21. Fatal Error Manager¶
21.1. Introduction¶
The fatal error manager processes all fatal or irrecoverable errors and other
sources of system termination (for example after exit()). Fatal
errors are identified by the (fatal source, error code) pair. The directives
provided by the fatal error manager are:
- rtems_fatal - Invoke the fatal error handler
- rtems_panic - Print a message and invoke the fatal error handler
- rtems_shutdown_executive - Shutdown RTEMS
- rtems_exception_frame_print - Print the CPU exception frame
- rtems_fatal_source_text - Return the fatal source text
- rtems_internal_error_text - Return the error code text
- rtems_fatal_error_occurred - Invoke the fatal error handler (deprecated)
21.2. Background¶
21.2.1. Overview¶
The fatal error manager is called upon detection of an irrecoverable error condition by either RTEMS or the application software. Fatal errors are also used in case it is difficult or impossible to return an error condition by other means, e.g. a return value of a directive call. Fatal errors can be detected from various sources, for example
- the executive (RTEMS),
- support libraries,
- user system code, and
- user application code.
RTEMS automatically invokes the fatal error manager upon detection of an error it considers to be fatal. Similarly, the user should invoke the fatal error manager upon detection of a fatal error.
Each static or dynamic user extension set may include a fatal error handler. The fatal error handler in the static extension set can be used to provide access to debuggers and monitors which may be present on the target hardware. If any user-supplied fatal error handlers are installed, the fatal error manager will invoke them. Usually, the board support package provides a fatal error extension which resets the board. If no user handlers are configured or if all the user handler return control to the fatal error manager, then the RTEMS default fatal error handler is invoked. If the default fatal error handler is invoked, then the system state is marked as failed.
Although the precise behavior of the default fatal error handler is processor specific, in general, it will disable all maskable interrupts, place the error code in a known processor dependent place (generally either on the stack or in a register), and halt the processor. The precise actions of the RTEMS fatal error are discussed in the Default Fatal Error Processing chapter of the Applications Supplement document for a specific target processor.
21.2.2. Fatal Sources¶
The following fatal sources are defined for RTEMS via the
rtems_fatal_source enumeration. Each symbolic name has the
corresponding numeric fatal source in parenthesis.
- INTERNAL_ERROR_CORE (0)
- Errors of the core operating system. See Chapter 21 Section 2.3 - Internal Error Codes.
- INTERNAL_ERROR_RTEMS_API (1)
- Errors of the Classic API.
- INTERNAL_ERROR_POSIX_API (2)
- Errors of the POSIX API.
- RTEMS_FATAL_SOURCE_BDBUF (3)
- Fatal source for the block device cache. See
rtems_bdbuf_fatal_code. - RTEMS_FATAL_SOURCE_APPLICATION (4)
- Fatal source for application-specific errors. The fatal code is application-specific.
- RTEMS_FATAL_SOURCE_EXIT (5)
- Fatal source of
exit(). The fatal code is theexit()status code. - RTEMS_FATAL_SOURCE_BSP (6)
- Fatal source for BSP errors. The fatal codes are defined in
<bsp/fatal.h>. Examples are interrupt and exception initialization. Seebsp_fatal_codeandbsp_fatal(). - RTEMS_FATAL_SOURCE_ASSERT (7)
- Fatal source of
assert(). The fatal code is the pointer value of the assert context. Seertems_assert_context. - RTEMS_FATAL_SOURCE_STACK_CHECKER (8)
- Fatal source of the stack checker. The fatal code is the object name of the executing task.
- RTEMS_FATAL_SOURCE_EXCEPTION (9)
- Fatal source of the exceptions. The fatal code is the pointer value of the
exception frame pointer. See
rtems_exception_frameand Chapter 21 Section 4.4 - EXCEPTION_FRAME_PRINT - Prints the exception frame. - RTEMS_FATAL_SOURCE_SMP (10)
- Fatal source of SMP domain. See
SMP_Fatal_code. - RTEMS_FATAL_SOURCE_PANIC (11)
- Fatal source of
rtems_panic(), see Chapter 21 Section 4.2 - PANIC - Print a message and invoke the fatal error handler. - RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE (12)
- Fatal source for invalid C program heap frees via
free(). The fatal code is the bad pointer.
21.2.3. Internal Error Codes¶
The following error codes are defined for the INTERNAL_ERROR_CORE
fatal source. Each symbolic name has the corresponding numeric error code in
parenthesis.
- INTERNAL_ERROR_TOO_LITTLE_WORKSPACE (2)
- There is not enough memory for the workspace. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_WORKSPACE_ALLOCATION (3)
- An allocation from the workspace failed. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL (4)
- The configured interrupt stack size is too small. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_THREAD_EXITTED (5)
A non-POSIX thread entry function returned. This is an API usage error.
