Here is a list of all documented struct and union fields with links to the struct/union documentation for each field:
- c -
- C : APSR_Type, xPSR_Type
- C0 : CMP_Type, ISI_R2Y, ISI_Y2R
- C1 : _pxp_csc2_config, CMP_Type, ISI_R2Y, ISI_Y2R
- C1ICR : HSEM_TypeDef
- C1IER : HSEM_TypeDef
- C1ISR : HSEM_TypeDef
- C1MISR : HSEM_TypeDef
- C2 : _pxp_csc2_config, CMP_Type, ISI_R2Y, ISI_Y2R
- C2EMR1 : EXTI_TypeDef
- C2EMR2 : EXTI_TypeDef
- C2EMR3 : EXTI_TypeDef
- C2ICR : HSEM_TypeDef
- C2IER : HSEM_TypeDef
- C2IMR1 : EXTI_TypeDef
- C2IMR2 : EXTI_TypeDef
- C2IMR3 : EXTI_TypeDef
- C2ISR : HSEM_TypeDef
- C2MISR : HSEM_TypeDef
- C2PR1 : EXTI_TypeDef
- C2PR2 : EXTI_TypeDef
- C2PR3 : EXTI_TypeDef
- C3 : _pxp_csc2_config, CMP_Type, ISI_R2Y, ISI_Y2R
- C4 : ISI_R2Y, ISI_Y2R
- C5 : ISI_R2Y
- C6 : ISI_R2Y
- C7 : ISI_R2Y
- C8 : ISI_R2Y
- CA : MMCAU_Type
- CAA : MMCAU_Type
- CAAMVID_LS : CAAM_Type
- CAAMVID_LS_DC01 : CAAM_Type
- CAAMVID_LS_JR : CAAM_Type
- CAAMVID_LS_RTIC : CAAM_Type
- CAAMVID_LS_TRAD : CAAM_Type
- CAAMVID_MS : CAAM_Type
- CAAMVID_MS_DC01 : CAAM_Type
- CAAMVID_MS_JR : CAAM_Type
- CAAMVID_MS_RTIC : CAAM_Type
- CAAMVID_MS_TRAD : CAAM_Type
- cache : rtems_bdbuf_buffer::rtems_bdbuf_avl_node, rtems_rtl_obj_cpmp
- cache_id : L2CC
- cache_sync : L2CC
- cache_type : L2CC
- CACR : LTDC_Layer_TypeDef, SCB_Type
- CACRR : CCM_Type
- CAL : ADC_Type
- CALFACT : ADC_TypeDef
- CALFACT2 : ADC_TypeDef
- CALFACT2_RES14 : ADC_TypeDef
- CALFACT_RES13 : ADC_TypeDef
- CALIB : SysTick_Type
- callback : _asrc_edma_handle, _asrc_in_handle, _asrc_out_handle, _Async, _AsyncTwi, _csi_handle, _dsi_handle, _edma_handle, _enet_config, _enet_handle, _flexcan_edma_handle, _flexcan_handle, _flexio_camera_edma_handle, _flexio_i2s_dma_handle, _flexio_i2s_edma_handle, _flexio_i2s_handle, _flexio_spi_master_dma_handle, _flexio_spi_master_edma_handle, _flexio_spi_master_handle, _flexio_uart_dma_handle, _flexio_uart_edma_handle, _flexio_uart_handle, _lpi2c_slave_handle, _lpspi_master_edma_handle, _lpspi_master_handle, _lpspi_slave_edma_handle, _lpspi_slave_handle, _lpuart_dma_handle, _lpuart_edma_handle, _lpuart_handle, _pdm_edma_handle, _pdm_handle, _pdm_sdma_handle, _sai_handle, _sai_sdma_handle, _spdif_edma_handle, _spdif_handle, _SpidCmd, _usdhc_handle, AfeCmd, DacCmd, sai_edma_handle, UartChannel, UsartChannel
- caller_thread : rtems_aio_request
- calls : RtemsTaskReqDelete_Context, RtemsTaskReqRestart_Context
- calls_after_restart : RtemsTaskReqDelete_Context, RtemsTaskReqRestart_Context
- CALR : RTC_TypeDef
- can_be_triggered_by_message : rtems_interrupt_attributes
- can_clear : rtems_interrupt_attributes
- can_disable : rtems_interrupt_attributes
- can_enable : rtems_interrupt_attributes
- can_get_affinity : rtems_interrupt_attributes
- can_get_priority : rtems_interrupt_attributes, RtemsIntrReqGetPriority_Context
- can_raise : rtems_interrupt_attributes
- can_raise_on : rtems_interrupt_attributes
- can_set_affinity : rtems_interrupt_attributes
- can_set_priority : rtems_interrupt_attributes, RtemsIntrReqSetPriority_Context
- cancel_job : Scheduler_Operations
- cancode : grcan
- canconf : grcan
- canctrl : grcan
- canmask : grcan
- canrxaddr : grcan
- canrxcode : grcan
- canrxctrl : grcan
- canrxirq : grcan
- canrxmask : grcan
- canrxrd : grcan
- canrxsize : grcan
- canrxwr : grcan
- canstat : grcan
- cantxaddr : grcan
- cantxctrl : grcan
- cantxirq : grcan
- cantxrd : grcan
- cantxsize : grcan
- cantxwr : grcan
- cap : grgpio, grspwrouter, spictrl
- cap0 : griommu
- cap1 : griommu
- cap2 : griommu
- capabilities : rtems_disk_device
- Capabilities : RTEMS_PACKED
- capability : _usdhc_host
- CAPABILITY0 : DCP_Type
- CAPABILITY1 : DCP_Type
- CAPLENGTH : USB_Type
- CAPT : TMR_Type
- CAPTCOMPA : PWM_Type
- CAPTCOMPB : PWM_Type
- CAPTCOMPX : PWM_Type
- CAPTCTRLA : PWM_Type
- CAPTCTRLB : PWM_Type
- CAPTCTRLX : PWM_Type
- captureInputSel : _pwm_input_capture_param
- CardComdClasses : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- CardInserted : _usdhc_transfer_callback
- cardParams : _smartcard_context
- CardRemoved : _usdhc_transfer_callback
- CardSpeed : HAL_SD_CardInfoTypeDef
- CardType : HAL_MMC_CardInfoTypeDef, HAL_SD_CardInfoTypeDef, HAL_SD_CardStatusTypeDef
- CardVersion : HAL_SD_CardInfoTypeDef
- cascade : rtems_test_parallel_job
- casLatency : _semc_sdram_config
- CASLatency : FMC_SDRAM_InitTypeDef
- CASR : MMCAU_Type
- catch_status : RtemsSignalReqCatch_Context
- CBCDR : CCM_Type
