RTEMS 6.1-rc6
Test context for spec:/rtems/ratemon/req/timeout test case. More...
Data Fields | |
rtems_id | period_id |
This member contains the period identifier. | |
Rate_monotonic_Control * | period |
This member references the period control block. | |
rtems_id | other_period_id |
This member contains another period identifier. | |
rtems_id | worker_id |
This member contains the worker task identifier. | |
CallWithinISRRequest | request |
This member contains the call within ISR request. | |
bool | wait_for_period |
If this member is true, then the worker shall wait for a period. | |
bool | period_is_other |
If this member is true, then the worker shall wait for another period. | |
bool | intend_to_block |
If this member is true, then the worker shall intend to block for a period. | |
uint32_t | postponed_jobs |
This member contains the postponed jobs count before the timeout. | |
Timestamp_Control | uptime_before |
This member contains the uptime of the period before the timeout. | |
Timestamp_Control | cpu_usage_before |
This member contains the CPU usage of the period before the timeout. | |
uint32_t | release_job_counter |
This member contains the release job counter. | |
uint32_t | unblock_counter |
This member contains the unblock counter. | |
struct { | |
size_t pci [3] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [3] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsRatemonReqTimeout_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
