RTEMS 6.1-rc2
Data Structures | Functions
Pwm_driver
struct  _pwm_signal_param
 Structure for the user to define the PWM signal characteristics. More...
struct  _pwm_config
 PWM config structure. More...
struct  _pwm_fault_input_filter_param
 Structure for the user to configure the fault input filter. More...
struct  _pwm_fault_param
 Structure is used to hold the parameters to configure a PWM fault. More...
struct  _pwm_input_capture_param
 Structure is used to hold parameters to configure the capture capability of a signal pin. More...
void PWM_SetupInputCapture (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmChannel, const pwm_input_capture_param_t *inputCaptureParams)
 Sets up the PWM input capture.
void PWM_SetupFaultInputFilter (PWM_Type *base, const pwm_fault_input_filter_param_t *faultInputFilterParams)
 Sets up the PWM fault input filter.
void PWM_SetupFaults (PWM_Type *base, pwm_fault_input_t faultNum, const pwm_fault_param_t *faultParams)
 Sets up the PWM fault protection.
void PWM_FaultDefaultConfig (pwm_fault_param_t *config)
 Fill in the PWM fault config struct with the default settings.
void PWM_SetupForceSignal (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmChannel, pwm_force_signal_t mode)
 Selects the signal to output on a PWM pin when a FORCE_OUT signal is asserted.
uint8_t PWM_GetPwmChannelState (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmChannel)
 Get the dutycycle value.
status_t PWM_SetOutputToIdle (PWM_Type *base, pwm_channels_t pwmChannel, pwm_submodule_t subModule, bool idleStatus)
 Set PWM output in idle status (high or low).
void PWM_SetClockMode (PWM_Type *base, pwm_submodule_t subModule, pwm_clock_prescale_t prescaler)
 Set the pwm submodule prescaler.
void PWM_SetPwmForceOutputToZero (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmChannel, bool forcetozero)
 This function enables-disables the forcing of the output of a given eFlexPwm channel to logic 0.
void PWM_SetChannelOutput (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmChannel, pwm_output_state_t outputstate)
 This function set the output state of the PWM pin as requested for the current cycle.
Driver version
enum  _pwm_submodule { kPWM_Module_0 = 0U , kPWM_Module_1 , kPWM_Module_2 , kPWM_Module_3 }
 List of PWM submodules. More...
enum  _pwm_channels { kPWM_PwmB = 0U , kPWM_PwmA , kPWM_PwmX }
 List of PWM channels in each module.
enum  _pwm_value_register {
  kPWM_ValueRegister_0 = 0U , kPWM_ValueRegister_1 , kPWM_ValueRegister_2 , kPWM_ValueRegister_3 ,
  kPWM_ValueRegister_4 , kPWM_ValueRegister_5
 List of PWM value registers. More...
enum  _pwm_value_register_mask {
  kPWM_ValueRegisterMask_0 = (1U << 0) , kPWM_ValueRegisterMask_1 = (1U << 1) , kPWM_ValueRegisterMask_2 = (1U << 2) , kPWM_ValueRegisterMask_3 = (1U << 3) ,
  kPWM_ValueRegisterMask_4 = (1U << 4) , kPWM_ValueRegisterMask_5 = (1U << 5)
 List of PWM value registers mask. More...
enum  _pwm_clock_source { kPWM_BusClock = 0U , kPWM_ExternalClock , kPWM_Submodule0Clock }
 PWM clock source selection. More...
enum  _pwm_clock_prescale {
  kPWM_Prescale_Divide_1 = 0U , kPWM_Prescale_Divide_2 , kPWM_Prescale_Divide_4 , kPWM_Prescale_Divide_8 ,
  kPWM_Prescale_Divide_16 , kPWM_Prescale_Divide_32 , kPWM_Prescale_Divide_64 , kPWM_Prescale_Divide_128
 PWM prescaler factor selection for clock source. More...
enum  _pwm_force_output_trigger {
  kPWM_Force_Local = 0U , kPWM_Force_Master , kPWM_Force_LocalReload , kPWM_Force_MasterReload ,
  kPWM_Force_LocalSync , kPWM_Force_MasterSync , kPWM_Force_External , kPWM_Force_ExternalSync
 Options that can trigger a PWM FORCE_OUT. More...
enum  _pwm_output_state {
  kPWM_HighState = 0 , kPWM_LowState , kPWM_NormalState , kPWM_InvertState ,
  kPWM_MaskState
 PWM channel output status. More...
enum  _pwm_init_source { kPWM_Initialize_LocalSync = 0U , kPWM_Initialize_MasterReload , kPWM_Initialize_MasterSync , kPWM_Initialize_ExtSync }
 PWM counter initialization options. More...
