RTEMS 6.1-rc4
gdt.h
2
11/*
12 * Copyright (C) 2024 Matheus Pecoraro
13 *
16 * are met:
22 *
34 */
35
36#ifndef GDT_H
37#define GDT_H
38
39#define GDT_CODE_SEG_OFFSET 0x8
40#define GDT_DATA_SEG_OFFSET 0x10
41
42#ifndef ASM
44
45#include <stdint.h>
46
47typedef struct {
48 uint16_t limit_low; /* Lower 16 bits of the limit */
49 uint16_t base_low; /* Lower 16 bits of the base */
50 uint8_t base_middle; /* Next 8 bits of the base */
51 uint8_t access; /* Access flags */
52 uint8_t gran_limit_middle; /* Granularity flags and upper 4 bits of the limit */
53 uint8_t base_high; /* Last 8 bits of the base */
54} RTEMS_PACKED gdt_entry;
55
56typedef struct {
57 uint16_t size;
58 uint64_t addr;
59} RTEMS_PACKED gdt_desc;
60
61extern const gdt_desc amd64_gdt_descriptor;
62#endif // ASM
63
64#endif // GDT_H
This header file provides basic definitions used by the API and the implementation.
Used for passing and retrieving registers content to/from real mode interrupt call.
Definition: realmode_int.h:43
