RTEMS 6.1-rc6
Test context for spec:/rtems/sem/req/delete test case. More...
rtems_id worker_id [2]
 This member contains the worker task identifiers.
uint32_t counter
 This member contains the worker activity counter.
uint32_t worker_counter [2]
 This member contains the worker activity counter of a specific worker.
rtems_status_code obtain_status
 This member specifies the expected rtems_semaphore_obtain() status.
uint32_t count
 This member specifies if the initial count of the semaphore.
rtems_attribute attribute_set
 This member specifies if the attribute set of the semaphore.
rtems_id semaphore_id
 This member contains the semaphore identifier.
bool valid_id
 If this member is true, then the name parameter shall be valid, otherwise it should be NULL.
bool blocked
 If this member is true, then tasks shall be blocked on the semaphore, otherwise no tasks shall be blocked on the semaphore.
rtems_id id
 This member specifies the name parameter for the rtems_semaphore_delete() call.
rtems_status_code delete_status
 This member specifies the expected rtems_semaphore_delete() status.
struct {
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSemReqDelete_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