- CBCMR : CCM_Type
- CbkBuffFull : _SpioCaptureInit
- CbkDataReady : _SpioCaptureInit
- CbkEndReception : _SpioCaptureInit
- CbkOverrun : _SpioCaptureInit
- CBNDTR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- Cboff : ISI_Y2R
- CBRUR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- cbs_budget_overrun : Scheduler_CBS_Server
- cbs_server : Scheduler_CBS_Node
- CBT : CAN_Type
- CC1AADSZR : CAAM_Type
- CC1CTXR : CAAM_Type
- CC1DSR : CAAM_Type
- CC1ICVSR : CAAM_Type
- CC1IVSZR : CAAM_Type
- CC1KR : CAAM_Type
- CC1KSR : CAAM_Type
- CC1MR : CAAM_Type
- CC1MR_PK : CAAM_Type
- CC1MR_RNG : CAAM_Type
- CC2CTXR : CAAM_Type
- CC2DSR : CAAM_Type
- CC2ICVSZR : CAAM_Type
- CC2KEYR : CAAM_Type
- CC2KSR : CAAM_Type
- CC2MR : CAAM_Type
- CCBVID : CAAM_Type
- CCBVID_DC01 : CAAM_Type
- CCBVID_JR : CAAM_Type
- CCBVID_RTIC : CAAM_Type
- CCCR : FDCAN_GlobalTypeDef, SYSCFG_TypeDef
- CCCSR : SYSCFG_TypeDef
- CCCTRL : CAAM_Type
- CCER : TIM_TypeDef
- CCFG : FDCAN_ClockCalibrationUnit_TypeDef
- CCFG_CAN0 : Matrix
- CCFG_SMCNFCS : Matrix
- CCFG_SYSIO : Matrix
- CCGR0 : CCM_Type
- CCGR1 : CCM_Type
- CCGR2 : CCM_Type
- CCGR3 : CCM_Type
- CCGR4 : CCM_Type
- CCGR5 : CCM_Type
- CCGR6 : CCM_Type
- cclksel : lpc176x_scb
- CCMR1 : TIM_TypeDef
- CCMR2 : TIM_TypeDef
- CCMR3 : TIM_TypeDef
- CCOSR : CCM_Type
- CCR : ADC_Common_TypeDef, BDMA_Channel_TypeDef, CCM_Type, DAC_TypeDef, DMAMUX_Channel_TypeDef, DSI_TypeDef, GFXMMU_TypeDef, lpc176x_timer_device, LPSPI_Type, MDMA_Channel_TypeDef, OCTOSPI_TypeDef, QUADSPI_TypeDef, SCB_Type, VREFBUF_TypeDef
- CCR1 : FLASH_TypeDef, TIM_TypeDef
- CCR2 : FLASH_TypeDef, TIM_TypeDef
- CCR3 : TIM_TypeDef
- CCR4 : TIM_TypeDef
- CCR5 : TIM_TypeDef
- CCR6 : TIM_TypeDef
- CCSIDR : SCB_Type
- CCSR : CCM_Type
- CCSTA_LS : CAAM_Type
- CCSTA_MS : CAAM_Type
- cctrl_0 : l4stat
- cctrl_1 : l4stat
- CCVR : SYSCFG_TypeDef
- CCWR : CAAM_Type
- CDAR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- CDCCIP1R : RCC_TypeDef
- CDCCIP2R : RCC_TypeDef
- CDCCIPR : RCC_TypeDef
- CDCDR : CCM_Type
- CDCFGR1 : RCC_TypeDef
- CDCFGR2 : RCC_TypeDef
- CDHIPR : CCM_Type
- CDNE : DMA_Type
- CDR : ADC_Common_TypeDef
- CDR2 : ADC_Common_TypeDef
- CDSR : LTDC_TypeDef
- CecClockSelection : RCC_PeriphCLKInitTypeDef
- CEEI : DMA_Type
- cePinMux : _semc_nand_config, _semc_nor_config, _semc_sram_config
- CERQ : DMA_Type
- CERR : DMA_Type
- CESR : MDMA_Channel_TypeDef
- cet0 : spwtdp
- cet1 : spwtdp
- cet2 : spwtdp
- cet3 : spwtdp
- cet4 : spwtdp
- cfaValue : _pxp_lut_config
- CFBAR : LTDC_Layer_TypeDef
- CFBLNR : LTDC_Layer_TypeDef
- CFBLR : LTDC_Layer_TypeDef
- CFG : ADC_Type
- cfg : lpc176x_pll
- CFG : PUF_Type
- CFG0 : OCOTP_Type
- CFG1 : OCOTP_Type, SPI_TypeDef
- CFG2 : OCOTP_Type, SPI_TypeDef
- CFG3 : OCOTP_Type
- CFG4 : OCOTP_Type
- CFG5 : OCOTP_Type
- CFG6 : OCOTP_Type
- CFG_AUTOINSERT_EOTP : DSI_HOST_Type
- CFG_BTA_H_TO_COUNT : DSI_HOST_Type
- CFG_DISABLE_DATA_LANES : MIPI_CSI2RX_Type
- CFG_DISABLE_PAYLOAD_0 : MIPI_CSI2RX_Type
- CFG_DISABLE_PAYLOAD_1 : MIPI_CSI2RX_Type
- CFG_EXTRA_CMDS_AFTER_EOTP : DSI_HOST_Type
- CFG_HTX_TO_COUNT : DSI_HOST_Type
- CFG_IGNORE_VC : MIPI_CSI2RX_Type
- CFG_LRX_H_TO_COUNT : DSI_HOST_Type
- CFG_NONCONTINUOUS_CLK : DSI_HOST_Type
- CFG_NUM_LANES : DSI_HOST_Type, MIPI_CSI2RX_Type
- CFG_STATUS_OUT : DSI_HOST_Type
- CFG_T_POST : DSI_HOST_Type
- CFG_T_PRE : DSI_HOST_Type
- CFG_TWAKEUP : DSI_HOST_Type
- CFG_TX_GAP : DSI_HOST_Type
- CFG_VID_HSYNC : MIPI_CSI2RX_Type
- CFG_VID_HSYNC_BP : MIPI_CSI2RX_Type
- CFG_VID_HSYNC_FP : MIPI_CSI2RX_Type
- CFG_VID_P_FIFO_SEND_LEVEL : MIPI_CSI2RX_Type
- CFG_VID_VC : MIPI_CSI2RX_Type
- CFG_VID_VSYNC : MIPI_CSI2RX_Type
- CFGR : ADC_TypeDef, CEC_TypeDef, COMP_Common_TypeDef, COMP_TypeDef, CRS_TypeDef, DLYB_TypeDef, LPTIM_TypeDef, RCC_TypeDef, RTC_TypeDef, SYSCFG_TypeDef, TAMP_TypeDef
- CFGR0 : LPSPI_Type
- CFGR1 : DTS_TypeDef, LPSPI_Type
- CFGR2 : ADC_TypeDef, LPTIM_TypeDef
- cfgwe : grspwrouter
- CFI_1 : NOR_CFITypeDef
- CFIFOSTA : CAAM_Type
- CFR : DMAMUX_ChannelStatus_TypeDef, JPEG_TypeDef, WWDG_TypeDef
- CFSR : SCB_Type
- CGPR : CCM_Type
- CH0CMDPTR : DCP_Type
- CH0OPTS : DCP_Type
- CH0OPTS_CLR : DCP_Type
- CH0OPTS_SET : DCP_Type
- CH0OPTS_TOG : DCP_Type
- CH0SEMA : DCP_Type
- CH0STAT : DCP_Type
- CH0STAT_CLR : DCP_Type
- CH0STAT_SET : DCP_Type
- CH0STAT_TOG : DCP_Type
- CH1CMDPTR : DCP_Type
- CH1OPTS : DCP_Type
- CH1OPTS_CLR : DCP_Type
- CH1OPTS_SET : DCP_Type
- CH1OPTS_TOG : DCP_Type
- CH1SEMA : DCP_Type
- CH1STAT : DCP_Type
