RTEMS 6.1-rc4
Modules | Files | Macros | Variables
spec:/testsuites/validation-intr
This validation test suite provides enough resources to run tests for the interrupt controller related directives of the Interrupt Manager. More...
 spec:/bsp/req/interrupt-handler-dispatch-unchecked
 spec:/rtems/intr/req/clear
 spec:/rtems/intr/req/entry-install
 spec:/rtems/intr/req/entry-remove
 spec:/rtems/intr/req/get-affinity
 spec:/rtems/intr/req/get-attributes
 spec:/rtems/intr/req/get-priority
 spec:/rtems/intr/req/handler-iterate
 spec:/rtems/intr/req/is-pending
 spec:/rtems/intr/req/raise
 spec:/rtems/intr/req/raise-on
 spec:/rtems/intr/req/set-affinity
 spec:/rtems/intr/req/set-priority
 spec:/rtems/intr/req/vector-disable
 spec:/rtems/intr/req/vector-enable
 spec:/rtems/intr/req/vector-is-enabled
 spec:/score/isr/val/isr
 Tests general interrupt support behaviour.
file  ts-validation-intr.c
#define CONFIGURE_MAXIMUM_PROCESSORS   5
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
const char rtems_test_name [] = "TestsuitesValidationIntr"
 Each test must define a test name string.
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
