31. Object Services¶
31.1. Introduction¶
RTEMS provides a collection of services to assist in the management and usage of the objects created and utilized via other managers. These services assist in the manipulation of RTEMS objects independent of the API used to create them. The object related services provided by RTEMS are:
- build_id
- rtems_build_name - build object name from characters
- rtems_object_get_classic_name - lookup name from Id
- rtems_object_get_name - obtain object name as string
- rtems_object_set_name - set object name
- rtems_object_id_get_api - obtain API from Id
- rtems_object_id_get_class - obtain class from Id
- rtems_object_id_get_node - obtain node from Id
- rtems_object_id_get_index - obtain index from Id
- rtems_build_id - build object id from components
- rtems_object_id_api_minimum - obtain minimum API value
- rtems_object_id_api_maximum - obtain maximum API value
- rtems_object_id_api_minimum_class - obtain minimum class value
- rtems_object_id_api_maximum_class - obtain maximum class value
- rtems_object_get_api_name - obtain API name
- rtems_object_get_api_class_name - obtain class name
- rtems_object_get_class_information - obtain class information
31.2. Background¶
31.2.1. APIs¶
RTEMS implements multiple APIs including an Internal API, the Classic API, and the POSIX API. These APIs share the common foundation of SuperCore objects and thus share object management code. This includes a common scheme for object Ids and for managing object names whether those names be in the thirty-two bit form used by the Classic API or C strings.
The object Id contains a field indicating the API that an object instance is associated with. This field holds a numerically small non-zero integer.
31.2.2. Object Classes¶
Each API consists of a collection of managers. Each manager is responsible for instances of a particular object class. Classic API Tasks and POSIX Mutexes example classes.
The object Id contains a field indicating the class that an object instance is associated with. This field holds a numerically small non-zero integer. In all APIs, a class value of one is reserved for tasks or threads.
31.2.3. Object Names¶
Every RTEMS object which has an Id may also have a name associated with it. Depending on the API, names may be either thirty-two bit integers as in the Classic API or strings as in the POSIX API.
Some objects have Ids but do not have a defined way to associate a name with
them. For example, POSIX threads have Ids but per POSIX do not have names. In
RTEMS, objects not defined to have thirty-two bit names may have string names
assigned to them via the rtems_object_set_name service. The original
impetus in providing this service was so the normally anonymous POSIX threads
could have a user defined name in CPU Usage Reports.
31.3. Operations¶
31.3.1. Decomposing and Recomposing an Object Id¶
Services are provided to decompose an object Id into its subordinate components. The following services are used to do this:
rtems_object_id_get_apirtems_object_id_get_classrtems_object_id_get_nodertems_object_id_get_index
The following C language example illustrates the decomposition of an Id and printing the values.
void printObjectId(rtems_id id)
printf(
"API=%d Class=%d Node=%d Index=%d\n",
rtems_object_id_get_api(id),
rtems_object_id_get_class(id),
rtems_object_id_get_node(id),
rtems_object_id_get_index(id)
This prints the components of the Ids as integers.
It is also possible to construct an arbitrary Id using the rtems_build_id
service. The following C language example illustrates how to construct the
“next Id.”
rtems_id nextObjectId(rtems_id id)
return rtems_build_id(
rtems_object_id_get_index(id) + 1
Note that this Id may not be valid in this system or associated with an allocated object.
31.3.2. Printing an Object Id¶
RTEMS also provides services to associate the API and Class portions of an Object Id with strings. This allows the application developer to provide more information about an object in diagnostic messages.
In the following C language example, an Id is decomposed into its constituent parts and “pretty-printed.”
void prettyPrintObjectId(rtems_id id)
int tmpAPI, tmpClass;
tmpAPI = rtems_object_id_get_api(id),
tmpClass = rtems_object_id_get_class(id),
printf(
"API=%s Class=%s Node=%d Index=%d\n",
rtems_object_get_api_name(tmpAPI),
rtems_object_get_api_class_name(tmpAPI, tmpClass),
31.4. Directives¶
31.4.1. BUILD_NAME - Build object name from characters¶
- CALLING SEQUENCE:
rtems_name rtems_build_name( uint8_t c1, uint8_t c2, uint8_t c3, uint8_t c4 );
- DIRECTIVE STATUS CODES:
- Returns a name constructed from the four characters.