enum  _pwm_load_frequency {
  kPWM_LoadEveryOportunity = 0U , kPWM_LoadEvery2Oportunity , kPWM_LoadEvery3Oportunity , kPWM_LoadEvery4Oportunity ,
  kPWM_LoadEvery5Oportunity , kPWM_LoadEvery6Oportunity , kPWM_LoadEvery7Oportunity , kPWM_LoadEvery8Oportunity ,
  kPWM_LoadEvery9Oportunity , kPWM_LoadEvery10Oportunity , kPWM_LoadEvery11Oportunity , kPWM_LoadEvery12Oportunity ,
  kPWM_LoadEvery13Oportunity , kPWM_LoadEvery14Oportunity , kPWM_LoadEvery15Oportunity , kPWM_LoadEvery16Oportunity
 PWM load frequency selection. More...
enum  _pwm_fault_input { kPWM_Fault_0 = 0U , kPWM_Fault_1 , kPWM_Fault_2 , kPWM_Fault_3 }
 List of PWM fault selections. More...
enum  _pwm_fault_disable { kPWM_FaultDisable_0 = (1U << 0) , kPWM_FaultDisable_1 = (1U << 1) , kPWM_FaultDisable_2 = (1U << 2) , kPWM_FaultDisable_3 = (1U << 3) }
 List of PWM fault disable mapping selections. More...
enum  _pwm_fault_channels { kPWM_faultchannel_0 = 0U , kPWM_faultchannel_1 }
 List of PWM fault channels.
enum  _pwm_input_capture_edge { kPWM_Disable = 0U , kPWM_FallingEdge , kPWM_RisingEdge , kPWM_RiseAndFallEdge }
 PWM capture edge select. More...
enum  _pwm_force_signal { kPWM_UsePwm = 0U , kPWM_InvertedPwm , kPWM_SoftwareControl , kPWM_UseExternal }
 PWM output options when a FORCE_OUT signal is asserted. More...
enum  _pwm_chnl_pair_operation { kPWM_Independent = 0U , kPWM_ComplementaryPwmA , kPWM_ComplementaryPwmB }
 Options available for the PWM A & B pair operation. More...
enum  _pwm_register_reload { kPWM_ReloadImmediate = 0U , kPWM_ReloadPwmHalfCycle , kPWM_ReloadPwmFullCycle , kPWM_ReloadPwmHalfAndFullCycle }
 Options available on how to load the buffered-registers with new values. More...
enum  _pwm_fault_recovery_mode { kPWM_NoRecovery = 0U , kPWM_RecoverHalfCycle , kPWM_RecoverFullCycle , kPWM_RecoverHalfAndFullCycle }
 Options available on how to re-enable the PWM output when recovering from a fault. More...
enum  _pwm_interrupt_enable {
  kPWM_CompareVal0InterruptEnable = (1U << 0) , kPWM_CompareVal1InterruptEnable = (1U << 1) , kPWM_CompareVal2InterruptEnable = (1U << 2) , kPWM_CompareVal3InterruptEnable = (1U << 3) ,
  kPWM_CompareVal4InterruptEnable = (1U << 4) , kPWM_CompareVal5InterruptEnable = (1U << 5) , kPWM_CaptureX0InterruptEnable = (1U << 6) , kPWM_CaptureX1InterruptEnable = (1U << 7) ,
  kPWM_CaptureB0InterruptEnable = (1U << 8) , kPWM_CaptureB1InterruptEnable = (1U << 9) , kPWM_CaptureA0InterruptEnable = (1U << 10) , kPWM_CaptureA1InterruptEnable = (1U << 11) ,
  kPWM_ReloadInterruptEnable = (1U << 12) , kPWM_ReloadErrorInterruptEnable = (1U << 13) , kPWM_Fault0InterruptEnable = (1U << 16) , kPWM_Fault1InterruptEnable = (1U << 17) ,
  kPWM_Fault2InterruptEnable = (1U << 18) , kPWM_Fault3InterruptEnable = (1U << 19)
 List of PWM interrupt options. More...
enum  _pwm_status_flags {
  kPWM_CompareVal0Flag = (1U << 0) , kPWM_CompareVal1Flag = (1U << 1) , kPWM_CompareVal2Flag = (1U << 2) , kPWM_CompareVal3Flag = (1U << 3) ,
  kPWM_CompareVal4Flag = (1U << 4) , kPWM_CompareVal5Flag = (1U << 5) , kPWM_CaptureX0Flag = (1U << 6) , kPWM_CaptureX1Flag = (1U << 7) ,
  kPWM_CaptureB0Flag = (1U << 8) , kPWM_CaptureB1Flag = (1U << 9) , kPWM_CaptureA0Flag = (1U << 10) , kPWM_CaptureA1Flag = (1U << 11) ,
  kPWM_ReloadFlag = (1U << 12) , kPWM_ReloadErrorFlag = (1U << 13) , kPWM_RegUpdatedFlag = (1U << 14) , kPWM_Fault0Flag = (1U << 16) ,
  kPWM_Fault1Flag = (1U << 17) , kPWM_Fault2Flag = (1U << 18) , kPWM_Fault3Flag = (1U << 19)
 List of PWM status flags. More...