- CH1STAT_CLR : DCP_Type
- CH1STAT_SET : DCP_Type
- CH1STAT_TOG : DCP_Type
- CH2CMDPTR : DCP_Type
- CH2OPTS : DCP_Type
- CH2OPTS_CLR : DCP_Type
- CH2OPTS_SET : DCP_Type
- CH2OPTS_TOG : DCP_Type
- CH2SEMA : DCP_Type
- CH2STAT : DCP_Type
- CH2STAT_CLR : DCP_Type
- CH2STAT_SET : DCP_Type
- CH2STAT_TOG : DCP_Type
- CH3CMDPTR : DCP_Type
- CH3OPTS : DCP_Type
- CH3OPTS_CLR : DCP_Type
- CH3OPTS_SET : DCP_Type
- CH3OPTS_TOG : DCP_Type
- CH3SEMA : DCP_Type
- CH3STAT : DCP_Type
- CH3STAT_CLR : DCP_Type
- CH3STAT_SET : DCP_Type
- CH3STAT_TOG : DCP_Type
- Chain : Thread_Zombie_registry, Watchdog_Control
- chain_node : rtems_rbheap_chunk
- chainedNextCommandNumber : lpadc_conv_command_config_t
- channel : _asrc_p2p_edma_config, _dcp_handle, _edma_handle, _pdm_hwvad_config, _sai_handle, _sai_sdma_handle, _sai_transfer_format
- Channel : ADC_AnalogWDGConfTypeDef, ADC_ChannelConfTypeDef, DFSDM_Filter_AwdParamTypeDef
- channel : sai_edma_handle
- Channel : TIM_HandleTypeDef
- ChannelCount : ADC_InjectionConfigTypeDef
- CHANNELCTRL : DCP_Type
- CHANNELCTRL_CLR : DCP_Type
- CHANNELCTRL_SET : DCP_Type
- CHANNELCTRL_TOG : DCP_Type
- channelMask : _sai_handle, _sai_sdma_handle, _sai_transceiver, _sai_transfer_format, sai_edma_handle
- ChannelNState : TIM_HandleTypeDef
- channelNumber : _adc_channel_config, lpadc_conv_command_config_t
- channelNums : _pdm_edma_handle, _pdm_handle, _pdm_sdma_handle, _sai_handle, _sai_sdma_handle, _sai_transceiver, _sai_transfer_format, sai_edma_handle
- channelPair : _asrc_edma_handle, _asrc_handle
- channelPriority : _edma_channel_Preemption_config
- ChannelState : TIM_HandleTypeDef
- CHANUM_LS : CAAM_Type
- CHANUM_LS_DC01 : CAAM_Type
- CHANUM_LS_JR : CAAM_Type
- CHANUM_LS_RTIC : CAAM_Type
- CHANUM_MS : CAAM_Type
- CHANUM_MS_DC01 : CAAM_Type
- CHANUM_MS_JR : CAAM_Type
- CHANUM_MS_RTIC : CAAM_Type
- character : RtemsIoReqPutc_Context, RtemsIoReqPutChar_Context
- chargePumpCurrent : _pmu_snvs_dig_config
- chars : Hash_Control
- CHAVID_LS : CAAM_Type
- CHAVID_LS_DC01 : CAAM_Type
- CHAVID_LS_JR : CAAM_Type
- CHAVID_LS_RTIC : CAAM_Type
- CHAVID_MS : CAAM_Type
- CHAVID_MS_DC01 : CAAM_Type
- CHAVID_MS_JR : CAAM_Type
- CHAVID_MS_RTIC : CAAM_Type
- CHAWSCDR : DFSDM_Channel_TypeDef
- CHCFG : DMAMUX_Type
- CHCFGR1 : DFSDM_Channel_TypeDef
- CHCFGR2 : DFSDM_Channel_TypeDef
- CHDATINR : DFSDM_Channel_TypeDef
- CHDLYR : DFSDM_Channel_TypeDef
- check : rtems_rtl_loader_table
- check_msgq_unchanged : RtemsMessageReqBroadcast_Context, RtemsMessageReqFlushPending_Context, RtemsMessageReqReceive_Context, RtemsMessageReqUrgentSend_Context
- checkerChannelMask : _acmp_round_robin_config
- Checksum : RTEMS_PACKED
- checksum : rtems_rtl_obj, rtems_rtl_rap
- child_bus : rtems_ofw_ranges
- children : drvmgr_bus
- CHIPID_CIDR : Chipid
- CHIPID_EXID : Chipid
- ChNum : UartChannel, UsartChannel
- CHPxR : HRTIM_Timerx_TypeDef
- CHRG_DETECT : USB_ANALOG_Type
- CHRG_DETECT_CLR : USB_ANALOG_Type
- CHRG_DETECT_SET : USB_ANALOG_Type
- CHRG_DETECT_STAT : USB_ANALOG_Type
- CHRG_DETECT_TOG : USB_ANALOG_Type
- chunk_tree : rtems_rbheap_control
- CHWDATAR : DFSDM_Channel_TypeDef
- cicOverSampleRate : _pdm_config, _pdm_hwvad_config
- CICR : RCC_TypeDef
- CICTL : CAAM_Type
- CID : MMC_HandleTypeDef, SD_HandleTypeDef, USB_OTG_GlobalTypeDef
- CID0 : ITM_Type
- CID1 : ITM_Type
- CID2 : ITM_Type
- CID3 : ITM_Type
- CID_CRC : HAL_MMC_CardCIDTypeDef, HAL_SD_CardCIDTypeDef
- CIDR0 : DBGMCU_TypeDef
- CIDR1 : DBGMCU_TypeDef
- CIDR2 : DBGMCU_TypeDef
- CIDR3 : DBGMCU_TypeDef
- CIER : RCC_TypeDef
- CIFCR : MDMA_Channel_TypeDef
- CIFIFO : CAAM_Type
- CIFR : RCC_TypeDef
- CIMR : CCM_Type
- CINT : DMA_Type
- CISR : CCM_Type, MDMA_Channel_TypeDef
- CITER : _edma_tcd
- CITER_ELINKNO : DMA_Type
- CITER_ELINKYES : DMA_Type
- CKCR : LTDC_Layer_TypeDef
- CKGAENR : RCC_TypeDef
- CKGR_MCFR : Pmc
- CKGR_MOR : Pmc
- CKGR_PLLAR : Pmc
- CKGR_UCKR : Pmc
- CkperClockSelection : RCC_PeriphCLKInitTypeDef
- CLAIMCLR : TPI_Type
- CLAIMSET : TPI_Type
- CLAR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- Class : HAL_MMC_CardInfoTypeDef, HAL_SD_CardInfoTypeDef
- class : rtems_rtl_rap
- CLCR : DSI_TypeDef
- clean_blocks : rtems_jffs2_info
- clean_index : L2CC
- clean_inv_indx : L2CC
- clean_inv_pa : L2CC
- clean_inv_way : L2CC
- clean_pa : L2CC
- clean_way : L2CC
- clear : rtems_rtl_obj_flags_data
- cleared_by_acknowledge : rtems_interrupt_attributes
- ClearInputFilter : TIM_ClearInputConfigTypeDef
