RTEMS 6.1-rc4
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Test Support
Test support functions. More...
file  test-info.h
 This header file provides interfaces of the RTEMS Test Support.
file  test-printer.h
file  testrun.c
 This source file provides the implementation of rtems_test_run().
struct  rtems_test_parallel_context
 Internal context for parallel job execution. More...
struct  rtems_test_parallel_job
 Basic parallel job description. More...
#define RTEMS_TEST_INITIAL_EXTENSION    { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension, NULL }
 Initial extension for tests.
#define TEST_STATE   RTEMS_TEST_STATE_PASS
#define RTEMS_TEST_PARALLEL_PROCESSOR_MAX   32
typedef struct rtems_test_parallel_job rtems_test_parallel_job
typedef void(* rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id)
 Worker task setup handler.
enum  RTEMS_TEST_STATE {
  RTEMS_TEST_STATE_PASS , RTEMS_TEST_STATE_FAIL , RTEMS_TEST_STATE_USER_INPUT , RTEMS_TEST_STATE_INDETERMINATE ,
  RTEMS_TEST_STATE_BENCHMARK
 Test states.
void rtems_test_fatal_extension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code)
 Fatal extension for tests.
int rtems_test_begin (const char *name, const RTEMS_TEST_STATE state)
 Prints a begin of test message using printf().
int rtems_test_end (const char *name)
 Prints an end of test message using printf().
RTEMS_NO_RETURN void rtems_test_exit (int status)
 Exit the test without calling exit() since it closes stdin, etc and pulls in stdio code.
void rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count)
 Runs a bunch of jobs in parallel on all processors of the system.
void rtems_test_busy_cpu_usage (time_t seconds, long nanoseconds)
 Performs a busy loop for the specified seconds and nanoseconds based on the CPU usage of the executing thread.
RTEMS_NO_RETURN void rtems_test_run (rtems_task_argument arg, const RTEMS_TEST_STATE state)
 Runs the test cases of the RTEMS Test Framework using a default configuration in the context of a task.
void rtems_test_gcov_dump_info (void)
 Dumps the gcov information as a base64 encoded gcfn and gcda data stream using rtems_put_char().
int rtems_test_printf (const char *format,...) RTEMS_PRINTFLIKE(1
 Prints via the RTEMS test printer.
const char rtems_test_name []
 Each test must define a test name string.
rtems_printer rtems_test_printer
 Provides an RTEMS printer for tests.
Typedef Documentation
◆ rtems_test_parallel_worker_setup
Called during rtems_test_parallel() to optionally setup a worker task before it is started.
Parameters
[in]ctxThe parallel context.
[in]worker_indexThe worker index.
[in]worker_idThe worker task identifier.
◆ rtems_test_begin()
int rtems_test_begin ( const char *  name,
Returns
As specified by printf().
◆ rtems_test_busy_cpu_usage()
void rtems_test_busy_cpu_usage ( time_t  seconds,
long  nanoseconds
This function continuously reads the CPU usage of the executing thread. This operation may lead to a scheduler instance lock contention in SMP configurations.
Parameters
[in]secondsThe busy seconds.
[in]nanosecondsThe busy nanoseconds.
◆ rtems_test_end()
int rtems_test_end ( const char *  name)
Returns
◆ rtems_test_parallel()
void rtems_test_parallel ( rtems_test_parallel_context ctx,
const rtems_test_parallel_job jobs,
size_t  job_count
The worker tasks inherit the priority of the executing task.
There are SMP barriers before and after the job body.
Parameters
[in]worker_setupOptional handler to setup a worker task before it is started.
[in]jobsThe table of jobs.
[in]job_countThe count of jobs in the job table.
◆ rtems_test_printf()
int rtems_test_printf ( const char *  format,
Returns
Returns the count of output characters as specified by printf().
◆ rtems_test_run()
RTEMS_NO_RETURN void rtems_test_run ( rtems_task_argument  arg,
The application must provide rtems_test_name.
Parameters
argis the task argument.
stateis the test state.