enum  _pwm_dma_enable {
  kPWM_CaptureX0DMAEnable = (1U << 0) , kPWM_CaptureX1DMAEnable = (1U << 1) , kPWM_CaptureB0DMAEnable = (1U << 2) , kPWM_CaptureB1DMAEnable = (1U << 3) ,
  kPWM_CaptureA0DMAEnable = (1U << 4) , kPWM_CaptureA1DMAEnable = (1U << 5)
 List of PWM DMA options. More...
enum  _pwm_dma_source_select { kPWM_DMARequestDisable = 0U , kPWM_DMAWatermarksEnable , kPWM_DMALocalSync , kPWM_DMALocalReload }
 List of PWM capture DMA enable source select. More...
enum  _pwm_watermark_control { kPWM_FIFOWatermarksOR = 0U , kPWM_FIFOWatermarksAND }
 PWM FIFO Watermark AND Control. More...
enum  _pwm_mode { kPWM_SignedCenterAligned = 0U , kPWM_CenterAligned , kPWM_SignedEdgeAligned , kPWM_EdgeAligned }
 PWM operation mode. More...
enum  _pwm_level_select { kPWM_HighTrue = 0U , kPWM_LowTrue }
 PWM output pulse mode, high-true or low-true. More...
enum  _pwm_fault_state { kPWM_PwmFaultState0 , kPWM_PwmFaultState1 , kPWM_PwmFaultState2 , kPWM_PwmFaultState3 }
 PWM output fault status. More...
enum  _pwm_reload_source_select { kPWM_LocalReload = 0U , kPWM_MasterReload }
 PWM reload source select. More...
enum  _pwm_fault_clear { kPWM_Automatic = 0U , kPWM_ManualNormal , kPWM_ManualSafety }
 PWM fault clearing options. More...
enum  _pwm_module_control { kPWM_Control_Module_0 = (1U << 0) , kPWM_Control_Module_1 = (1U << 1) , kPWM_Control_Module_2 = (1U << 2) , kPWM_Control_Module_3 = (1U << 3) }
 Options for submodule master control operation. More...
typedef enum _pwm_submodule pwm_submodule_t
typedef enum _pwm_channels pwm_channels_t
typedef enum _pwm_value_register pwm_value_register_t
typedef enum _pwm_clock_source pwm_clock_source_t
typedef enum _pwm_clock_prescale pwm_clock_prescale_t
typedef enum _pwm_force_output_trigger pwm_force_output_trigger_t
typedef enum _pwm_output_state pwm_output_state_t
typedef enum _pwm_init_source pwm_init_source_t
typedef enum _pwm_load_frequency pwm_load_frequency_t
typedef enum _pwm_fault_input pwm_fault_input_t
typedef enum _pwm_fault_disable pwm_fault_disable_t
typedef enum _pwm_fault_channels pwm_fault_channels_t
typedef enum _pwm_input_capture_edge pwm_input_capture_edge_t
typedef enum _pwm_force_signal pwm_force_signal_t
typedef enum _pwm_chnl_pair_operation pwm_chnl_pair_operation_t
typedef enum _pwm_register_reload pwm_register_reload_t
typedef enum _pwm_fault_recovery_mode pwm_fault_recovery_mode_t
typedef enum _pwm_interrupt_enable pwm_interrupt_enable_t
typedef enum _pwm_status_flags pwm_status_flags_t
typedef enum _pwm_dma_enable pwm_dma_enable_t
typedef enum _pwm_dma_source_select pwm_dma_source_select_t
typedef enum _pwm_watermark_control pwm_watermark_control_t
typedef enum _pwm_mode pwm_mode_t
 PWM operation mode.
typedef enum _pwm_level_select pwm_level_select_t
typedef enum _pwm_fault_state pwm_fault_state_t
typedef enum _pwm_reload_source_select pwm_reload_source_select_t
typedef enum _pwm_fault_clear pwm_fault_clear_t
typedef enum _pwm_module_control pwm_module_control_t
typedef struct _pwm_signal_param pwm_signal_param_t
typedef struct _pwm_config pwm_config_t
typedef struct _pwm_fault_input_filter_param pwm_fault_input_filter_param_t
typedef struct _pwm_fault_param pwm_fault_param_t
typedef struct _pwm_input_capture_param pwm_input_capture_param_t
#define FSL_PWM_DRIVER_VERSION   (MAKE_VERSION(2, 5, 1))
#define PWM_SUBMODULE_SWCONTROL_WIDTH   2
#define PWM_SUBMODULE_CHANNEL   2
Initialization and deinitialization
status_t PWM_Init (PWM_Type *base, pwm_submodule_t subModule, const pwm_config_t *config)
 Ungates the PWM submodule clock and configures the peripheral for basic operation.
void PWM_Deinit (PWM_Type *base, pwm_submodule_t subModule)
 Gate the PWM submodule clock.
void PWM_GetDefaultConfig (pwm_config_t *config)
 Fill in the PWM config struct with the default settings.
