RTEMS 6.1-rc2
_pwm_config Struct Reference
PWM config structure. More...
#include <fsl_pwm.h>
bool enableDebugMode
bool enableWait
pwm_init_source_t initializationControl
pwm_clock_source_t clockSource
pwm_clock_prescale_t prescale
pwm_chnl_pair_operation_t pairOperation
pwm_register_reload_t reloadLogic
pwm_reload_source_select_t reloadSelect
pwm_load_frequency_t reloadFrequency
pwm_force_output_trigger_t forceTrigger
This structure holds the configuration settings for the PWM peripheral. To initialize this structure to reasonable defaults, call the PWM_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
Field Documentation
◆ clockSource
pwm_clock_source_t _pwm_config::clockSource
Clock source for the counter
◆ enableDebugMode
bool _pwm_config::enableDebugMode
true: PWM continues to run in debug mode; false: PWM is paused in debug mode
◆ enableWait
bool _pwm_config::enableWait
true: PWM continues to run in WAIT mode; false: PWM is paused in WAIT mode
◆ forceTrigger
pwm_force_output_trigger_t _pwm_config::forceTrigger
Specify which signal will trigger a FORCE_OUT
◆ initializationControl
pwm_init_source_t _pwm_config::initializationControl
Option to initialize the counter
◆ pairOperation
pwm_chnl_pair_operation_t _pwm_config::pairOperation
Channel pair in indepedent or complementary mode
◆ prescale
pwm_clock_prescale_t _pwm_config::prescale
Pre-scaler to divide down the clock
◆ reloadFrequency
pwm_load_frequency_t _pwm_config::reloadFrequency
Specifies when to reload, used when user's choice is not immediate reload
◆ reloadLogic
pwm_register_reload_t _pwm_config::reloadLogic
PWM Reload logic setup
◆ reloadSelect
pwm_reload_source_select_t _pwm_config::reloadSelect
Reload source select