- ClearInputPolarity : TIM_ClearInputConfigTypeDef
- ClearInputPrescaler : TIM_ClearInputConfigTypeDef
- ClearInputSource : TIM_ClearInputConfigTypeDef
- ClearInputState : TIM_ClearInputConfigTypeDef
- CLIDR : SCB_Type
- client_maximum : rtems_telnetd_config_table
- clk_phase : ALT_QSPI_TIMING_CONFIG_s
- clk_pol : ALT_QSPI_TIMING_CONFIG_s
- CLK_TUNE_CTRL_STATUS : USDHC_Type
- CLKCFG : EMVSIM_Type
- CLKCR : SDMMC_TypeDef
- CLKCTRL : EWM_Type
- clkdiv : grspw2
- CLKDivision : FMC_NORSRAM_TimingTypeDef
- clken : grclkgate
- clkgrpsel : ALT_CLK_GROUP_RAW_CFG_s
- ClkInputPinCap : __attribute__
- CLKLastBit : SMARTCARD_InitTypeDef, USART_InitTypeDef
- clkoutcfg : lpc176x_scb
- CLKPhase : SMARTCARD_InitTypeDef, SPI_InitTypeDef, USART_InitTypeDef
- CLKPolarity : SMARTCARD_InitTypeDef, SPI_InitTypeDef, USART_InitTypeDef
- CLKPRESCALER : EWM_Type
- clkSource : _pmu_well_bias_option
- clkSrc : _flexcan_config
- clksrcsel : lpc176x_scb
- clock : lpc176x_module_entry
- CLOCK : USBHSDCD_Type
- clock_freq : ALT_I2C_DEV_s
- clock_id : CReqClockNanosleep_Context
- clock_offset : i2c_rtc_base
- ClockDiv : SDMMC_InitTypeDef
- ClockDivision : TIM_Base_InitTypeDef
- clockDriver : _adc_config
- ClockEdge : SDMMC_InitTypeDef
- ClockEnable : SAI_PdmInitTypeDef
- ClockFilter : TIM_ClockConfigTypeDef
- clockHoldTime_ns : _lpi2c_slave_config
- clockModule : _smartcard_interface_config
- clockModuleChannel : _smartcard_interface_config
- clockModuleSourceClock : _smartcard_interface_config
- clockOff : _clock_group_config
- ClockPolarity : TIM_ClockConfigTypeDef
- ClockPowerSave : SDMMC_InitTypeDef
- ClockPrescaler : ADC_InitTypeDef, IRDA_InitTypeDef, SMARTCARD_InitTypeDef, TIM_ClockConfigTypeDef, UART_InitTypeDef, USART_InitTypeDef
- clockSource : _adc_config, _gpt_init_config, _pwm_config, _rtwdog_config
- ClockSource : TIM_ClockConfigTypeDef
- ClockStrobing : SAI_InitTypeDef
- clockToResetDelay : _smartcard_interface_config
- ClockType : RCC_ClkInitTypeDef
- close_entry : rtems_driver_address_table
- CLPCR : CCM_Type
- CLR : AUDIO_PLL_Type, CCM_Type, ETHERNET_PLL_Type
- clr : lpc176x_fio
- Clr : lpc176x_interrupt_control
- CLR : OSC_RC_400M_Type, PHY_LDO_Type, VIDEO_MUX_Type, VIDEO_PLL_Type, VMBANDGAP_Type
- CLRFR : SAI_Block_TypeDef
- CLTCR : DSI_TypeDef
- CLUT_LOAD : LCDIFV2_Type
- CLUTWR : LTDC_Layer_TypeDef
- CM : DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type
- CM0AR : BDMA_Channel_TypeDef
- CM1AR : BDMA_Channel_TypeDef
- CM_AUTHEN_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_INT_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_IRQ_WAKEUP_MASK : GPC_CPU_MODE_CTRL_Type
- CM_IRQ_WAKEUP_STAT : GPC_CPU_MODE_CTRL_Type
- CM_MISC : GPC_CPU_MODE_CTRL_Type
- CM_MODE_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_MODE_STAT : GPC_CPU_MODE_CTRL_Type
- CM_NON_IRQ_WAKEUP_MASK : GPC_CPU_MODE_CTRL_Type
- CM_NON_IRQ_WAKEUP_STAT : GPC_CPU_MODE_CTRL_Type
- CM_RUN_MODE_MAPPING : GPC_CPU_MODE_CTRL_Type
- CM_SLEEP_ISO_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_SLEEP_LPCG_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_SLEEP_PLL_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_SLEEP_POWER_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_SLEEP_RESET_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_SLEEP_SSAR_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_SP_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_SP_MAPPING : GPC_CPU_MODE_CTRL_Type
- CM_SP_STAT : GPC_CPU_MODE_CTRL_Type
- CM_STBY_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_STOP_MODE_MAPPING : GPC_CPU_MODE_CTRL_Type
- CM_SUSPEND_MODE_MAPPING : GPC_CPU_MODE_CTRL_Type
- CM_WAIT_MODE_MAPPING : GPC_CPU_MODE_CTRL_Type
- CM_WAKEUP_ISO_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_WAKEUP_LPCG_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_WAKEUP_PLL_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_WAKEUP_POWER_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_WAKEUP_RESET_CTRL : GPC_CPU_MODE_CTRL_Type
- CM_WAKEUP_SSAR_CTRL : GPC_CPU_MODE_CTRL_Type
- CMAR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- CMCR : DSI_TypeDef
- CMD : SDMMC_TypeDef
- cmd : spictrl
- CMD_ARG : USDHC_Type
- cmd_pads : _serial_nor_config_option
- CMD_RSP0 : USDHC_Type
- CMD_RSP1 : USDHC_Type
- CMD_RSP2 : USDHC_Type
- CMD_RSP3 : USDHC_Type
- CMD_XFR_TYP : USDHC_Type
- cmdDone : _SmcStatus::_SmcStatusBits
- CMDH : ADC_Type
- CmdIndex : SDMMC_CmdInitTypeDef
- CMDL : ADC_Type
