RTEMS 6.1-rc4
- r -
- RTC_Table : rtc-config.c
- rtems_bdbuf_configuration : bdbuf.h
- rtems_fb_default_mode : fb_vesa_rm.c, fb_default_mode.h
- rtems_filesystem_default_pathconf : libio.h, mount.c
- rtems_filesystem_global_location_null : libio_.h, __usrenv.c
- rtems_filesystem_handlers_default : libio.h, default_handlers.c
- rtems_filesystem_operations_default : libio.h, default_ops.c
- rtems_filesystem_table : libio.h
- rtems_flashdisk_configuration : flashdisk.h
- rtems_flashdisk_configuration_size : flashdisk.h
- rtems_interrupt_mask : modes.h, modes.c
- RTEMS_Malloc_Heap : malloc.h, mallocheap.c
- rtems_minimum_stack_size : stack.h
- rtems_nvdisk_configuration : nvdisk.h
- rtems_nvdisk_configuration_size : nvdisk.h
- rtems_nvdisk_sram_handlers : nvdisk-sram.h, nvdisk-sram.c
- rtems_ramdisk_configuration : ramdisk.h
- rtems_ramdisk_configuration_size : ramdisk.h
- rtems_rfs_ops : rtems-rfs-rtems.c
- rtems_rfs_rtems_dir_handlers : rtems-rfs-rtems-dir.c, rtems-rfs-rtems.h
- rtems_rfs_rtems_link_handlers : rtems-rfs-rtems.c, rtems-rfs-rtems.h
- rtems_telnetd_config : telnetd.h
- rtems_termios_baud_table : termiostypes.h, termios_baudtable.c
- rtems_test_name : test-info.h, init.c, ts-fatal-clock-xil-ttc-irq-install.c, ts-fatal-extension.c, ts-fatal-sparc-leon3-cache-snooping-disabled-boot.c, ts-fatal-sparc-leon3-cache-snooping-disabled-secondary.c, ts-fatal-sparc-leon3-clock-initialization.c, ts-validation-bsp-0.c, ts-fatal-boot-processor-not-assigned-to-scheduler.c, ts-fatal-idle-thread-create-failed.c, ts-fatal-idle-thread-stack-too-small.c, ts-fatal-init-task-construct-failed.c, ts-fatal-mandatory-processor-not-present.c, ts-fatal-scheduler-requires-exactly-one-processor.c, ts-fatal-smp.c, ts-fatal-start-of-mandatory-processor-failed.c, ts-fatal-start-on-not-online-processor.c, ts-fatal-too-large-tls-size.c, ts-performance-no-clock-0.c, ts-terminate.c, ts-userext.c, ts-validation-0.c, ts-validation-1.c, ts-validation-acfg-0.c, ts-validation-acfg-1.c, ts-validation-cache.c, ts-validation-intr.c, ts-validation-io-kernel.c, ts-validation-no-clock-0.c, ts-validation-non-smp.c, ts-validation-one-cpu-0.c, ts-validation-one-cpu-1.c, ts-validation-smp-one-cpu-0.c, ts-validation-smp-only-0.c, ts-validation-smp-only-2.c, ts-validation-timecounter-0.c, ts-validation-timecounter-1.c, ts-validation-timecounter-smp-0.c, ts-validation-tls-0.c, ts-validation-tls-1.c
- rtems_test_printer : test-printer.h, testprinter.c
