RTEMS 6.1-rc4
This header file provides basic definitions used by the API and the implementation. More...
#include <stdbool.h>
#include <stddef.h>
#include <stdint.h>
#define | RTEMS_ALIAS(_target) |
Instructs the compiler to generate an alias to the target function. | |
#define | RTEMS_ALIGN_DOWN(_value, _alignment) ( ( _value ) & ~( ( _alignment ) - 1 ) ) |
Aligns down the value to the alignment. | |
#define | RTEMS_ALIGN_UP(_value, _alignment) ( ( ( _value ) + ( _alignment ) - 1 ) & ~( ( _alignment ) - 1 ) ) |
Aligns up the value to the alignment. | |
#define | RTEMS_ALIGNED(_alignment) |
Instructs the compiler in a declaration or definition to enforce the alignment. | |
#define | RTEMS_ALIGNOF(_type_name) sizeof( _type_name ) |
Gets the alignment requirement of the type. | |
#define | RTEMS_ALLOC_ALIGN(_index) |
Tells the compiler in a declaration that the memory allocation alignment parameter of this function is similar to aligned_alloc(). | |
#define | RTEMS_ALLOC_SIZE(_index) |
Tells the compiler in a declaration that the memory allocation size parameter of this function is similar to malloc(). | |
#define | RTEMS_ALLOC_SIZE_2(_count_index, _size_index) |
Tells the compiler in a declaration that the memory allocation item count and item size parameter of this function is similar to calloc(). | |
#define | RTEMS_ARRAY_SIZE(_array) ( sizeof( _array ) / sizeof( ( _array )[ 0 ] ) ) |
Gets the element count of the array. | |
#define | RTEMS_COMPILER_MEMORY_BARRIER() do { } while ( 0 ) |
This macro forbids the compiler to reorder read and write commands around it. | |
#define | RTEMS_CONCAT(_x, _y) _x##_y |
Concatenates _x and _y without expanding. | |
#define | RTEMS_CONST |
Tells the compiler in a function declaration that this function has no effect except the return value and that the return value depends only on the value of parameters. | |
#define | RTEMS_CONTAINER_OF(_m, _type, _member_name) ( (_type *) ( (uintptr_t) ( _m ) - offsetof( _type, _member_name ) ) ) |
Gets the container of a member. | |
#define | RTEMS_DECLARE_GLOBAL_SYMBOL(_name) extern char _name[] |
Declares a global symbol with the name. | |
#define | RTEMS_DEPRECATED |
Instructs the compiler in a declaration to issue a warning whenever a variable, function, or type using this declaration will be used. | |
#define | RTEMS_COMPILER_DEPRECATED_ATTRIBUTE RTEMS_DEPRECATED |
Provided for backward compatibility. | |
#define | RTEMS_EXPAND(_token) _token |
Helper macro to perform a macro expansion on the token. | |
#define | RTEMS_FUNCTION_NAME __func__ |
Expands to the name of the function containing the use of this define. | |
#define | RTEMS_NO_RETURN |
Tells the compiler in a function declaration that this function does not return. | |
#define | RTEMS_COMPILER_NO_RETURN_ATTRIBUTE RTEMS_NO_RETURN |
#define | RTEMS_SECTION(_section) |
Instructs the compiler to place the variable or function in the section. | |
#define | RTEMS_STRING(...) #__VA_ARGS__ |
Stringifies the arguments without expanding them. | |
#define | RTEMS_TYPEOF_REFX(_level, _target) |
Gets the pointer reference type. | |
#define | RTEMS_XCONCAT(_x, _y) RTEMS_CONCAT( _x, _y ) |
Concatenates expansion of _x and expansion of _y. | |
#define | RTEMS_DEQUALIFY_DEPTHX(_ptr_level, _type, _var) ( (_type) (uintptr_t) (const volatile void *)( _var ) ) |
Performs a type cast which removes qualifiers without warnings to the type for the variable. | |
#define | RTEMS_DECONST(_type, _var) RTEMS_DEQUALIFY_DEPTHX( *, _type, _var ) |
Performs a type cast which removes const qualifiers without warnings to the type for the pointer variable. | |
#define | RTEMS_DEQUALIFY(_type, _var) RTEMS_DEQUALIFY_DEPTHX( *, _type, _var ) |
