RTEMS 7.0-rc1
rtems_can_stats Struct Reference
This structure is used to represent CAN statistics. More...
#include <can-stats.h>
unsigned long tx_done
 This member holds number of succesful TX frames.
unsigned long rx_done
 This member holds number of succesful RX frames.
unsigned long tx_bytes
 This member holds number of bytes succesfully send.
unsigned long rx_bytes
 This member holds number of bytes succesfully received.
unsigned long tx_error
 This member holds number of TX errors.
unsigned long rx_error
 This member holds number of RX errors.
unsigned long rx_overflows
 This member holds number of overflows on RX side.
int chip_state
 This member holds controller's state (error active, passive, bus off)