- DESCRIPTION:
- This service takes the four characters provided as arguments and constructs
a thirty-two bit object name with
c1in the most significant byte andc4in the least significant byte. - NOTES:
- This directive is strictly local and does not impact task scheduling.
31.4.2. OBJECT_GET_CLASSIC_NAME - Lookup name from id¶
- CALLING SEQUENCE:
rtems_status_code rtems_object_get_classic_name( rtems_id id, rtems_name *name );
RTEMS_SUCCESSFULname looked up successfully RTEMS_INVALID_ADDRESSinvalid name pointer RTEMS_INVALID_IDinvalid object id - DESCRIPTION:
- This service looks up the name for the object
idspecified and, if found, places the result in*name. - NOTES:
31.4.3. OBJECT_GET_NAME - Obtain object name as string¶
- CALLING SEQUENCE:
char* rtems_object_get_name( rtems_id id, size_t length, char *name );
- Returns a pointer to the name if successful or
NULLotherwise. - DESCRIPTION:
- This service looks up the name of the object specified by
idand places it in the memory pointed to byname. Every attempt is made to return name as a printable string even if the object has the Classic API thirty-two bit style name. - NOTES:
31.4.4. OBJECT_SET_NAME - Set object name¶
- CALLING SEQUENCE:
rtems_status_code rtems_object_set_name( rtems_id id, const char *name );
- This service sets the name of
idto that specified by the string located atname. - NOTES:
If the object specified by
idis of a class that has a string name, this method will free the existing name to the RTEMS Workspace and allocate enough memory from the RTEMS Workspace to make a copy of the string located atname.If the object specified by
idis of a class that has a thirty-two bit integer style name, then the first four characters in*namewill be used to construct the name. name to the RTEMS Workspace and allocate enough memory from the RTEMS Workspace to make a copy of the string
31.4.5. OBJECT_ID_GET_API - Obtain API from Id¶
- CALLING SEQUENCE:
int rtems_object_id_get_api( rtems_id id );
- Returns the API portion of the object Id.
- DESCRIPTION:
- This directive returns the API portion of the provided object
id. - NOTES:
This directive does NOT validate the
idprovided.
31.4.6. OBJECT_ID_GET_CLASS - Obtain Class from Id¶
- CALLING SEQUENCE:
int rtems_object_id_get_class( rtems_id id );
- Returns the class portion of the object Id.
- DESCRIPTION:
- This directive returns the class portion of the provided object
id. - NOTES:
idprovided.
31.4.7. OBJECT_ID_GET_NODE - Obtain Node from Id¶
- CALLING SEQUENCE:
int rtems_object_id_get_node( rtems_id id );
- Returns the node portion of the object Id.
- DESCRIPTION:
- This directive returns the node portion of the provided object
id. - NOTES:
idprovided.
31.4.8. OBJECT_ID_GET_INDEX - Obtain Index from Id¶
- CALLING SEQUENCE:
int rtems_object_id_get_index( rtems_id id );
- Returns the index portion of the object Id.
- DESCRIPTION:
- This directive returns the index portion of the provided object
id. - NOTES:
idprovided.
31.4.9. BUILD_ID - Build Object Id From Components¶
- CALLING SEQUENCE:
rtems_id rtems_build_id( int the_api, int the_class, int the_node, int the_index );
- Returns an object Id constructed from the provided arguments.
- DESCRIPTION:
- This service constructs an object Id from the provided
the_api,the_class,the_node, andthe_index. - NOTES:
This directive does NOT validate the arguments provided or the Object id returned.