Performs a type cast which removes all qualifiers without warnings to the type for the pointer variable. | |
#define | RTEMS_DEVOLATILE(_type, _var) RTEMS_DEQUALIFY_DEPTHX( *, _type, _var ) |
Performs a type cast which removes volatile qualifiers without warnings to the type for the pointer variable. | |
#define | FALSE 0 |
If FALSE is undefined, then FALSE is defined to 0. | |
#define | RTEMS_HAVE_MEMBER_SAME_TYPE(_t_lhs, _m_lhs, _t_rhs, _m_rhs) true |
Checks if members of two types have compatible types. | |
#define | RTEMS_INLINE_ROUTINE static inline |
Gives a hint to the compiler in a function declaration to inline this function. | |
#define | RTEMS_MALLOCLIKE |
Tells the compiler in a declaration that this function is a memory allocation function similar to malloc(). | |
#define | RTEMS_NO_INLINE |
Instructs the compiler in a function declaration to not inline this function. | |
#define | RTEMS_NOINIT RTEMS_SECTION( ".noinit" ) |
Instructs the compiler to place the variable in a section which is not initialized. | |
#define | RTEMS_OBFUSCATE_VARIABLE(_var) (void) ( _var ) |
Obfuscates the variable so that the compiler cannot perform optimizations based on the variable value. | |
#define | RTEMS_PACKED |
Instructs the compiler in a type definition to place members of a structure or union so that the memory required is minimized. | |
#define | RTEMS_COMPILER_PACKED_ATTRIBUTE RTEMS_PACKED |
#define | RTEMS_PREDICT_FALSE(_exp) ( _exp ) |
Evaluates the integral expression and tells the compiler that the predicted value is false (0). | |
#define | RTEMS_PREDICT_TRUE(_exp) ( _exp ) |
Evaluates the integral expression and tells the compiler that the predicted value is true (1). | |
#define | RTEMS_PRINTFLIKE(_format_pos, _ap_pos) |
Tells the compiler in a declaration that this function expects printf()-like arguments. | |
#define | RTEMS_PURE |
Tells the compiler in a function declaration that this function has no effect except the return value and that the return value depends only on the value of parameters and/or global variables. | |
#define | RTEMS_COMPILER_PURE_ATTRIBUTE RTEMS_PURE |
#define | RTEMS_RETURN_ADDRESS() NULL |
Gets the return address of the current function. | |
#define | RTEMS_STATIC_ASSERT(_cond, _msg) |
It is defined if a static analysis run is performed. | |
#define | RTEMS_SYMBOL_NAME(_name) RTEMS_EXPAND( _name ) |
Maps the name to the associated symbol name. | |
#define | TRUE 1 |
If TRUE is undefined, then TRUE is defined to 1. | |
#define | RTEMS_UNREACHABLE() do { } while ( 0 ) |
Tells the compiler that this program point is unreachable. | |
#define | RTEMS_UNUSED |
Tells the compiler that the variable or function is deliberately unused. | |
#define | RTEMS_COMPILER_UNUSED_ATTRIBUTE RTEMS_UNUSED |
#define | RTEMS_USED |
Tells the compiler that the variable or function is used. | |
#define | RTEMS_WARN_UNUSED_RESULT |
Tells the compiler in a declaration that the result of this function should be used. | |
#define | RTEMS_WEAK |
Tells the compiler in a function definition that this function should be weak. | |
#define | RTEMS_WEAK_ALIAS(_target) |
Instructs the compiler to generate a weak alias to the target function. | |
#define | RTEMS_XSTRING(...) RTEMS_STRING( __VA_ARGS__ ) |
Stringifies the expansion of the arguments. | |
#define | RTEMS_DEFINE_GLOBAL_SYMBOL(_name, _value) |
Defines a global symbol with the name and value. | |
#define | RTEMS_ZERO_LENGTH_ARRAY 0 |
This constant represents the element count of a zero-length array. | |
void * | RTEMS_DEQUALIFY_types_not_compatible (void) |
A not implemented function to trigger compile time errors with an error message. | |