Module PWM output
status_t PWM_SetupPwm (PWM_Type *base, pwm_submodule_t subModule, const pwm_signal_param_t *chnlParams, uint8_t numOfChnls, pwm_mode_t mode, uint32_t pwmFreq_Hz, uint32_t srcClock_Hz)
 Sets up the PWM signals for a PWM submodule.
status_t PWM_SetupPwmPhaseShift (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmChannel, uint32_t pwmFreq_Hz, uint32_t srcClock_Hz, uint8_t shiftvalue, bool doSync)
 Set PWM phase shift for PWM channel running on channel PWM_A, PWM_B which with 50% duty cycle..
void PWM_UpdatePwmDutycycle (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmSignal, pwm_mode_t currPwmMode, uint8_t dutyCyclePercent)
 Updates the PWM signal's dutycycle.
void PWM_UpdatePwmDutycycleHighAccuracy (PWM_Type *base, pwm_submodule_t subModule, pwm_channels_t pwmSignal, pwm_mode_t currPwmMode, uint16_t dutyCycle)
 Updates the PWM signal's dutycycle with 16-bit accuracy.
Interrupts Interface
void PWM_EnableInterrupts (PWM_Type *base, pwm_submodule_t subModule, uint32_t mask)
 Enables the selected PWM interrupts.
void PWM_DisableInterrupts (PWM_Type *base, pwm_submodule_t subModule, uint32_t mask)
 Disables the selected PWM interrupts.
uint32_t PWM_GetEnabledInterrupts (PWM_Type *base, pwm_submodule_t subModule)
 Gets the enabled PWM interrupts.
Status Interface
uint32_t PWM_GetStatusFlags (PWM_Type *base, pwm_submodule_t subModule)
 Gets the PWM status flags.
void PWM_ClearStatusFlags (PWM_Type *base, pwm_submodule_t subModule, uint32_t mask)
 Clears the PWM status flags.
◆ FSL_PWM_DRIVER_VERSION
Version 2.5.1
◆ PWM_SUBMODULE_CHANNEL
Because setting the pwm duty cycle doesn't support PWMX, getting the pwm duty cycle also doesn't support PWMX.
◆ PWM_SUBMODULE_SWCONTROL_WIDTH
Number of bits per submodule for software output control
Typedef Documentation
◆ pwm_config_t
This structure holds the configuration settings for the PWM peripheral. To initialize this structure to reasonable defaults, call the PWM_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
◆ _pwm_chnl_pair_operation
kPWM_Independent
PWM A & PWM B operate as 2 independent channels
PWM A & PWM B are complementary channels, PWM A generates the signal
PWM A & PWM B are complementary channels, PWM B generates the signal
◆ _pwm_clock_prescale
PWM clock frequency = fclk/1
PWM clock frequency = fclk/2
PWM clock frequency = fclk/4
PWM clock frequency = fclk/8
PWM clock frequency = fclk/16
PWM clock frequency = fclk/32
PWM clock frequency = fclk/64
PWM clock frequency = fclk/128
◆ _pwm_clock_source
kPWM_BusClock
The IPBus clock is used as the clock
kPWM_ExternalClock
EXT_CLK is used as the clock
Clock of the submodule 0 (AUX_CLK) is used as the source clock
◆ _pwm_dma_enable
PWM capture X0 DMA
PWM capture X1 DMA
PWM capture B0 DMA
PWM capture B1 DMA
PWM capture A0 DMA
PWM capture A1 DMA
◆ _pwm_dma_source_select
Read DMA requests disabled
Exceeding a FIFO watermark sets the DMA read request
kPWM_DMALocalSync
A local sync (VAL1 matches counter) sets the read DMA request
kPWM_DMALocalReload
A local reload (STS[RF] being set) sets the read DMA request
◆ _pwm_fault_clear
kPWM_Automatic
Automatic fault clearing
kPWM_ManualNormal
Manual fault clearing with no fault safety mode
kPWM_ManualSafety
Manual fault clearing with fault safety mode
◆ _pwm_fault_disable
kPWM_FaultDisable_0
Fault 0 disable mapping
kPWM_FaultDisable_1
Fault 1 disable mapping
kPWM_FaultDisable_2
Fault 2 disable mapping
kPWM_FaultDisable_3
Fault 3 disable mapping
◆ _pwm_fault_input
kPWM_Fault_0
Fault 0 input pin
kPWM_Fault_1
Fault 1 input pin
kPWM_Fault_2
Fault 2 input pin
kPWM_Fault_3
Fault 3 input pin
◆ _pwm_fault_recovery_mode
kPWM_NoRecovery
PWM output will stay inactive
PWM output re-enabled at the first half cycle
PWM output re-enabled at the first full cycle
PWM output re-enabled at the first half or full cycle
◆ _pwm_fault_state
kPWM_PwmFaultState0
Output is forced to logic 0 state prior to consideration of output polarity control.