31.4.10. OBJECT_ID_API_MINIMUM - Obtain Minimum API Value¶
- CALLING SEQUENCE:
int rtems_object_id_api_minimum(void);
- Returns the minimum valid for the API portion of an object Id.
- DESCRIPTION:
- This service returns the minimum valid for the API portion of an object Id.
- NOTES:
31.4.11. OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value¶
- CALLING SEQUENCE:
int rtems_object_id_api_maximum(void);
- Returns the maximum valid for the API portion of an object Id.
- DESCRIPTION:
- This service returns the maximum valid for the API portion of an object Id.
- NOTES:
31.4.12. OBJECT_API_MINIMUM_CLASS - Obtain Minimum Class Value¶
- CALLING SEQUENCE:
int rtems_object_api_minimum_class( int api );
If
apiis not valid, -1 is returned.If successful, this service returns the minimum valid for the class portion of an object Id for the specified
api.- DESCRIPTION:
- This service returns the minimum valid for the class portion of an object
api. - NOTES:
31.4.13. OBJECT_API_MAXIMUM_CLASS - Obtain Maximum Class Value¶
- CALLING SEQUENCE:
int rtems_object_api_maximum_class( int api );
If
apiis not valid, -1 is returned.If successful, this service returns the maximum valid for the class portion of an object Id for the specified
api.- DESCRIPTION:
- This service returns the maximum valid for the class portion of an object
api. - NOTES:
31.4.14. OBJECT_ID_API_MINIMUM_CLASS - Obtain Minimum Class Value for an API¶
- CALLING SEQUENCE:
int rtems_object_get_id_api_minimum_class( int api );
If
apiis not valid, -1 is returned.If successful, this service returns the index corresponding to the first object class of the specified
api.- DESCRIPTION:
- This service returns the index for the first object class associated with
the specified
api. - NOTES:
31.4.15. OBJECT_ID_API_MAXIMUM_CLASS - Obtain Maximum Class Value for an API¶
- CALLING SEQUENCE:
int rtems_object_get_api_maximum_class( int api );
If
apiis not valid, -1 is returned.If successful, this service returns the index corresponding to the last object class of the specified
api.- DESCRIPTION:
- This service returns the index for the last object class associated with
the specified
api. - NOTES:
31.4.16. OBJECT_GET_API_NAME - Obtain API Name¶
- CALLING SEQUENCE:
const char* rtems_object_get_api_name( int api );
If
apiis not valid, the string"BAD API"is returned.If successful, this service returns a pointer to a string containing the name of the specified
api.- DESCRIPTION:
- This service returns the name of the specified
api. - NOTES:
The string returned is from constant space. Do not modify or free it.
31.4.17. OBJECT_GET_API_CLASS_NAME - Obtain Class Name¶
- CALLING SEQUENCE:
const char *rtems_object_get_api_class_name( int the_api, int the_class );
If
the_apiis not valid, the string"BAD API"is returned.If
the_classis not valid, the string"BAD CLASS"is returned.If successful, this service returns a pointer to a string containing the name of the specified
the_api/the_classpair.- DESCRIPTION:
- This service returns the name of the object class indicated by the
specified
the_apiandthe_class. - NOTES:
31.4.18. OBJECT_GET_CLASS_INFORMATION - Obtain Class Information¶
- CALLING SEQUENCE:
rtems_status_code rtems_object_get_class_information( int the_api, int the_class, rtems_object_api_class_information *info );
RTEMS_SUCCESSFULinformation obtained successfully RTEMS_INVALID_ADDRESSinfois NULLRTEMS_INVALID_NUMBERinvalid apiorthe_classIf successful, the structure located at
infowill be filled in with information about the specifiedapi/the_classpairing.- DESCRIPTION:
This service returns information about the object class indicated by the specified
apiandthe_class. This structure is defined as follows:typedef struct { rtems_id minimum_id; rtems_id maximum_id; int maximum; bool auto_extend; int unallocated; } rtems_object_api_class_information;
- NOTES:
