RTEMS 6.1-rc6
_flexio_mculcd_smartdma_handle Struct Reference
FlexIO MCULCD SMARTDMA transfer handle, users should not touch the content of the handle. More...
#include <fsl_flexio_mculcd_smartdma.h>
FLEXIO_MCULCD_Typebase
size_t dataCount
uint32_t dataAddrOrSameValue
size_t dataCountUsingEzh
volatile size_t remainingCount
volatile uint32_t state
uint8_t smartdmaApi
bool needColorConvert
uint8_t blockingXferBuffer [FLEXIO_MCULCD_SMARTDMA_TX_LEN_ALIGN *3/2]
flexio_mculcd_smartdma_transfer_callback_t completionCallback
void * userData
smartdma_flexio_mculcd_param_t smartdmaParam
uint32_t smartdmaStack [1]
Field Documentation
◆ base
FLEXIO_MCULCD_Type* _flexio_mculcd_smartdma_handle::base
Pointer to the FLEXIO_MCULCD_Type.
◆ blockingXferBuffer
uint8_t _flexio_mculcd_smartdma_handle::blockingXferBuffer[FLEXIO_MCULCD_SMARTDMA_TX_LEN_ALIGN *3/ 2]
Used for blocking method color space convet.
◆ completionCallback
flexio_mculcd_smartdma_transfer_callback_t _flexio_mculcd_smartdma_handle::completionCallback
Callback for MCULCD SMARTDMA transfer
◆ dataAddrOrSameValue
uint32_t _flexio_mculcd_smartdma_handle::dataAddrOrSameValue
When sending the same value for many times, this is the value to send. When writing or reading array, this is the address of the data array.
◆ dataCount
size_t _flexio_mculcd_smartdma_handle::dataCount
Total count to be transferred.
◆ dataCountUsingEzh
size_t _flexio_mculcd_smartdma_handle::dataCountUsingEzh
Data transfered using SMARTDMA.
◆ needColorConvert
bool _flexio_mculcd_smartdma_handle::needColorConvert
Need color convert or not.
◆ remainingCount
volatile size_t _flexio_mculcd_smartdma_handle::remainingCount
Remaining count to transfer.
◆ smartdmaApi
uint8_t _flexio_mculcd_smartdma_handle::smartdmaApi
The SMARTDMA API used during transfer.
◆ smartdmaParam
smartdma_flexio_mculcd_param_t _flexio_mculcd_smartdma_handle::smartdmaParam
SMARTDMA function parameters.
◆ smartdmaStack
uint32_t _flexio_mculcd_smartdma_handle::smartdmaStack[1]
SMARTDMA function stack.
◆ state
volatile uint32_t _flexio_mculcd_smartdma_handle::state
FlexIO MCULCD driver internal state.
◆ userData
void* _flexio_mculcd_smartdma_handle::userData
User Data for MCULCD SMARTDMA callback