kPWM_PwmFaultState1
Output is forced to logic 1 state prior to consideration of output polarity control.
kPWM_PwmFaultState2
Output is tristated.
kPWM_PwmFaultState3
◆ _pwm_force_output_trigger
kPWM_Force_Local
The local force signal, CTRL2[FORCE], from the submodule is used to force updates
kPWM_Force_Master
The master force signal from submodule 0 is used to force updates
The local reload signal from this submodule is used to force updates without regard to the state of LDOK
The master reload signal from submodule 0 is used to force updates if LDOK is set
The local sync signal from this submodule is used to force updates
The master sync signal from submodule0 is used to force updates
kPWM_Force_External
The external force signal, EXT_FORCE, from outside the PWM module causes updates
The external sync signal, EXT_SYNC, from outside the PWM module causes updates
◆ _pwm_force_signal
kPWM_UsePwm
Generated PWM signal is used by the deadtime logic.
kPWM_InvertedPwm
Inverted PWM signal is used by the deadtime logic.
Software controlled value is used by the deadtime logic.
kPWM_UseExternal
PWM_EXTA signal is used by the deadtime logic.
◆ _pwm_init_source
Local sync causes initialization
Master reload from submodule 0 causes initialization
Master sync from submodule 0 causes initialization
EXT_SYNC causes initialization
◆ _pwm_input_capture_edge
kPWM_Disable
Disabled
kPWM_FallingEdge
Capture on falling edge only
kPWM_RisingEdge
Capture on rising edge only
Capture on rising or falling edge
◆ _pwm_interrupt_enable
PWM VAL0 compare interrupt
PWM VAL1 compare interrupt
PWM VAL2 compare interrupt
PWM VAL3 compare interrupt
PWM VAL4 compare interrupt
PWM VAL5 compare interrupt
PWM capture X0 interrupt
PWM capture X1 interrupt
PWM capture B0 interrupt
PWM capture B1 interrupt
PWM capture A0 interrupt
PWM capture A1 interrupt
PWM reload interrupt
PWM reload error interrupt
PWM fault 0 interrupt
PWM fault 1 interrupt
PWM fault 2 interrupt
PWM fault 3 interrupt
◆ _pwm_level_select
kPWM_HighTrue
High level represents "on" or "active" state
kPWM_LowTrue
Low level represents "on" or "active" state
◆ _pwm_load_frequency
Every PWM opportunity
Every 2 PWM opportunities
Every 3 PWM opportunities
Every 4 PWM opportunities
Every 5 PWM opportunities
Every 6 PWM opportunities
Every 7 PWM opportunities
Every 8 PWM opportunities
Every 9 PWM opportunities
Every 10 PWM opportunities
Every 11 PWM opportunities
Every 12 PWM opportunities
Every 13 PWM opportunities
Every 14 PWM opportunities
Every 15 PWM opportunities
Every 16 PWM opportunities
◆ _pwm_mode
enum _pwm_mode
PWM operation mode.
Signed center-aligned
kPWM_CenterAligned
Unsigned cente-aligned
Signed edge-aligned
kPWM_EdgeAligned
Unsigned edge-aligned
◆ _pwm_module_control
Control submodule 0's start/stop,buffer reload operation
Control submodule 1's start/stop,buffer reload operation
Control submodule 2's start/stop,buffer reload operation
Control submodule 3's start/stop,buffer reload operation
◆ _pwm_output_state
kPWM_HighState
The output state of PWM channel is high
kPWM_LowState
The output state of PWM channel is low
kPWM_NormalState
The output state of PWM channel is normal
kPWM_InvertState
The output state of PWM channel is invert
kPWM_MaskState
The output state of PWM channel is mask
◆ _pwm_register_reload
Buffered-registers get loaded with new values as soon as LDOK bit is set
Registers loaded on a PWM half cycle
Registers loaded on a PWM full cycle
Registers loaded on a PWM half & full cycle
◆ _pwm_reload_source_select
kPWM_LocalReload
The local reload signal is used to reload registers
kPWM_MasterReload
The master reload signal (from submodule 0) is used to reload
◆ _pwm_status_flags
PWM VAL0 compare flag
PWM VAL1 compare flag
PWM VAL2 compare flag
PWM VAL3 compare flag
PWM VAL4 compare flag
PWM VAL5 compare flag
kPWM_CaptureX0Flag
PWM capture X0 flag
kPWM_CaptureX1Flag
PWM capture X1 flag
kPWM_CaptureB0Flag
PWM capture B0 flag
kPWM_CaptureB1Flag
PWM capture B1 flag
kPWM_CaptureA0Flag
PWM capture A0 flag
kPWM_CaptureA1Flag
PWM capture A1 flag
kPWM_ReloadFlag
PWM reload flag
PWM reload error flag
kPWM_RegUpdatedFlag
PWM registers updated flag