- cmdOrDataFlag : _ILI9488_ctl
- CMDR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- cmdTimeoutCycles : _semc_config_t
- cmdType : _flexspi_transfer
- CMEOR : CCM_Type
- CMP : LPTIM_TypeDef
- CMP1CxR : HRTIM_Timerx_TypeDef
- CMP1xR : HRTIM_Timerx_TypeDef
- CMP2xR : HRTIM_Timerx_TypeDef
- CMP3xR : HRTIM_Timerx_TypeDef
- CMP4xR : HRTIM_Timerx_TypeDef
- CMPH : EWM_Type
- CMPL : EWM_Type
- CMPLD1 : TMR_Type
- CMPLD2 : TMR_Type
- CN : DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type
- CNDTR : BDMA_Channel_TypeDef
- CNFIFO : CAAM_Type
- CNFIFO_2 : CAAM_Type
- CNT : GPT_Type, LPTIM_TypeDef, PWM_Type, RTWDOG_Type, TIM_TypeDef
- cntMode : _gpc_tran_step_config
- CNTR : GPC_Type, TMR_Type
- cntrs : ALT_CLK_PLL_CFG_s
- CNTxR : HRTIM_Timerx_TypeDef
- CO : DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type
- code : AcfgValFatalInitTaskConstructFailed_Context, AcfgValFatalTooLargeTlsSize_Context, BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context, BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context, BspSparcLeon3ValFatalClockInitialization_Context, DevClockXilTtcValFatalIrqInstall_Context, RtemsStatusReqText_Context, ScoreSmpValFatal_Context, ScoreSmpValFatalBootProcessorNotAssignedToScheduler_Context, ScoreSmpValFatalMandatoryProcessorNotPresent_Context, ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Context, ScoreSmpValFatalStartOfMandatoryProcessorFailed_Context, ScoreSmpValFatalStartOnNotOnlineProcessor_Context, ScoreThreadValFatalIdleThreadCreateFailed_Context, ScoreThreadValFatalIdleThreadStackTooSmall_Context, ScoreValFatal_Context
- codec_fb_addr : _isi_Video
- codec_fbd_base : _isi_Video
- codec_hsize : _isi_Video
- codec_vsize : _isi_Video
- CODEINPUT : PUF_Type
- CODEOUTPUT : PUF_Type
- CodeSegSel : RTEMS_PACKED
- COFIFO : CAAM_Type
- ColAddrCycles : XNandPsu_Geometry
- columnAddrBitNum : _semc_dbi_config, _semc_nand_config, _semc_nor_config, _semc_sdram_config
- columnAddressWidth : _flexspi_mem_config, _FlexSPIConfig
- ColumnBitsNumber : FMC_SDRAM_InitTypeDef
- columnspace : _flexspi_device_config
- command : _flexio_mculcd_transfer, _usdhc_handle, _usdhc_scatter_gather_transfer, _usdhc_transfer, rtems_telnetd_config_table
- Command1 : OnfiCmdFormat
- Command2 : OnfiCmdFormat
- commandBuffer : _lpi2c_master_edma_handle, _lpi2c_master_handle
- commandIdSource : lpadc_conv_result_t
- commandInterval : _flexspi_mem_config, _FlexSPIConfig
- CommandMode : FMC_SDRAM_CommandTypeDef
- CommandSet : NOR_HandleTypeDef
- CommandTarget : FMC_SDRAM_CommandTypeDef
- commit() : rtems::thread::attributes
- Commutation_Delay : TIM_HallSensor_InitTypeDef
- COMP0 : DWT_Type
- COMP1 : DWT_Type, TMR_Type
- COMP2 : DWT_Type, TMR_Type
- COMP3 : DWT_Type
- compact_segs : rtems_flashdisk, rtems_flashdisk_config
- CompandingMode : SAI_InitTypeDef
- compareHighValue : _ewm_config
- compareLowValue : _ewm_config
- complementFeedForwardStep : _dcdc_loop_control_config
- completionCallback : _flexio_i2c_master_handle, _flexio_mculcd_edma_handle, _flexio_mculcd_handle, _flexio_mculcd_smartdma_handle, _flexspi_dma_handle, _flexspi_edma_handle, _flexspi_handle, _lpi2c_master_edma_handle, _lpi2c_master_handle
- completionStatus : _lpi2c_slave_transfer
- compress : rtems_jffs2_compressor_control
- compression : rtems_rtl_obj_cpmp, rtems_rtl_rap
- compressor_control : rtems_jffs2_mount_data
- con : lpc176x_pll
- concurrent_activity : RtemsMessageReqReceive_Context
- conf0 : spwtdp
- conf3 : spwtdp
- config : _usdhc_host
- CONFIG : CCM_Type
- config : gptimer, memscrub
- Config : NAND_HandleTypeDef
- config : rtems_rtl_archives, RTEMS_tasks_User_task_config
- Config : XQspiPsu
- config_length : rtems_rtl_archives
- config_mtime : rtems_rtl_archives
- config_name : rtems_rtl_archives
- configCmdArgs : _flexspi_mem_config, _FlexSPIConfig
- configCmdEnable : _flexspi_mem_config, _FlexSPIConfig
- configCmdSeqs : _flexspi_mem_config, _FlexSPIConfig
- CONFIGFLAG : USB_Type
- configFlags : _lpspi_transfer
- configModeType : _flexspi_mem_config, _FlexSPIConfig
- CONFR0 : JPEG_TypeDef
- CONFR1 : JPEG_TypeDef
- CONFR2 : JPEG_TypeDef
- CONFR3 : JPEG_TypeDef
- CONFR4 : JPEG_TypeDef
- CONFR5 : JPEG_TypeDef
- CONFR6 : JPEG_TypeDef
- CONFR7 : JPEG_TypeDef
- ConnectionMode : XQspiPsu_Config
- const_base : rtems_rtl_obj
- const_size : rtems_rtl_obj
- consumed : RtemsRatemonReqGetStatus_Context
- contention_counts : rtems_profiling_smp_lock
