RTEMS 6.1-rc4
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Modules | |
spec:/dev/clock/xil-ttc/val/fatal-irq-install | |
Tests a fatal error. | |
Files | |
file | ts-fatal-clock-xil-ttc-irq-install.c |
#define | FATAL_SYSINIT_RUN DevClockXilTtcValFatalIrqInstall_Run |
#define | CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER |
const char | rtems_test_name [] = "TestsuitesBspsFatalClockXilTtcIrqInstall" |
Each test must define a test name string. | |