kPWM_Fault0Flag
PWM fault 0 flag
kPWM_Fault1Flag
PWM fault 1 flag
kPWM_Fault2Flag
PWM fault 2 flag
kPWM_Fault3Flag
PWM fault 3 flag
◆ _pwm_submodule
kPWM_Module_0
Submodule 0
kPWM_Module_1
Submodule 1
kPWM_Module_2
Submodule 2
kPWM_Module_3
Submodule 3
◆ _pwm_value_register
PWM Value0 register
PWM Value1 register
PWM Value2 register
PWM Value3 register
PWM Value4 register
PWM Value5 register
◆ _pwm_value_register_mask
PWM Value0 register mask
PWM Value1 register mask
PWM Value2 register mask
PWM Value3 register mask
PWM Value4 register mask
PWM Value5 register mask
◆ _pwm_watermark_control
Selected FIFO watermarks are OR'ed together
Selected FIFO watermarks are AND'ed together
◆ PWM_ClearStatusFlags()
void PWM_ClearStatusFlags ( PWM_Type base,
uint32_t  mask
Parameters
basePWM peripheral base address
subModulePWM submodule to configure
maskThe status flags to clear. This is a logical OR of members of the enumeration pwm_status_flags_t
brief Clears the PWM status flags
param base PWM peripheral base address param subModule PWM submodule to configure param mask The status flags to clear. This is a logical OR of members of the enumeration pwm_status_flags_t
◆ PWM_Deinit()
void PWM_Deinit ( PWM_Type base,
Parameters
subModulePWM submodule to deinitialize
brief Gate the PWM submodule clock
param base PWM peripheral base address param subModule PWM submodule to deinitialize
◆ PWM_DisableInterrupts()
void PWM_DisableInterrupts ( PWM_Type base,
uint32_t  mask
Parameters
maskThe interrupts to enable. This is a logical OR of members of the enumeration pwm_interrupt_enable_t
brief Disables the selected PWM interrupts
param base PWM peripheral base address param subModule PWM submodule to configure param mask The interrupts to enable. This is a logical OR of members of the enumeration pwm_interrupt_enable_t
◆ PWM_EnableInterrupts()
void PWM_EnableInterrupts ( PWM_Type base,
uint32_t  mask
Parameters
brief Enables the selected PWM interrupts
◆ PWM_FaultDefaultConfig()
void PWM_FaultDefaultConfig ( pwm_fault_param_t config)
The default values are:
config->faultClearingMode = kPWM_Automatic;
config->faultLevel = false;
config->enableCombinationalPath = true;
config->recoverMode = kPWM_NoRecovery;
@ kPWM_NoRecovery
Definition: fsl_pwm.h:208
@ kPWM_Automatic
Definition: fsl_pwm.h:324
Definition: deflate.c:114
Parameters
configPointer to user's PWM fault config structure.
brief Fill in the PWM fault config struct with the default settings
The default values are: code config->faultClearingMode = kPWM_Automatic; config->faultLevel = false; config->enableCombinationalPath = true; config->recoverMode = kPWM_NoRecovery; endcode param config Pointer to user's PWM fault config structure.
◆ PWM_GetDefaultConfig()
void PWM_GetDefaultConfig ( pwm_config_t config)
config->enableDebugMode = false;
config->enableWait = false;
config->reloadSelect = kPWM_LocalReload;
config->clockSource = kPWM_BusClock;
config->initializationControl = kPWM_Initialize_LocalSync;
config->forceTrigger = kPWM_Force_Local;
config->reloadFrequency = kPWM_LoadEveryOportunity;
config->pairOperation = kPWM_Independent;
@ kPWM_LoadEveryOportunity
Definition: fsl_pwm.h:127
@ kPWM_Independent
Definition: fsl_pwm.h:191
@ kPWM_Force_Local
Definition: fsl_pwm.h:94
@ kPWM_Initialize_LocalSync
Definition: fsl_pwm.h:118
@ kPWM_ReloadImmediate
Definition: fsl_pwm.h:199
@ kPWM_Prescale_Divide_1
Definition: fsl_pwm.h:81
@ kPWM_BusClock
Definition: fsl_pwm.h:73
@ kPWM_LocalReload
Definition: fsl_pwm.h:317
Parameters
configPointer to user's PWM config structure.
brief Fill in the PWM config struct with the default settings
The default values are: code config->enableDebugMode = false; config->enableWait = false; config->reloadSelect = kPWM_LocalReload; config->clockSource = kPWM_BusClock; config->prescale = kPWM_Prescale_Divide_1; config->initializationControl = kPWM_Initialize_LocalSync; config->forceTrigger = kPWM_Force_Local; config->reloadFrequency = kPWM_LoadEveryOportunity; config->reloadLogic = kPWM_ReloadImmediate; config->pairOperation = kPWM_Independent; endcode param config Pointer to user's PWM config structure.