An example code to provoke this fatal error is:
void task( rtems_arg arg ) { /* Classic API tasks must not return */ } void create_bad_task( void ) { rtems_status_code sc; rtems_id task_id; sc = rtems_task_create( rtems_build_name('T', 'A', 'S', 'K'), 1, RTEMS_DEFAULT_MODES, RTEMS_DEFAULT_ATTRIBUTES, &task_id ); assert( sc == RTEMS_SUCCESSFUL ); sc = rtems_task_start( task_id, task, 0 ); assert( sc == RTEMS_SUCCESSFUL ); }
- INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION (6)
- This fatal error can only occur on MPCI configurations. The MPCI nodes or global objects configuration is inconsistent. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_INVALID_NODE (7)
- This fatal error can only occur on MPCI configurations. The own MPCI node number is invalid. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_NO_MPCI (8)
- This fatal error can only occur on MPCI configurations. There is no MPCI configuration table. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_BAD_PACKET (9)
- This fatal error can only occur on MPCI configurations. The MPCI server thread received a bad packet.
- INTERNAL_ERROR_OUT_OF_PACKETS (10)
- This fatal error can only occur on MPCI configurations. The MPCI packet pool is empty. It is an application configuration error.
- INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS (11)
- This fatal error can only occur on MPCI configurations. The MPCI global objects pool is empty. It is an application configuration error.
- INTERNAL_ERROR_OUT_OF_PROXIES (12)
- This fatal error can only occur on MPCI configurations. The MPCI thread proxy pool is empty. It is an application configuration error.
- INTERNAL_ERROR_INVALID_GLOBAL_ID (13)
- This fatal error can only occur on MPCI configurations. The system cannot find the global object for a specific object identifier. In case this happens, then this is probably an operating system bug.
- INTERNAL_ERROR_BAD_STACK_HOOK (14)
- The stack allocator hook or stack free hook is NULL. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0 (19)
- An object class is configured to use the unlimited objects option, however, the count of objects for each extension is zero. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_NO_MEMORY_FOR_HEAP (23)
- There is not enough memory for the C program heap. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR (24)
- The use of
_CPU_ISR_install_vector()is illegal on this system. - INTERNAL_ERROR_RESOURCE_IN_USE (25)
- This fatal error can only occur on debug configurations. It happens in case a thread which owns mutexes is deleted. Mutexes owned by a deleted thread are in an inconsistent state.
- INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL (26)
- An RTEMS initialization task entry function is NULL. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK (28)
- A deadlock was detected during a thread queue enqueue operation.
- INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE (29)
This fatal error can only happen in SMP configurations. It is not allowed to obtain MrsP semaphores in a context with thread dispatching disabled, for example interrupt context.
void bad( rtems_id timer_id, void *arg ) { rtems_id *sem_id; sem_id = arg; rtems_semaphore_obtain( *sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT ); assert( 0 ); } void fire_bad_timer( rtems_task_argument arg ) { rtems_status_code sc; rtems_id sem_id; rtems_id timer_id; sc = rtems_semaphore_create( rtems_build_name('M', 'R', 'S', 'P'), 1, RTEMS_MULTIPROCESSOR_RESOURCE_SHARING | RTEMS_BINARY_SEMAPHORE, 1, &sem_id ); assert( sc == RTEMS_SUCCESSFUL ); sc = rtems_timer_create( rtems_build_name( 'E', 'V', 'I', 'L' ), &timer_id ); assert( sc == RTEMS_SUCCESSFUL ); sc = rtems_semaphore_obtain( sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT ); assert( sc == RTEMS_SUCCESSFUL ); sc = rtems_timer_fire_after( timer_id, 1, bad, &sem_id ); assert( sc == RTEMS_SUCCESSFUL ); rtems_task_wake_after( 2 ); assert( 0 ); }
- INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL (30)
It is illegal to call blocking operating system services with thread dispatching disabled, for example in interrupt context.
void bad( rtems_id id, void *arg ) { rtems_task_wake_after( RTEMS_YIELD_PROCESSOR ); assert( 0 ); } void fire_bad_timer( void ) { rtems_status_code sc; rtems_id id; sc = rtems_timer_create( rtems_build_name( 'E', 'V', 'I', 'L' ), &id ); assert( sc == RTEMS_SUCCESSFUL ); sc = rtems_timer_fire_after( id, 1, bad, NULL ); assert( sc == RTEMS_SUCCESSFUL ); rtems_task_wake_after( 2 ); assert( 0 ); }
- INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT (31)
In SMP configurations, it is a fatal error to call blocking operating system with interrupts disabled, since this prevents delivery of inter-processor interrupts. This could lead to executing threads which are not allowed to execute resulting in undefined system behaviour.
Some CPU ports, for example the ARM Cortex-M port, have a similar problem, since the interrupt state is not a part of the thread context.
This fatal error is detected in the operating system core function
_Thread_Do_dispatch()responsible to carry out a thread dispatch.An example code to provoke this fatal error is:
void bad( void ) { rtems_interrupt_level level; rtems_interrupt_local_disable( level ); rtems_task_suspend( RTEMS_SELF ); rtems_interrupt_local_enable( level ); }
- INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED (32)
- Creation of an RTEMS initialization task failed. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED (33)
- Creation of a POSIX initialization thread failed. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED (34)
- Creation of the IO library user environment POSIX key failed. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED (35)
- Creation of the IO library semaphore failed. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED (36)
- Open of the standard output file descriptor failed or resulted in an unexpected file descriptor number. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED (37)
- Open of the standard error file descriptor failed or resulted in an unexpected file descriptor number. This fatal error may occur during system initialization. It is an application configuration error.
- INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT (38)
- The floating point unit was used illegally, for example in interrupt context on some architectures.
- INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL (39)
- A
getentropy()system call failed in one of the ARC4RANDOM(3) functions. This fatal error can only be fixed with a different implementation ofgetentropy().
21.3. Operations¶
21.3.1. Announcing a Fatal Error¶
The _Terminate() internal error handler is invoked when the
application or the executive itself determines that a fatal error has occurred
or a final system state is reached (for example after rtems_fatal()
or exit()).
The first action of the internal error handler is to call the fatal extension of the user extensions. For the initial extensions the following conditions are required
- a valid stack pointer and enough stack space,
- a valid code memory, and
- valid read-only data.
For the initial extensions the read-write data (including .bss segment) is not required on single processor configurations. In SMP configurations, however, the read-write data must be initialized since this function must determine the state of the other processors and request them to shut-down if necessary.
Non-initial extensions require in addition valid read-write data. The board support package (BSP) may install an initial extension that performs a system reset. In this case the non-initial extensions will be not called.
The fatal extensions are called with three parameters:
- the fatal source,
- a legacy parameter which is always false, and
- an error code with a fatal source dependent content.
Once all fatal extensions executed, the error information will be stored to
_Internal_errors_What_happened and the system state is set to
SYSTEM_STATE_TERMINATED.
The final step is to call the CPU port specific _CPU_Fatal_halt().
21.4. Directives¶
This section details the fatal error manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
21.4.1. FATAL - Invoke the fatal error handler¶
- CALLING SEQUENCE:
void rtems_fatal( rtems_fatal_source fatal_source, rtems_fatal_code error_code ) RTEMS_NO_RETURN;
- DIRECTIVE STATUS CODES:
- NONE - This function will not return to the caller.
- DESCRIPTION:
- This directive terminates the system.
- NOTE:
- Registered
atexit()oron_exit()handlers are not called. Useexit()in case these handlers should be invoked.
21.4.2. PANIC - Print a message and invoke the fatal error handler¶
- CALLING SEQUENCE:
void rtems_panic( const char *fmt, ... ) RTEMS_NO_RETURN RTEMS_PRINTFLIKE( 1, 2 );
- DESCRIPTION:
- This directive prints a message via
printk()specified by the format and optional parameters and then terminates the system with theRTEMS_FATAL_SOURCE_PANICfatal source. The fatal code is set to the format string address. - NOTE:
- Registered
21.4.3. SHUTDOWN_EXECUTIVE - Shutdown RTEMS¶
- CALLING SEQUENCE:
void rtems_shutdown_executive( uint32_t result );
- DESCRIPTION:
- This directive is called when the application wishes to shutdown RTEMS.
The system is terminated with a fatal source of
RTEMS_FATAL_SOURCE_EXITand the specifiedresultcode. - NOTES:
This directive must be the last RTEMS directive invoked by an application and it does not return to the caller.
This directive may be called any time.
21.4.4. EXCEPTION_FRAME_PRINT - Prints the exception frame¶
- CALLING SEQUENCE:
void rtems_exception_frame_print( const rtems_exception_frame *frame );
- NONE
- DESCRIPTION:
- Prints the exception frame via
printk().
21.4.5. FATAL_SOURCE_TEXT - Returns a text for a fatal source¶
- CALLING SEQUENCE:
const char *rtems_fatal_source_text( rtems_fatal_source source );
- The fatal source text or “?” in case the passed fatal source is invalid.
- DESCRIPTION:
- Returns a text for a fatal source. The text for fatal source is the enumerator constant.
21.4.6. INTERNAL_ERROR_TEXT - Returns a text for an internal error code¶
- CALLING SEQUENCE:
const char *rtems_internal_error_text( rtems_fatal_code error );
- The error code text or “?” in case the passed error code is invalid.
- DESCRIPTION:
- Returns a text for an internal error code. The text for each internal error code is the enumerator constant.
21.4.7. FATAL_ERROR_OCCURRED - Invoke the fatal error handler (deprecated)¶
- CALLING SEQUENCE:
void rtems_fatal_error_occurred( uint32_t the_error ) RTEMS_NO_RETURN;
- DESCRIPTION:
- This directive processes fatal errors. If the FATAL error extension is defined in the configuration table, then the user-defined error extension is called. If configured and the provided FATAL error extension returns, then the RTEMS default error handler is invoked. This directive can be invoked by RTEMS or by the user’s application code including initialization tasks, other tasks, and ISRs.
- NOTES:
This directive is deprecated and should not be used in new code.
This directive supports local operations only.
Unless the user-defined error extension takes special actions such as restarting the calling task, this directive WILL NOT RETURN to the caller.
The user-defined extension for this directive may wish to initiate a global shutdown.
