RTEMS 6.1-rc4
Modules | Files | Macros | Functions | Variables
spec:/testsuites/validation-acfg-0
This validation test suite is used to validate the default value of application configuration options taking the optional BSP provided settings into account. More...
 spec:/acfg/val/appl-does-not-need-clock-driver
 Tests the effect of the CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER application configuration option.
 spec:/acfg/val/default
 Tests the default values of application configuration options.
file  ts-validation-acfg-0.c
#define CONFIGURE_IDLE_TASK_STORAGE_SIZE   RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_IDLE_TASK_BODY   IdleBody
#define CONFIGURE_INIT
void * IdleBody (uintptr_t ignored)
const char rtems_test_name [] = "TestsuitesValidationAcfg0"
 Each test must define a test name string.