◆ PWM_GetEnabledInterrupts()
uint32_t PWM_GetEnabledInterrupts ( PWM_Type base,
Parameters
Returns
The enabled interrupts. This is the logical OR of members of the enumeration pwm_interrupt_enable_t
brief Gets the enabled PWM interrupts
return The enabled interrupts. This is the logical OR of members of the enumeration pwm_interrupt_enable_t
◆ PWM_GetPwmChannelState()
uint8_t PWM_GetPwmChannelState ( PWM_Type base,
Parameters
pwmChannelPWM channel to configure
Returns
Current channel dutycycle value.
brief Get the dutycycle value.
param base PWM peripheral base address param subModule PWM submodule to configure param pwmChannel PWM channel to configure
return Current channel dutycycle value.
◆ PWM_GetStatusFlags()
uint32_t PWM_GetStatusFlags ( PWM_Type base,
Parameters
Returns
The status flags. This is the logical OR of members of the enumeration pwm_status_flags_t
brief Gets the PWM status flags
return The status flags. This is the logical OR of members of the enumeration pwm_status_flags_t
◆ PWM_Init()
status_t PWM_Init ( PWM_Type base,
const pwm_config_t config
Note
This API should be called at the beginning of the application using the PWM driver.
Parameters
Returns
kStatus_Success means success; else failed.
brief Ungates the PWM submodule clock and configures the peripheral for basic operation.
note This API should be called at the beginning of the application using the PWM driver.
param base PWM peripheral base address param subModule PWM submodule to configure param config Pointer to user's PWM config structure.
return kStatus_Success means success; else failed.
◆ PWM_SetChannelOutput()
void PWM_SetChannelOutput ( PWM_Type base,
Parameters
outputstateSet pwm output state, see pwm_output_state_t.
brief This function set the output state of the PWM pin as requested for the current cycle.
param base PWM peripheral base address param subModule PWM submodule to configure param pwmChannel PWM channel to configure param outputstate Set pwm output state, see pwm_output_state_t.
◆ PWM_SetClockMode()
void PWM_SetClockMode ( PWM_Type base,
Parameters
prescalerSet prescaler value
brief Set the pwm submodule prescaler.
param base PWM peripheral base address param subModule PWM submodule to configure param prescaler Set prescaler value
◆ PWM_SetOutputToIdle()
status_t PWM_SetOutputToIdle ( PWM_Type base,
bool  idleStatus
Note
This API should call after PWM_SetupPwm() APIs, and PWMX submodule is not supported.
Parameters
idleStatusTrue: PWM output is high in idle status; false: PWM output is low in idle status.
Returns
kStatus_Fail if there was error setting up the signal; kStatus_Success if set output idle success
brief Set PWM output in idle status (high or low).
note This API should call after PWM_SetupPwm() APIs, and PWMX submodule is not supported.
param base PWM peripheral base address param pwmChannel PWM channel to configure param subModule PWM submodule to configure param idleStatus True: PWM output is high in idle status; false: PWM output is low in idle status.
return kStatus_Fail if there was error setting up the signal; kStatus_Success if set output idle success
◆ PWM_SetPwmForceOutputToZero()
void PWM_SetPwmForceOutputToZero ( PWM_Type base,
bool  forcetozero
Parameters
forcetozeroTrue: Enable the pwm force output to zero; False: Disable the pwm output resumes normal function.
brief This function enables-disables the forcing of the output of a given eFlexPwm channel to logic 0.
param base PWM peripheral base address param pwmChannel PWM channel to configure param subModule PWM submodule to configure param forcetozero True: Enable the pwm force output to zero; False: Disable the pwm output resumes normal function.
◆ PWM_SetupFaultInputFilter()
void PWM_SetupFaultInputFilter ( PWM_Type base,
const pwm_fault_input_filter_param_t faultInputFilterParams
Parameters
faultInputFilterParamsParameters passed in to set up the fault input filter.
Parameters
◆ PWM_SetupFaults()
void PWM_SetupFaults ( PWM_Type base,
const pwm_fault_param_t faultParams
PWM has 4 fault inputs.
Parameters
faultNumPWM fault to configure.
faultParamsPointer to the PWM fault config structure
brief Sets up the PWM fault protection.
param base PWM peripheral base address param faultNum PWM fault to configure. param faultParams Pointer to the PWM fault config structure
◆ PWM_SetupForceSignal()
void PWM_SetupForceSignal ( PWM_Type base,
The user specifies which channel to configure by supplying the submodule number and whether to modify PWM A or PWM B within that submodule.
