_attribute attribute_set, uint32_t maximum_waiters, rtems_id *id );
- DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL
barrier created successfully RTEMS_INVALID_NAME
invalid barrier name RTEMS_INVALID_ADDRESS
id
is NULLRTEMS_TOO_MANY
too many barriers created - DESCRIPTION:
This directive creates a barrier which resides on the local node. The created barrier has the user-defined name specified in
name
and the initial count specified incount
. For control and maintenance of the barrier, RTEMS allocates and initializes a BCB. The RTEMS-assigned barrier id is returned inid
. This barrier id is used with other barrier related directives to access the barrier.RTEMS_BARRIER_MANUAL_RELEASE
only release Specifying
inattribute_set
causes tasks calling thertems_barrier_wait
directive to block until there aremaximum_waiters - 1
tasks waiting at the barrier. When themaximum_waiters
task invokes thertems_barrier_wait
directive, the previousmaximum_waiters - 1
tasks are automatically released and the caller returns.In contrast, when the
attribute is specified, there is no limit on the number of tasks that will block at the barrier. Only when thertems_barrier_release
directive is invoked, are the tasks waiting at the barrier unblocked.- NOTES:
This directive will not cause the calling task to be preempted.
The following barrier attribute constants are defined by RTEMS:
automatically release the barrier when the configured number of tasks are blocked RTEMS_BARRIER_MANUAL_RELEASE
only release the barrier when the application invokes the rtems_barrier_release
13.4.2. BARRIER_IDENT - Get ID of a barrier¶
- CALLING SEQUENCE:
rtems_status_code rtems_barrier_ident( rtems_name name, rtems_id *id );
RTEMS_SUCCESSFUL
barrier identified successfully RTEMS_INVALID_NAME
barrier name not found RTEMS_INVALID_NODE
invalid node id - DESCRIPTION:
- This directive obtains the barrier id associated with the barrier name. If the barrier name is not unique, then the barrier id will match one of the barriers with that name. However, this barrier id is not guaranteed to correspond to the desired barrier. The barrier id is used by other barrier related directives to access the barrier.
- NOTES:
- This directive will not cause the running task to be preempted.
13.4.3. BARRIER_DELETE - Delete a barrier¶
- CALLING SEQUENCE:
rtems_status_code rtems_barrier_delete( rtems_id id );
RTEMS_SUCCESSFUL
barrier deleted successfully RTEMS_INVALID_ID
invalid barrier id - DESCRIPTION:
- This directive deletes the barrier specified by
id
. All tasks blocked waiting for the barrier to be released will be readied and returned a status code which indicates that the barrier was deleted. The BCB for this barrier is reclaimed by RTEMS. - NOTES:
The calling task will be preempted if it is enabled by the task’s execution mode and a higher priority local task is waiting on the deleted barrier. The calling task will NOT be preempted if all of the tasks that are waiting on the barrier are remote tasks.
The calling task does not have to be the task that created the barrier. Any local task that knows the barrier id can delete the barrier.
13.4.4. BARRIER_WAIT - Wait at a barrier¶
- CALLING SEQUENCE:
rtems_status_code rtems_barrier_wait( rtems_id id, rtems_interval timeout );
RTEMS_SUCCESSFUL
barrier released and task unblocked RTEMS_UNSATISFIED
barrier not available RTEMS_TIMEOUT
timed out waiting for barrier RTEMS_OBJECT_WAS_DELETED
barrier deleted while waiting RTEMS_INVALID_ID
invalid barrier id
DESCRIPTION:
This directive acquires the barrier specified by
id
. TheRTEMS_WAIT
andRTEMS_NO_WAIT
components of the options parameter indicate whether the calling task wants to wait for the barrier to become available or return immediately if the barrier is not currently available. With eitherRTEMS_WAIT
orRTEMS_NO_WAIT
, if the current barrier count is positive, then it is decremented by one and the barrier is successfully acquired by returning immediately with a successful return code.Conceptually, the calling task should always be thought of as blocking when it makes this call and being unblocked when the barrier is released. If the barrier is configured for manual release, this rule of thumb will always be valid. If the barrier is configured for automatic release, all callers will block except for the one which is the Nth task which trips the automatic release condition.
The timeout parameter specifies the maximum interval the calling task is willing to be blocked waiting for the barrier. If it is set to
RTEMS_NO_TIMEOUT
, then the calling task will wait forever. If the barrier is available or theRTEMS_NO_WAIT
option component is set, then timeout is ignored.
NOTES:
The following barrier acquisition option constants are defined by RTEMS:
RTEMS_WAIT
task will wait for barrier (default) RTEMS_NO_WAIT
task should not wait A clock tick is required to support the timeout functionality of this directive.
13.4.5. BARRIER_RELEASE - Release a barrier¶
- CALLING SEQUENCE:
rtems_status_code rtems_barrier_release( rtems_id id, uint32_t *released );
RTEMS_SUCCESSFUL
barrier released successfully RTEMS_INVALID_ID
- This directive releases the barrier specified by id. All tasks waiting at the barrier will be unblocked. If the running task’s preemption mode is enabled and one of the unblocked tasks has a higher priority than the running task.
- NOTES:
- The calling task may be preempted if it causes a higher priority task to be made ready for execution.