- ContentProtectAppli : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- context : _enet_tx_frame_struct, _Scheduler_Control, console_device
- CONTEXT : DCP_Type
- context : enet_frame_info
- Context : Hash_Context, MMC_HandleTypeDef
- context : RtemsBarrierValPerf_Context, RtemsEventValPerf_Context, RtemsMessageValPerf_Context, RtemsPartValPerf_Context, RtemsSemValPerf_Context, RtemsTaskValPerf_Context, ScoreCpuValPerf_Context
- Context : SD_HandleTypeDef
- context : tlb_context_reg, tlb_demap_addr, tlb_tag_read_reg, tte_tag
- ContextQueue : ADC_InjectionConfigTypeDef
- ContinuousClock : FMC_NORSRAM_InitTypeDef
- ContinuousConvMode : ADC_InitTypeDef
- Contributors : Priority_Aggregation
- control : _enet_rx_bd_struct, _enet_tx_bd_struct
- CONTROL : CCM_OBS_Type, CCM_Type, CDOG_Type
- Control : ISI_FrameBufferDescriptors
- CONTROL : USBHSDCD_Type
- CONTROL_CLR : CCM_OBS_Type, CCM_Type
- control_entry : rtems_driver_address_table
- CONTROL_SET : CCM_OBS_Type, CCM_Type
- CONTROL_TOG : CCM_OBS_Type, CCM_Type
- controllerMiscOption : _flexspi_mem_config, _FlexSPIConfig
- controlMode : _dcdc_config
- controlParameterMagnitude : _dcdc_loop_control_config
- controlPin : _smartcard_interface_config
- controlPort : _smartcard_interface_config
- convention : _smartcard_card_params
- ConversionDataManagement : ADC_InitTypeDef
- convert_status : TQContext
- converter : rtems_dosfs_mount_options
- convPauseDelay : lpadc_config_t
- convValue : lpadc_conv_result_t
- copy_buffer : rtems_flashdisk
- CopyFlag : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- copyright : bootloader_api_entry_t
- Core_control : Semaphore_Control
- count : _flexspi_dma_handle, _flexspi_edma_handle, _pdm_edma_handle, _pdm_sdma_handle, _sai_sdma_handle, _spdif_edma_handle, CORE_semaphore_Control, Memory_Information, Rate_monotonic_Statistics, rtems_capture_buffer, rtems_debugger_block, rtems_fdisk_segment_desc, rtems_rate_monotonic_period_statistics, rtems_rfs_block_size_s, rtems_rtl_obj_summary, RtemsMessageReqBroadcast_Context, RtemsMessageReqFlushPending_Context, RtemsSemReqDelete_Context, RtemsSemReqSetPriority_Context, sai_edma_handle, Thread_Wait_information
- count_after : ScoreSemReqSeizeTry_Context, ScoreSemReqSurrender_Context
- count_before : ScoreSemReqSeizeTry_Context, ScoreSemReqSurrender_Context
- count_param : RtemsMessageReqBroadcast_Context, RtemsMessageReqFlushPending_Context
- countChargingTimePeriod : _dcdc_low_power_config
- countChargingTimeThreshold : _dcdc_low_power_config
- counter : RtemsSemReqDelete_Context, RtemsSemValUni_Context, RtemsTaskReqStart_Context, RtemsTimerValTimer_Context, ScoreMtxReqSurrender_Context, ScoreSchedSmpValSmp_Context, ScoreThreadValIdleBodyNoReturn_Context, ScoreThreadValSmp_Context, ScoreThreadValSmpOneCpu_Context, ScoreValFatal_Context, TQContext
- Counter : WWDG_InitTypeDef
- counter_by_entry : RtemsIntrReqEntryInstall_Context
- counter_register : leon3_timecounter
- counter_snapshots : RtemsTimerValTimer_Context
- CounterMode : TIM_Base_InitTypeDef
- COUNTR : TAMP_TypeDef
- cp : tte_data
- CPACR : SCB_Type
- CPAR : BDMA_Channel_TypeDef
- CPC_AUTHEN_CTRL : PGMC_CPC_Type
- CPC_CACHE_CM_CTRL : PGMC_CPC_Type
- CPC_CACHE_MODE : PGMC_CPC_Type
- CPC_CACHE_SP_CTRL_0 : PGMC_CPC_Type
- CPC_CACHE_SP_CTRL_1 : PGMC_CPC_Type
- CPC_CORE_MODE : PGMC_CPC_Type
- CPC_CORE_POWER_CTRL : PGMC_CPC_Type
- CPC_FLAG : PGMC_CPC_Type
- CPC_LMEM_CM_CTRL : PGMC_CPC_Type
- CPC_LMEM_MODE : PGMC_CPC_Type
- CPC_LMEM_SP_CTRL_0 : PGMC_CPC_Type
- CPC_LMEM_SP_CTRL_1 : PGMC_CPC_Type
- cpha : _lpspi_master_config, _lpspi_slave_config
- CPICNT : DWT_Type
- CPINE : SEMA4_Type
- CPKASZR : CAAM_Type
- CPKBSZR : CAAM_Type
- CPKESZR : CAAM_Type
- CPKNSZR : CAAM_Type
- CPNTF : SEMA4_Type
- cpol : _lpspi_master_config, _lpspi_slave_config
- CPOL : I2S_InitTypeDef
- CPSM : SDMMC_CmdInitTypeDef
- CPSR : LTDC_TypeDef
- CPT1xCR : HRTIM_Timerx_TypeDef
- CPT1xR : HRTIM_Timerx_TypeDef
- CPT2xCR : HRTIM_Timerx_TypeDef
- CPT2xR : HRTIM_Timerx_TypeDef
- cpu : RtemsSchedulerReqAddProcessor_Context
- CPU : Scheduler_strong_APA_Context
- cpu : Scheduler_strong_APA_CPU
- CPU2CR : PWR_TypeDef
- cpu_after_yield : ScoreSchedReqYield_Context
- CPU_budget : _Thread_Control
- cpu_budget_operations : Thread_Configuration, Thread_Start_information
- CPU_CTRL : PGC_Type
- cpu_has_scheduler : RtemsSchedulerReqIdentByProcessor_Context, RtemsSchedulerReqIdentByProcessorSet_Context