Parameters
pwmChannelChannel to configure
modeSignal to output when a FORCE_OUT is triggered
brief Selects the signal to output on a PWM pin when a FORCE_OUT signal is asserted.
param base PWM peripheral base address param subModule PWM submodule to configure param pwmChannel Channel to configure param mode Signal to output when a FORCE_OUT is triggered
◆ PWM_SetupInputCapture()
void PWM_SetupInputCapture ( PWM_Type base,
const pwm_input_capture_param_t inputCaptureParams
Each PWM submodule has 3 pins that can be configured for use as input capture pins. This function sets up the capture parameters for each pin and enables the pin for input capture operation.
Parameters
pwmChannelChannel in the submodule to setup
inputCaptureParamsParameters passed in to set up the input pin
brief Sets up the PWM input capture
param base PWM peripheral base address param subModule PWM submodule to configure param pwmChannel Channel in the submodule to setup param inputCaptureParams Parameters passed in to set up the input pin
◆ PWM_SetupPwm()
status_t PWM_SetupPwm ( PWM_Type base,
const pwm_signal_param_t chnlParams,
uint8_t  numOfChnls,
pwm_mode_t  mode,
The function initializes the submodule according to the parameters passed in by the user. The function also sets up the value compare registers to match the PWM signal requirements. If the dead time insertion logic is enabled, the pulse period is reduced by the dead time period specified by the user.
Parameters
chnlParamsArray of PWM channel parameters to configure the channel(s), PWMX submodule is not supported.
numOfChnlsNumber of channels to configure, this should be the size of the array passed in. Array size should not be more than 2 as each submodule has 2 pins to output PWM
modePWM operation mode, options available in enumeration pwm_mode_t
pwmFreq_HzPWM signal frequency in Hz
srcClock_HzPWM main counter clock in Hz.
Returns
Returns kStatus_Fail if there was error setting up the signal; kStatus_Success otherwise
brief Sets up the PWM signals for a PWM submodule.
param base PWM peripheral base address param subModule PWM submodule to configure param chnlParams Array of PWM channel parameters to configure the channel(s), PWMX submodule is not supported. param numOfChnls Number of channels to configure, this should be the size of the array passed in. Array size should not be more than 2 as each submodule has 2 pins to output PWM param mode PWM operation mode, options available in enumeration pwm_mode_t param pwmFreq_Hz PWM signal frequency in Hz param srcClock_Hz PWM main counter clock in Hz.
return Returns kStatusFail if there was error setting up the signal; kStatusSuccess otherwise
◆ PWM_SetupPwmPhaseShift()
status_t PWM_SetupPwmPhaseShift ( PWM_Type base,
uint8_t  shiftvalue,
bool  doSync
Parameters
shiftvaluePhase shift value
doSynctrue: Set LDOK bit for the submodule list; false: LDOK bit don't set, need to call PWM_SetPwmLdok to sync update.
Returns
brief Set PWM phase shift for PWM channel running on channel PWM_A, PWM_B which with 50% duty cycle.
param base PWM peripheral base address param subModule PWM submodule to configure param pwmChannel PWM channel to configure param pwmFreq_Hz PWM signal frequency in Hz param srcClock_Hz PWM main counter clock in Hz. param shiftvalue Phase shift value, range in 0 ~ 50 param doSync true: Set LDOK bit for the submodule list; false: LDOK bit don't set, need to call PWM_SetPwmLdok to sync update.
return Returns kStatus_Fail if there was error setting up the signal; kStatus_Success otherwise
◆ PWM_UpdatePwmDutycycle()
void PWM_UpdatePwmDutycycle ( PWM_Type base,
The function updates the PWM dutycyle to the new value that is passed in. If the dead time insertion logic is enabled then the pulse period is reduced by the dead time period specified by the user.
Parameters
pwmSignalSignal (PWM A or PWM B) to update
currPwmModeThe current PWM mode set during PWM setup
dutyCyclePercentNew PWM pulse width, value should be between 0 to 100 0=inactive signal(0% duty cycle)... 100=active signal (100% duty cycle)
brief Updates the PWM signal's dutycycle.
param base PWM peripheral base address param subModule PWM submodule to configure param pwmSignal Signal (PWM A or PWM B) to update param currPwmMode The current PWM mode set during PWM setup param dutyCyclePercent New PWM pulse width, value should be between 0 to 100 0=inactive signal(0% duty cycle)... 100=active signal (100% duty cycle)
◆ PWM_UpdatePwmDutycycleHighAccuracy()
void PWM_UpdatePwmDutycycleHighAccuracy ( PWM_Type base,
uint16_t  dutyCycle
Parameters
dutyCycleNew PWM pulse width, value should be between 0 to 65535 0=inactive signal(0% duty cycle)... 65535=active signal (100% duty cycle)
brief Updates the PWM signal's dutycycle with 16-bit accuracy.
param base PWM peripheral base address param subModule PWM submodule to configure param pwmSignal Signal (PWM A or PWM B) to update param currPwmMode The current PWM mode set during PWM setup param dutyCycle New PWM pulse width, value should be between 0 to 65535 0=inactive signal(0% duty cycle)... 65535=active signal (100% duty cycle)
