RTEMS 6.1-rc2
_pwm_fault_param Struct Reference
Structure is used to hold the parameters to configure a PWM fault. More...
#include <fsl_pwm.h>
pwm_fault_clear_t faultClearingMode
bool faultLevel
bool enableCombinationalPath
pwm_fault_recovery_mode_t recoverMode
Field Documentation
◆ enableCombinationalPath
bool _pwm_fault_param::enableCombinationalPath
true: Combinational Path from fault input is enabled; false: No combination path is available
◆ faultClearingMode
pwm_fault_clear_t _pwm_fault_param::faultClearingMode
Fault clearing mode to use
◆ faultLevel
bool _pwm_fault_param::faultLevel
true: Logic 1 indicates fault; false: Logic 0 indicates fault
◆ recoverMode
pwm_fault_recovery_mode_t _pwm_fault_param::recoverMode
Specify when to re-enable the PWM output