- cpu_index : RtemsIntrReqRaiseOn_Context, RtemsSchedulerReqAddProcessor_Context, RtemsSchedulerReqIdentByProcessor_Context, RtemsSchedulerReqRemoveProcessor_Context
- CPU_PDNSCR : PGC_Type
- CPU_PUPSCR : PGC_Type
- CPU_SR : PGC_Type
- cpu_time_used : _Thread_Control
- cpu_time_used_at_last_reset : _Thread_Control
- cpu_to_preempt : Scheduler_strong_APA_Node
- cpu_todo : rtems_record_fetch_control
- cpu_usage_before : RtemsRatemonReqTimeout_Context
- cpu_usage_period_initiated : Rate_monotonic_Control
- cpu_usage_timestamp : Per_CPU_Control
- CPUCR : PWR_TypeDef
- cpuDomain : _ssarc_group_config
- CPUID : SCB_Type
- cpuset : RtemsIntrReqGetAffinity_Context, RtemsIntrReqSetAffinity_Context, RtemsSchedulerReqGetProcessorSet_Context, RtemsSchedulerReqIdentByProcessorSet_Context, RtemsTaskReqGetAffinity_Context, RtemsTaskReqSetAffinity_Context
- cpuset_obj : RtemsIntrReqGetAffinity_Context, RtemsIntrReqSetAffinity_Context, RtemsTaskReqGetAffinity_Context, RtemsTaskReqSetAffinity_Context
- cpuset_value : RtemsSchedulerReqGetProcessorSet_Context, RtemsSchedulerReqIdentByProcessorSet_Context
- cpusetsize : RtemsIntrReqGetAffinity_Context, RtemsIntrReqSetAffinity_Context, RtemsSchedulerReqGetProcessorSet_Context, RtemsSchedulerReqIdentByProcessorSet_Context, RtemsTaskReqGetAffinity_Context, RtemsTaskReqSetAffinity_Context
- CR : ADC_TypeDef, CEC_TypeDef, CRC_TypeDef, CRS_TypeDef, CRYP_TypeDef, CSI_Type, DAC_Type, DAC_TypeDef, DBGMCU_TypeDef, DCMI_TypeDef, DLYB_TypeDef, DMA2D_TypeDef, DMA_Stream_TypeDef, DMA_Type, DSI_TypeDef, FMAC_TypeDef, GFXMMU_TypeDef, GPT_Type
- cr : grethgbit
- CR : HASH_TypeDef, HSEM_TypeDef, JPEG_TypeDef, lpc176x_timer_device, LPSPI_Type, LPTIM_TypeDef, LTDC_Layer_TypeDef, MCM_Type, MU_Type, OCTOSPI_TypeDef, OCTOSPIM_TypeDef, OTFAD_Type, PSSI_TypeDef, QUADSPI_TypeDef, RAMECC_MonitorTypeDef, RCC_TypeDef, RNG_TypeDef, RTC_TypeDef, SPDIFRX_TypeDef, SWPMI_TypeDef, WWDG_TypeDef
- CR0 : CMP_Type
- CR1 : CMP_Type, CSI_Type, FLASH_TypeDef, HRTIM_Common_TypeDef, I2C_TypeDef, PWR_TypeDef, SAI_Block_TypeDef, SPI_TypeDef, TAMP_TypeDef, TIM_TypeDef, USART_TypeDef
- CR18 : CSI_Type
- CR19 : CSI_Type
- CR2 : CSI_Type, DAC_Type, FLASH_TypeDef, HRTIM_Common_TypeDef, I2C_TypeDef, PWR_TypeDef, SAI_Block_TypeDef, SPI_TypeDef, TAMP_TypeDef, TIM_TypeDef, USART_TypeDef
- CR20 : CSI_Type
- CR3 : CSI_Type, PWR_TypeDef, USART_TypeDef
- Crc : __attribute__
- crc : rtems_fdisk_page_desc
- CRC_STAT : LCDIF_Type
- CRCCalculation : SPI_InitTypeDef
- CRCCR1 : FLASH_TypeDef
- CRCCR2 : FLASH_TypeDef
- CRCDATA : FLASH_TypeDef
- CRCDATA2 : FLASH_TypeDef
- CRCEADD1 : FLASH_TypeDef
- CRCEADD2 : FLASH_TypeDef
- CRCEndAddr : FLASH_CRCInitTypeDef
- CRCLength : CRC_InitTypeDef, SPI_InitTypeDef
- CRCPOLY : SPI_TypeDef
- CRCPolynomial : SPI_InitTypeDef
- CRCR : CAN_Type
- CRCSADD1 : FLASH_TypeDef
- CRCSADD2 : FLASH_TypeDef
- CRCSize : __SPI_HandleTypeDef
- CRCStartAddr : FLASH_CRCInitTypeDef
- credcnt : grspwrouter
- CREL : FDCAN_ClockCalibrationUnit_TypeDef, FDCAN_GlobalTypeDef
- CRNR_LS : CAAM_Type
- CRNR_LS_DC01 : CAAM_Type
- CRNR_LS_JR : CAAM_Type
- CRNR_LS_RTIC : CAAM_Type
- CRNR_MS : CAAM_Type
- CRNR_MS_DC01 : CAAM_Type
- CRNR_MS_JR : CAAM_Type
- CRNR_MS_RTIC : CAAM_Type
- Croff : ISI_Y2R
- CRRCR : RCC_TypeDef
- crystal : mcp7940m_rtc
- CS : CAN_Type, RTWDOG_Type
- cs : sc16is752_spi_context, spi_bus, spi_ioc_transfer
- CS1CDR : CCM_Type
- CS2CDR : CCM_Type
- cs_change : spi_bus, spi_ioc_transfer
- cs_da : ALT_QSPI_TIMING_CONFIG_s
- cs_dads : ALT_QSPI_TIMING_CONFIG_s
- cs_eot : ALT_QSPI_TIMING_CONFIG_s
- cs_idle : spi_gpio_params
- cs_pages : rtems_nvdisk
- cs_sot : ALT_QSPI_TIMING_CONFIG_s
- CSAR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- CSC1_COEF0 : PXP_Type
- CSC1_COEF1 : PXP_Type
- CSC1_COEF2 : PXP_Type
- CSC_COEF0 : LCDIFV2_Type
- CSC_COEF1 : LCDIFV2_Type
- CSC_COEF2 : LCDIFV2_Type
- CSCDR1 : CCM_Type
- CSCDR2 : CCM_Type
- CSCDR3 : CCM_Type
- CSCMR1 : CCM_Type
- CSCMR2 : CCM_Type
- CSCTRL : TMR_Type
- CSD : MMC_HandleTypeDef, SD_HandleTypeDef
- CSD_CRC : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- CSDStruct : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- csf : _ivt_
- CSGCM0R : CRYP_TypeDef
- CSGCM1R : CRYP_TypeDef
- CSGCM2R : CRYP_TypeDef
- CSGCM3R : CRYP_TypeDef
- CSGCM4R : CRYP_TypeDef
- CSGCM5R : CRYP_TypeDef
- CSGCM6R : CRYP_TypeDef
- CSGCM7R : CRYP_TypeDef
- CSGCMCCM0R : CRYP_TypeDef
- CSGCMCCM1R : CRYP_TypeDef
- CSGCMCCM2R : CRYP_TypeDef
- CSGCMCCM3R : CRYP_TypeDef
- CSGCMCCM4R : CRYP_TypeDef
- CSGCMCCM5R : CRYP_TypeDef
- CSGCMCCM6R : CRYP_TypeDef
- CSGCMCCM7R : CRYP_TypeDef
- CSHoldTime : _flexspi_device_config
- csHoldTime : _flexspi_mem_config, _FlexSPIConfig
- CSICalibrationValue : RCC_OscInitTypeDef
- CSICFGR : RCC_TypeDef
- CSInterval : _flexspi_device_config
- CSIntervalUnit : _flexspi_device_config
- CSIState : RCC_OscInitTypeDef
- CSL : CSU_Type
- CSnPinIndex : _flexio_spi_type
- csPadSettingOverride : _flexspi_mem_config, _FlexSPIConfig
- CSPSR : TPI_Type
- CSR : _edma_tcd, ADC_Common_TypeDef, CCM_Type, CORDIC_TypeDef, DMA_Type, DMAMUX_ChannelStatus_TypeDef, HASH_TypeDef, OPAMP_TypeDef, RCC_TypeDef, SPDIFRX_TypeDef, VREFBUF_TypeDef
- CSR1 : PWR_TypeDef
- CSSELR : SCB_Type
- CSSetupTime : _flexspi_device_config
- csSetupTime : _flexspi_mem_config, _FlexSPIConfig
- CSTA : CAAM_Type
- CSTA_DC01 : CAAM_Type
- CSTA_JR : CAAM_Type
- CSTA_RTIC : CAAM_Type
- CSTAT : FDCAN_ClockCalibrationUnit_TypeDef
- csval_0 : l4stat
- csval_1 : l4stat
- csxPinMux : _semc_dbi_config, _semc_sdram_config
- ct : tlb_sfsr_reg
- CTBR : MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- CTCR : lpc176x_timer_device, MDMA_Channel_TypeDef, MDMA_LinkNodeTypeDef
- ctime : _rtems_rfs_file_shared, _rtems_rfs_inode
- CTPR_LS : CAAM_Type
- CTPR_LS_DC01 : CAAM_Type
- CTPR_LS_JR : CAAM_Type
- CTPR_LS_RTIC : CAAM_Type
- CTPR_MS : CAAM_Type
- CTPR_MS_DC01 : CAAM_Type
- CTPR_MS_JR : CAAM_Type
- CTPR_MS_RTIC : CAAM_Type
- CTR : ART_TypeDef, OTFAD_Type, SCB_Type
- CTR_NONCE0_W0 : BEE_Type
- CTR_NONCE0_W1 : BEE_Type
- CTR_NONCE0_W2 : BEE_Type
- CTR_NONCE0_W3 : BEE_Type
- CTR_NONCE1_W0 : BEE_Type
- CTR_NONCE1_W1 : BEE_Type
- CTR_NONCE1_W2 : BEE_Type
- CTR_NONCE1_W3 : BEE_Type
- CTRL : ADC_ETC_Type, ADC_Type
- ctrl : ahbtrace, apbuart
- CTRL : BEE_Type, DCP_Type
- ctrl : dsu4
- CTRL : DWT_Type, EMVSIM_Type, ENC_Type, EWM_Type, FLEXIO_Type
- ctrl : gr740_thsens, griommu, grpci2, grspw2
- CTRL : LCDIF_Type, LCDIFV2_Type, LPUART_Type, OCOTP_Type, PUF_Type, PWM_Type, PXP_Type
- ctrl : spwtdp
- CTRL : SRAM_Type, SSARC_LP_Type, SysTick_Type, TMR_Type, USBPHY_Type
- ctrl0 : _dcp_hash_ctx_internal
- CTRL0 : DCDC_Type, TMPSNS_Type, XBARA_Type
- CTRL0_CLR : TMPSNS_Type
- CTRL0_SET : TMPSNS_Type
- CTRL0_TOG : TMPSNS_Type
- CTRL1 : CAN_Type, DCDC_Type, LCDIF_Type, TMPSNS_Type, USBNC_Type, XBARA_Type
- CTRL1_CLR : LCDIF_Type, TMPSNS_Type
- CTRL1_SET : LCDIF_Type, TMPSNS_Type
- CTRL1_TOG : LCDIF_Type, TMPSNS_Type
- CTRL2 : CAN_Type, ENC_Type, LCDIF_Type, PWM_Type, USBNC_Type
- CTRL2_CLR : LCDIF_Type
- CTRL2_SET : LCDIF_Type
- CTRL2_TOG : LCDIF_Type
- CTRL3 : ENC_Type
- CTRL_1 : PDM_Type
- CTRL_2 : PDM_Type
- CTRL_CLR : DCP_Type, LCDIF_Type, LCDIFV2_Type, OCOTP_Type, PXP_Type, USBPHY_Type
- CTRL_DISPLAY : SRC_Type
- CTRL_M4CORE : SRC_Type
- CTRL_M4DEBUG : SRC_Type
- CTRL_M7CORE : SRC_Type
- CTRL_M7DEBUG : SRC_Type
- CTRL_MEGA : SRC_Type
- CTRL_SET : DCP_Type, LCDIF_Type, LCDIFV2_Type, OCOTP_Type, PXP_Type, USBPHY_Type
- ctrl_socket : rtems_ftpfs_entry
- CTRL_TOG : DCP_Type, LCDIF_Type, LCDIFV2_Type, OCOTP_Type, PXP_Type, USBPHY_Type
- CTRL_USBPHY1 : SRC_Type
- CTRL_USBPHY2 : SRC_Type
- CTRL_WAKEUP : SRC_Type
- CTRLDESCL1 : LCDIFV2_Type
- CTRLDESCL2 : LCDIFV2_Type
- CTRLDESCL3 : LCDIFV2_Type
- CTRLDESCL4 : LCDIFV2_Type
- CTRLDESCL5 : LCDIFV2_Type
- CTRLDESCL6 : LCDIFV2_Type
- CUR_BUF : LCDIF_Type
- Current : ISI_FrameBufferDescriptors
- current : rtems_debugger_threads, rtems_stack_checker_info
- current_directory : rtems_user_env_t
- current_mode : RtemsTaskReqMode_Context
- current_priority : Scheduler_priority_Ready_queue
- current_state : _Thread_Control, CORE_RWLock_Control, Thread_Proxy_control
- currentD : _smartcard_card_params
- CurrentLcdIndex : ISI_Descriptors
- currentloc : rtems_filesystem_eval_path_context_t
- currentReferenceInternalTrimValue : dac12_config_t
- cutOffFreq : _pdm_channel_config, _pdm_hwvad_config
- CV : ADC_Type
- cv : tte_data
- CVAL : PIT_Type
- CVAL0 : PWM_Type
- CVAL0CYC : PWM_Type
- CVAL1 : PWM_Type
- CVAL1CYC : PWM_Type
- CVAL2 : PWM_Type
- CVAL2CYC : PWM_Type
- CVAL3 : PWM_Type
- CVAL3CYC : PWM_Type
- CVAL4 : PWM_Type
- CVAL4CYC : PWM_Type
- CVAL5 : PWM_Type
- CVAL5CYC : PWM_Type
- cval_0 : l4stat
- cval_1 : l4stat
- CWD : FDCAN_ClockCalibrationUnit_TypeDef
- CWI : _smartcard_card_params
- CWSIZER : DCMI_TypeDef
- CWSTRTR : DCMI_TypeDef
- CWT_VAL : EMVSIM_Type
- cwtExpired : _smartcard_timers_state
- CYCCNT : DWT_Type
